Question about Lexmark Optra T614 Laser Printer
I am replacing my printer cartridge on my Lexmark T-614. The new cartridge came with a 'buffer bar'. How do I install it?
  • 320 Answers
The fuser cover is located right under where the paper comes out of the top of the printer. the part you are refering to if the fuser wiper.
Posted on Dec 07, 2009
  • 85 Answers
Remove cover over top of fuser, it goes under that
Posted on Feb 15, 2009
I refilled my Lexmark cartridge but it continues to say I need to install a new cartridge. The printer model is x2670.
Hello there,
The reason why your Lexmark printer keeps on telling you to install new cartridge because the printer have ink cartridge detection. Meaning it will detect whether that particular cartridge is an old one or not.
Each Ink Cartridges have its code and it will be registered to the printer once you have connected it. The printer will assume the ink level and once it is empty, that particular Lexmark Ink Cartridge will be registered to your printer as an empty ink cartridge and needed to be replace with a new one.
I would suggest getting a genuine new cartridge instead of refilling the ink cartridges.
Feb 17, 2011 | Lexmark X2670 All-In-One Printer
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
Lexmark z816 the cartridge goes accross as tp
Normally this is caused by the cartridges not being installed correctly. Please go to the Lexmark site www.lexmark.com. Select Technical support, then search using the Z816 model printer. A new search bar will appear. Place the following number ENUS32244 into the box and hit <Enter>. Don
Jun 09, 2009 | Lexmark Z816 InkJet Printer
Installed new black ink cartridge
If you are using a cartridge that is not a factory new Lexmark cartridge, then I have bad news for you.Lexmark printers have intelligence in them to protect them against product tampering. Using non Lexmark cartridges or refilled cartridges is considered to "Tampering" by Lexmark.Please see the "Supplies Warranty Statemen" on the Lexmark web site: www.Lexmark.com.All I ask is that you do not shoot the messanger on this one!Don
Jun 07, 2009 | Lexmark X2500 All-In-One Printer
How do I change the ink cartridge on lexmark x3480
Please use lexmark solution center... here it is:
To install a cartridge using the Solution Center:
  1. Make sure the printer is switched on, the old cartridges are still in the printer, and the cartridge cover is closed.
  2. Click on Start, Programs (XP: All Programs), Lexmark <Printer Name>, Lexmark <Printer Name> Solution Center.
  3. When the Solution Center screen appears, click on the Maintenance button on the left-hand side. (This button is the third from the top and bears a picture of ink drops.)
  4. When you see the Install or obtain a New Cartridge option, click on it once. A pop-up displays a brief description of how to physically remove an old cartridge and install a new one.
  5. Follow these instructions and click Next. The software will prompt you to confirm whether the cartridges are new or old.
  6. For the new cartridge you just inserted, select No, it's new. Important: Make sure the setting for any old cartridge stays on Yes, It is old.
  7. Once your selections have been made, click OK. The program will want to run the alignment for any new cartridges you installed. This applies whether you changed one or both cartridges (in the case of printers that can hold two cartridges). An alignment screen with a red and white bull's eye will appear.
  8. Make sure the cartridge cover is closed and that there is paper in the printer.
  9. Then click the Print button on the alignment screen. A sheet of paper will print from your printer with a series of arrows and numbers on it, with one set of solid bars above them. You should see four groups of lines, unless you have a single cartridge. If you have a single cartridge, you will only have one set of lines.
  10. In each group, locate the arrow that looks the most solid. It may help to circle the number under each arrow you choose as you go along.
  11. On your screen, you will see an area where you can enter the alignment values. When you have identified all the numbers, select those same numbers for each group on your screen, using the up and down arrows next to each value for A, B, C, and D (or A if you have only one cartridge).
  12. When all the numbers have been changed to reflect the chosen numbers on the printed alignment page, click OK. The cartridge installation procedure is complete.
  13. You can now exit from the Solution Center.
Thank you......
Jan 15, 2009 | Lexmark X3480 All-In-One Printer
I installed a new "genuine" Lexmark color ink cartridge, but it doesn't work.
then get it replaced by lexmark as the cartridges comes with one year warranty..
Apr 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
New cartridge won' t print.
Was the cartridges lexmark factory replacements or was they generic replacement cartridges.
If they are generic cartridges you might want to buy lexmark cartridges because some generic cartridges will not work in some printers
Mar 03, 2008 | Lexmark JetPrinter Z22 Color InkJet
Lexmark printer
Lexmark technical support should be able to help resolve this problem, assuming the cartridges were Lexmark branded. Contact information is on www.lexmark.com.
Feb 13, 2008 | Lexmark International Z611 Printer
Lexmark Optra T614 Laser Printer Logo
91 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
