Should the drain pump cap just screw off for a bosch 900
  • Washing Mach... Master
  • 17,130 Answers
Click this link: Drain Pump
Posted on Jan 22, 2013
4 Suggested Answers
  • 9 Answers
SOURCE: Cant remove drain pump cap of bosch washing macine
I just replaced my drain pump on my BOSCH washing machine WFL2060-so almost identical to yours. When I posted my question, I was told that it was a pain to do, that many repairmen refuse to do it etc.... even that the front panel does not come off. Well, I am a fairly petite (by athletic) woman, and very far from being an expert at repairing anything....
I just did it in less than 45 minutes with a screw driver and a pair of pliers (and a bit of common sense). Here is the protocol:
1- UNPLUG your machine
2- drain any water that could be left inside (at the bottom front right, you will find a small door: open it, the filter and the small black hose are there)
3- . put an old blanket on the floor behind your machine and a piece of wood long enough to go across the width of your machine- place it half way to what will be the height of your machine once it lies down on the floor- this will save your fingers in case you loose grip of the machine while tilting it down on its back...
4- tilt your machine back and down on its back: use your thigh muscles as the machine si a bit heavy (if you have a friend help you that will be easier-but I did it alone...
5- remove the bottom front panel (2 screws)
6- above the filter access you will see 1 to 3 screws: take them off
7- from the bottom of your machine, take out the electric plug at the back of the pump's motor
8- using your pliers (and a good grip) loosen the metallic braces that hold the 2 hoses and slide them down along each of the hoses
9- the unit will come off into your hand.
10- replace the unit with the new one
11- screw the unit back
12 plug the wires back
13 reposition the hoses (you cannot go wrong, they are on wither side of the pump)
14- slide the braces back onto the hose+pump outlet
15- tilt your machine back
16- plug your machine
17- you are ready for your load!
AND... you have saved about $200 without the part (I ordered it, paid $49 and was delivered to me within 2 business days!)
Posted on Jul 27, 2009
  • 274 Answers
SOURCE: leaking drain pump
Yes its very semple takes about 20min.
Posted on Jul 05, 2010
  • 552 Answers
SOURCE: my bosch classix 1200 fl wont spin or drain
If the washer doesnt drain it will not spin, the link below had a video that explains how to clean the drain motor yourself.
http://www.appliancerepairlesson.com/2011/01/21/washer-not-draining-repair-bosch-maual-door-release/
Good luck with you're repair.
Posted on Mar 05, 2011
Error message F:21. Bosch
Take the kick panel off and see if there is a tray under it to catch leaks. If it has water in the tray, that is the problem.
Jun 18, 2013 | Washing Machines
Hi, My Bosch Logixx 8 is showing error F18 which I think means the filter is blocked. we have lost the manual so how do you get the filter out. Do we need to drain the machine first? Is there an online...
F18 is either the pump discharge is clogged or the machine is oversudsing. If it is oversudsing, make sure that you are using an HE detergent and use less detergent. (Make sure to note the minimum detergent line
To clean out the pump discharge, have a bucket ready for when you release the hose. First, set the cycle selector to Off and unplug the washer. Open the service door and remove it. Next loosen the screws and remove the protective foil. Remove the emptying hose from the holder and take off the cap. Drain the water from the hose. Replace the cap. Then carefully remove the pump cap and drain the rest of the water from the pump. Clean out any foreign objects from the area (housing, threads of the pump cap, etc). Make sure that the impeller can turn. Then replace the pump cap and tighten the screws (the handle should be vertical). Replace the emptying hose and the foil protector. Replace the service door and plug back in. Then fill the dispenser II with 1 liter of water and then start the Drain cycle. Let this water flow through to the pump.
The manual is available from Bosch. Go to http://www.bosch-home.com/us/WAS24460UC.html?source=search and click on Additional Documents . Then click on User Manual. This will redirect you to the correct page. Select your specific model and the language and click on the manual with the IU designation. The pictures to go with the clogged pump are on page 9 of the PDF.
The filters that can get blocked are in the water inlets. To clear those, turn off the water to the washer. Select a cycle and press Start/Pause. Wait 40 seconds then set the selector to Off. Unplug the washer. Then remove the inlet hoses. Clean and replace the filters at both sides of the hose. You will need pliers to remove the filters from the washing machine side. Then reconnect the hoses and check for leaks.
I hope this helps.
Jul 09, 2011 | Bosch Logixx WAS2446 Front Load Washer
Washer just stopped, won't do anything, door is locked and I cant get it open its a bosch 900 rpm front load.
you can use a wet dry shop vac and attach it to the end of the drain hose to remove any water this will also unlock the door the check the drain pump for anything that would be blocking the flow of water
take off the small front cover to the drain pump pull the whit plastic zip tie and this will unloock the door.
Apr 10, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Drain pump cap turns but will not pul out.
Make sure that you have unscrewed it as it will go anti-clockwise,
if you have, and it still will not come out, then there is probably stuck in the filter, and this will prevent it's removal
Try screwing it in, and then as you are unscrewing it, try to move the filter from side to side, keep doing this, and with a bit of luck it should come out.
At the worst, you may have to remove the complete pump, and clear it that way.
Mar 01, 2010 | Bosch Washing Machines
Jun 09, 2009 | Bosch WFL 2063 Front Load Washer
Bosch 1200 classic express washing machine wont spin
Providing the machine isn't requiring major breakdown repair, the problem should be solved by emptying the machine and cleaning the drain pump. If this is obstructed the maching won't drain or spin as any bits left in clothes (paper clips, coins, nails, screws etc) wedge themselves into the (what I call a fly wheel) the pump impeller wheel at the back. If the fly wheel can't rotate the machine cannot pump or spin.
So.........turn off the washing machine before you fiddle about with it. Then, at the bottom right-hand side at the front of the machine there's a drop down door. Take this down and take it off. Then, lower the drain hose from its holder and pull the hose out of its housing. Be very careful if you're doing this while you have very hot water in the machine. To be safe, let the water cool before starting. Next take off the closing cap from the hose and empty the water from the machine. There are times when the water doesn't empty by this method so carefully open the door to the machine and bale it out. If the water does come out via the hose, have a suitably sized bucket at the ready as up to 20litres can be drained. Once you've done this, put back the closing cap of the drain hose and returned the drain hose to its holder, unscrew (anti clockwise) the petrol tank cap look-a-like placing a towel underneath as a little residual water will flow out. The pump impeller (fly wheel) must be able to rotate so clean out any residual fluff from the thread of the pump cap and pump housing before returning the pump cover and screwing tightly on. Put back the drop down flap and, hopefully, away you'll go again.
Hope this is of some help.
Jun 04, 2009 | Bosch Washing Machines
Washing machine is not draining
Your drain pump is probably dead. Advice: do not believe anyone who tells you that it is a pain to replace on BOSCH! I just did it myself in less than 45 minutes and thereby saved about $200.
You need to order the part-> go to the BOSCH website and identify the exact model and part number for your machine. I ordered mine from www.appliancepartspros.com/Bosch-Parts.aspx.
The part arrived at my home this morning-it took 2 business days. I called to double check I had the right part and the CS person was very nice and helpful.
Then, beating the odds I did the following with just a pair of pliers and a screw driver:
1- unplug the washing machine (of course)
2- drain any water that could be left in it using the small black drain hose located behind the front bottom door (probably on the right)
3- lie your washing machine on its back-put a piece of wood long enough to cross the width of your machine and it will save your fingers- you will need some thigh and **** muscles as it is a little heavy (but I am a woman and did it without help)
4- remove the bottom front panel of your washer (2 screws)
5- remove the screw holding your pump (above the filter)
6- lying down on the floor, unplug the wires at the back of the pump"s motor
7- using your pliers loosen the braces that hold each of the 2 hoses, and slide them down along the hoses (easier this way)
8- take out the hoses- the pump will drop into your hand
9- place the new unit by screwing it to the front of the machine's casing
10- plug back the wires
11- reposition the hoses making sure that the braces are tightened around the hose + each of the 2 plastic tubes that stick from the pump
12- tilt your machine back up
13- plug your machine
14- you are ready for your first load adn have saved $200 :-)!
May 17, 2009 | Bosch WFL 2063 Front Load Washer
Bosch Maxx for Kids. Not draining, drained manually (little thin pipe at the bottom) then unscrewed larger screw-cap pipe and a wire from a bra came out, plus HALF of another one... When I try to either...
Sounds like a bra disintegrated and plugged the drain pump. Last time I had this happen, I had to take the machine apart, then the outlet pump and manually remove the clothing item. Most likely a service call for you.
Dec 19, 2017 | Bosch Washing Machines
Machine does not drain - same problem as Oct 8 2007 poster
pump cap screws out anticlockwise
if not been off it may have been screwed on too tight
if machine still has water in it you may have to get you machine out side other wise you are going to have a wet laundry
Oct 22, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
