Question about Cooktops
Cut out dimensions for whirlpool double oven model rbd275pd86
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
Kenmore 629
Could be the lock needs replacing the oven won't self clean if the door lock isn't functioning it's a safety thing so you don't get your face burnt .
Ray
Apr 16, 2014 | Kenmore Cooktops
Whirlpool self-cleaning feature not available
Because the features mention utilize 220 VAC power, I do not advise you attempt any corrections. Very dangerous; unless you are a trained technician. If the unit is in Warranty, get the Whirlpool folks out to you home ASAP.
Dec 19, 2013 | Whirlpool Gold GGE388LX Double Oven...
Where is the Pilot for my whirlpool oven
If you have a pilot light, it's in the oven section you take the bottom plate off with the 2 screws holding it on. It's going to be in the back by the burner valves. Most whirlpools don't carry pilot lights.
Nov 28, 2013 | Whirlpool Stove / Oven / Range Pilot...
Maytag ceramic top stove with the double oven, two small burners don't get hot anymore can I fix myself and how?
It is simple . Before the process make sure the the power is off .. There screws on the back after removing them you can lift the top n easily remove the none working ones . You can buy the spear ones online or local shop . I have done it myself or search YouTube with model number youse come a cross with repair option . Good luck .
Aug 06, 2013 | Cooktops
Whirlpool Double Oven Range
Recycle the circuit breaker for the oven several times. If you haven't used the oven much the contacts may be corroded. The display is off a 110Vac circuit but the ovens use 220Vac, The circuit breaker should be 2 switches "ganged" together as one. Both should be cycled...
Dec 25, 2012 | Whirlpool GGE388LXB - Black GoldR Double...
What are the dimensions for the JED8430??
The top dimensions are 29 3/4" x 22" and the cut out needs to be 28 7/8" x 21 1/8" if the need the install manual you can get on the link below.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8101P419-60.pdf
Good Luck and please Rate 4 thumbs for the free answer
Jun 06, 2010 | Jenn-Air JED8430 Electric Cooktop
I have a Whirlpool Accubake self-cleaning oven,model RBD275PD86. My wife ran the self-cleaner, then after a short time, everything went black,as if it burned out the oven. What needs to be replaced to get...
CHECK THERMAL CUT OUT ON BACK OF UNIT, MOST LIKELY THE PROBLEM YOU CAN BUY A CAN OF ELECTRONICS FREEZE AND SPRAY IT AND THEN TIP WITH BACK END OF NUT DRIVER CHEAP FIX
Sep 27, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Cooktops Logo
59 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
