Question about RCA RP-3765 Clock Radio
Alarm clock/radio Hi, I hope you can help me solve my problem. I have this alarm clock/dvd/radio and just today the display is not working, you can see all display on the screen and nothing changes when you push a certain function but I think everything is working, I tried the dvd, radio, everything is working fine, it's just that the display is not showing the function done. Thank you
Cut the power / batteries off and back on again to see if it will work, if not, go to www.easylifestyle.us to get a new one you need.
Posted on Jul 22, 2007
  • frdeinlein Jun 15, 2011
    This happened to me also. Cuttng off the power did not work. Tilting the radio backwards and viewing the display from the bottom shows a normal display. It appears the circuitry that controls the polarization the determines which LED segments are visible is not working.
SOURCE:
Set time on alarm clock nlc695 nelsonic
Hi Joe.
this is all i could find.
How to set Nelsonic alarm clock? Press and hold the ALARM BUTTON to enter ALARM SETTING MODE. While still holding the ALARM BUTTON down, press and hold the HOUR and MINUTE BUTTONS until you see the time you want on your LCD DISPLAY. Release the TIME BUTTON and the Alarm Clock Radio will return to NORMAL TIME MODE.
USER GUIDE Alarm Clock Radio - Jazwares
jazwares.com/assets/pdf/userguides/13500_wwe_alarm_clock_radio.pdf Search for: How to set Nelsonic alarm clock?
or go to this link might help you.
how to Set time on alarm clock nlc695 nelsonic Google Search
Nov 04, 2017 | Audio Players & Recorders
Alarm icon is displayed in the center of the screen no matter what I do. All alarms are turned off. I've rebooted the phone several times including removing the battery. What else can I do?
I've had this same weird problem today but I think that I may have solved it.
1. Go to "Menu"
2. Go to "Settings"
3. Go to "Display and Light"
4. Go to "Widget". Among your widgets is one called "Analog Clock". Un-check it and Save the widget screen.
5. Go out of the Menu to the top screen (that has "dial", "contacts" and "menu" at the bottom.) Hopefully, the alarm icon is gone. However, the "Analog Clock" that displays the time in the widgets (opened by the small arrow on the left side of the screen) is also gone. Simply go back through steps 1-4 to get to the "Widgets" screen and check the "Analog Clock". Your Analog Clock should display and the Alarm icon should still be gone.
I know that this solution doesn't seem to make much sense because what does an Analog Clock have to do with an Alarm icon? It just seems to be a software glitch of Samsung.
Try it out and see if it works.
Aug 14, 2010 | Samsung Solstice SGHa887
I have lost the instrucions and do not know how to operate the alarm. I never use the alarm but every night at 12pm the alarm goes off even if the radio is unplugged. Please help! Can I get the...
You can download the complete user manual by clicking this link
  • You'll require Adobe PDF Reader installed on your computer to view this manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Mar 03, 2010 | RCA RP5430 Clock Radio
Hi . My clock radio clock continuously displays
Likely a bad backup battery inside the clock, or a capacitor that is leaking a charge.
Nov 17, 2017 | Lenoxx Electronics CDR-190 Clock Radio
HI, my renault clio radio and clock display are dead
Hi All, the very same thing happened to me. Cold weather broke my radio and the display screen stayed on with the time and temperature but the radio wouldn't work. I rang Renault & they said I need to come in an get a new radio but I put it off. In the end the problem started affecting my battery and the car wouldn't start. But then when I jump started it, it also started the radio again perfectly. Problem solved!
Hope this helps. Good luck!
Jun 02, 2009 | 2004 Renault 181
I on the projector type clock only one alarm is workingneed to know how to set both alarms
[http://www.emersonradio.com/owners] Copy this web link and paste it into the address bar of your browser. It will take you to the Emerson customer support web page with all the Clock/Radios owners manuals on it. Just find you make and model number and open the pdf file of the owners manual.In the manual will be all the instructions to set the second alarm on your Clock/Radio. You can also use the print function on your computer to make a pdf copy for yourself. I hope this information helps you solve your problem with setting the second alarm.
Feb 26, 2009 | Emerson Smartset Clock Radio
TEAC SRL100 Set clock
The "set time" button on my SR-L100 is located inside the CD compartment. To set the time the unit needs to be in the standby mode. Press and hold the set time button until the time blinks, then use the tuning/clock adj. dial to set it. Hope this helps! Ted
May 26, 2008 | Teac SRL50 Clock Radio
Emerson research smartset cks2237
http://www.emersonradio.com/owners/SmartSet%20Series/CKS2237_073106.pdf Copy this link and paste it into the address bar of your browser. It will take you to the users manual for the model CKS2237 clock radio. On pages 7-10 you will find the instructions for setting the time for the clock. I hope this information helps you solve your problem.
Apr 29, 2008 | Emerson Smartset Clock Radio
Zenith Z212B CD clock radio
Have you done the presets on the memory. Do that then select the station you want to wake up to. Hopefully its fm. Per the instruction manuel . Set or adjust the alarm time if necessary. Press the Alarm on/off button if necessary until one of the alarm indicatior either the note or alarm appears on display when the buzzer alarm is selected. While the alarm time display is flashing press the tuner button to select am, fm, or tv band. The selected indicatior appears in the display ( Note : you can only select the band when you have selected wake to music. While the alarm time display is flashing press one of the preset buttons to select the station you wish to hear when the alarm goes off.
Apr 17, 2008 | Audio Players & Recorders
T307S How to deactivate the alarms
Timex T307S
I lost my manual also so had to resort to relentless trial and error.
The problem with the alarm is that it is too easy to turn it on.
The 1 and 2 buttons on top of the unit with the alarm clock symbol turn each alarm on or off. Your only cue is on the display in the top line of the display which will have a bell followed by “RADIO” or “SOUNDS”, if the alarm is armed. If you see this symbol and want to disarm the alarm, press the 1 or 2 alarm button according to which alarm was on the display. It’s just as easy to turn the alarm back on either deliberately or accidently
Enter Alarm Setting mode by holding the 1 or 2 alarm button for about 2 seconds.
Display will flash – in this mode you will be able to do the following
Date Set Button – changes between Everyday/Mon-Fri/Sat-Sun
Arrow Buttons – adjust the time setting
Alarm 1 (Radio):
Mode Button – changes between AM/FM1/FM2
1-6 Buttons -- changes between stations
Alarm 2 (Sounds):
Mode Button – changes between SD1/SD2/SD3/SD4/Buzzer
If you don’t change any settings for about 5 seconds the unit exits the alarm setting mode.
Timex already has your money so I guess they are not motivated to publish their manual.
Feb 08, 2008 | Timex (T307S) Clock Radio
RCA RP-3765 Clock Radio Logo
316 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
