Question about Sony EVI-D100 Webcam
Sony evi-d100 grinding
The servo motor that controls vertical movement grinds at a specific spot near just above the center (home) spot. Once it gets above or below this spot, it works fine.
5 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: SONY EVI-D100 constant blur which requires power off/power on
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 26, 2009
tbarratt
  • 96 Answers
SOURCE: i have a sony evi-d100 and i have the digital
well i have a few questions.
1st, does the evi-d100 work? can you confirm there is a pic by plugging it into your tv. sorry to have to ask the simple question.
if it is, what capture device are you using?
many capture devices are defaulted to confiugurations that you may not be aware of.
what capture application are you using?
the evi-d100 has an s-video and a composite out, whuich are you using?
the capture software will aloow you to change the source in a few different ways.
look for the configuration option in the capture program...
sometimes the conguration is defaulted to pal versu ntsc. sometimes the default is the composite and you mmay be using the s-video.
I'd start there or send me the answers i need and I can repond in more detail perhaps.
Posted on Feb 06, 2010
SOURCE: I am having trouble getting my Sony EVI-D100 to
click this link
https://www.servicesplus.sel.sony.com/sony-foc-software-tc.aspx?ln=0
Hope this helpfull
Posted on Jan 05, 2011
taran_2005
  • 10515 Answers
SOURCE: I have a EVI D100
I am sorry to hear regarding the trouble.
These webcams are really sensitive to power fluctuations. Unfortunately, there is no fuse in these cams.If you ever have a chance to dissemble these webcams, you would only find few wires round a small PCB board which control the function. However, the power board is not repairable and once burnt or at fault, new webcam is on the cards. I am sorry to be a bearer of bad news, as i am sure this is not what you want to hear. The only thing you could try is to re install the software to make sure it is not a software glitch.Sometimes, these might cause software to get corrupted unless replacement is on the cards. If this is under warranty, you could contact the seller and see if you could get it replaced / repaired without any charge.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 12, 2011
Connecting a EVI-D100 to a Macbook Pro Laptop Help.
Hi, I have a Sony EVI D100 that works. I have a Visca USB Cable and an s-Video cable and video cable. I will be connecting it to my MacBook Pro. What else do I need to use this Cam with my Mac to feed video to the mac? I also have a Mini Display Port To AV/CVBS/RCA/S-Video Converter Mac
Jul 29, 2012 | Sony EVI-D100 Webcam
Hello, I have a Sony EVI-D100 (ptz), I can connect the camera to my laptop, but only by the VISCA cable, used to control remotely the camera via PC, therefore I can control the camera but none video is...
Visca cable is only for camera control, it does not transmit video signal. You will need a USB video capture device and a s-video or composite video cable. Make sure the device you choose has the drivers for your version of Windows.
Feb 07, 2011 | Sony EVI-D100 Webcam
I have a sony evi-d100 and i have the digital converter connected to my computer, my laptop is recognizing that there is a camera, but it cannot get the feed. Is this a software problem? if so can u help...
Feb 06, 2010 | Sony EVI-D100 Webcam
How do I get my HP 5610 All-in-One Printer back online? Also, the display window on the printer is saying "Cartridge Error: Refer to device documentation to troubleshoot". When I looked into the owner's...
Try reinstalling the cartridge. Also listen carefully to the cartridge assembly movement. If you hear any grinding type noises your cartridge is reaching the proper home position. This will cause a cartridge error. If there is any grinding noise you may be in for a long task of realigning your cartridge position to its proper spot. Make sure that the position of the assembly is dead center when you reinstall the cartridge. If it is not move it the center as a starting point. Keep at this moving the assembly in either direction until you no longer hear grinding as the assembly attempts to find its home position. Good luck! Be patient. It may also help to completely unplug the printer for 30 seconds between adjustment attempts.
Nov 03, 2009 | HP Officejet 5610 All-In-One InkJet...
I have a EVI-D100 video camera.
You can special oeder those as they are one of a kind or you can find a camera for parts. Ether way check www.cables.com there you would search for the ribbon cables or give them a call. I do know those are special ordered.
Sep 29, 2009 | Sony EVI-D100 Webcam
I have a web cam but i dont know where to set it up on my sony laptop
You will have to experiment with it to determine where you get the picture you want.
Aug 15, 2009 | Sony EVI-D100 Webcam
Possible transmisson
motr coupling easy to turn??? did you look at closle ( sometimes appears intact, but the center of teh shaft is stripped allowing the motor to "slip" through giving what could amount to a stripped gear sound. the newest motor couplin (285753a) has a meatal sleeve to prevent such a thing from happening
Mar 20, 2009 | Whirlpool Washing Machines
Jan 02, 2009 | Sony EVI-D100 Webcam
Sony EVI-D100 Webcam Logo
43 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
