Question about Xerox Phaser 8560DN Laser Printer
Xerox phaser 8560 prints blank pages
I thought it was a driver problem but even when you go the the physical printer and print a configuration page, it still shoots out a blank page. it will sometimes faintly show just a trace of ink but nothing like the original document.
obviously it's not out of ink and maintenance kits have been replaced. any other suggestions would be great. thanks.
  • 2 more comments
  • chris_huffma Jan 29, 2009
    how deep do i have to go to find the compressor hose?
    i didn't see it after opening the easy access doors.
    i checked the easy access doors but i haven't tore into it yet. i thought i'd wait and double check first.
    the hose seemed to be good but it went under the hot ink holding tank. so i gave up. i guess we will just have to order another printer.
  • ut_mwbaker Mar 12, 2009
    I have the same problem with the 8560 printing blank pages.. I think it might be because it is in a room that gets down into the upper 50s?? It happened once before and after running, and re-running the cleaning processes about 9 times it finally started working perfectly again.
    This time, however, it is still being stubborn.. and only printing a smear of yellow or magenta - if anything.
    Do the cooler temps make this thing completely useless?
    President:
  • 2,072 Answers
That's very weird, I have been thinking about your problem a lot.
What I am wondering is if somehow there is a piece of paper between the print head and drum, but that should be moved out of the way by the wiper blade assembly.
There is a compressor that creates the pressure to spray the ink onto the page. That could have failed, or one of the hoses disconnected.
The other thing is the print head itself. But if this was a sudden thing, it really isn't likely the print head jets failed all at once. That would be bizarre considering the amount of jets on that print head.
If there were an electrical problem with the print head, the machine would definitely give you a fault code, and if the print head was not going into the proper position you would no doubt get an 07,xxx.xxx code.
I have to conclude the compressor or a bad or somehow disconnected hose. The compressor is near the ( looking from the front) the right side , near the top rear of the machine, It is a black box and has a hose with a wire wrapping around it.
Posted on Jan 28, 2009
  • Rick Kasper Jan 29, 2009
    You will have to remove the right side cover, There is a screw in on the upper back of the cover and should be one inside front. The front output tray holds the covers together also, so you may have to pop the tabs on it.
    Once you remove the cover it is on the upper rear section of the machine frame.
  • Rick Kasper Jan 30, 2009
    Hey, if you are going to order another printer, Get one of the Phaser DRY INK not solid ink printers. They are 2400x2400 DPI and the toner has been developed where the particles align end to end instead of just random edges. I have worked on numerous color printers copiers and the color and sharpness of that color is amazing, It is actually magazing quality.
    I was nevre a fan of the solid ink printers and until the dry ink phasers have been introduced I was in no way shape or form a Phaser fan. But this new genration of Phaser products, no one, and I mean no one can even come close to the print quality.
    And I do HP, Cannon, Toshiba, Xerox. Just my 2 cents. But for reliability and cost please stay away from the solid ink technology. Although unique, the dry ink printers have now surpassed them in print wuality and 10 times more raliable.,
Printing from wrong tray
I suffered from the same problem for a long time. We got Xerox Phaser 8550 and 8560 here. I choose on computer "tray 2" but the printer just print from tray 1 which is empty.
Today i figured it out! It's some configuration at the printer. So go to "Paper tray setp" -> "Tray 1 mode" and "Tray 2 mode" -> change to "static".
I figure it's like this. Before it was "dynamic", it probably means the printer decides it's better to use tray 1 even though you choose tray 2 - and this decision is stupid. Changing it to "static" fixes this.
Let me know whether this works for you too!
Feb 12, 2010 | Xerox Phaser 8560MFP Laser Printer
My xerox phaser 8560 is printing muted color
First off on your screen access troubleshooting, and perform the remove light strips and also remove smears and skips.
Next go to Xerox.com, under support and drivers enter 8560 in the search box. then go to the support page.
You want to look up the procedures for TEC color correction. And follow those steps.
If you are using a generic ink then, all bets are off in getting true color reproduction.
Feb 10, 2010 | Xerox Phaser 8560DN Printer
I am trying to print a document in Word and my Phaser 8560 will print it, but there is a blank section on the page (approximately 4 inches wide running down the middle of the page) where the text did not...
Did the document print in full even though it left blank spaces? I f so the problem is The Page Break Occurred before it actually reached the end of the paper. Check what paper is selected on the printer. I don't mean the tray or paper feeder.
On the LCD screen on the printer go through the menu till you find the paper. Make sure the paper is set to A4 or Letter (whatever you normally use.) and make sure this setting matches with the paper select in the documenent.
Check File ->Print ->Settings or Options .... Find out where the paper is mentioned and select A4 or Letter as the case may be.
Hope this will solve your problem
Good luck
luciana44
Jan 06, 2010 | Xerox Phaser 8560N Laser Printer
Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Feb 13, 2009 | Xerox Phaser 8560DN Laser Printer
Problems with printer settings
Interesting. I tried printing a simple 3-page Excel spreadsheet sent my by a colleague to my 8500DN from Microsoft's Excel Viewer and got a timeout error formatted as follows:
ERROR: timeout
OFFENDING COMMAND: timeout
STACK:
42
-mark-
(84,160)
No idea what this means, but resetting the network parameters (even though I use USB connection) from the printer's front panel cleared the problem. The printer would print nothing else from any program until I performed this reset. Wonder if Excel futzes with settings and printing somehow?
Oct 14, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8560 Waste INk
Although I agree totally, the anwer is no. Althought it appears black, take a piece of it an use it like a crayon. It is a combination of all the color inks combined. So if you take and rub it on a piece of paper it will be a purple color. So threfore would not create proper colors.
Now to save ink, Do not turn the printer off at all. Just let it use its own sleep mode. The power consumption is intermittent to keep the print head warm and uses about the same ammount of electricity as your refridgerator light bulb. The reason being, when you turn off a solid ink printer, it purges the print head of ALL old ink and dumps it into the waste tray. That is part of those weird noises you hear when you cycle up the machine, one is a compressor emptying the print head.
Also, honestly, althogh I am not sure what you are using the machine for. But you would be wise to put that product on a pay per page maintenance agreement. That includes all ink and all service. Some of the parts for those printers are super expensive.
I will say one thing you can do with that waste ink, if you know anyone who has children, they can use them as purple crayons..
Feb 21, 2008 | Xerox Phaser 8560DN Laser Printer
Phaser 8560 won't communicate with me or my computer
What you can try is making sure the ink sticks are fully in the loaded position. They may be keeping that cover from closing totally.
The other thing is the actuator on that cover, may have briken off and is not properly actuating the sensor that tells the machine the cover is closed.
Make sure the ink is fully forward, and look at the covers for some area of beoken plastic.
Jan 12, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser  8560DN Laser Printer Logo
2,480 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
