Question about Bose FreeStyle TV Speakers
FREESTYLE CONTROLER NOT WORKING - Bose FreeStyle TV Speakers
Where is the hvac electronic control module located on a 2007 ford freestyle limited?
It's the part in the dash you use to adjust the temp. , turn on the A/C , select the vent's etc.. from . That is the HVAC control head (module)
Oct 23, 2017 | 2007 Ford Freestyle Limited
2005 ford freestyle vacuum diagrams
Transmission is all electronically controlled , no vacuum hose's to transmission .
Which trans does it have ? continuously variable transaxle (CVT)
or 6 speed automatic
This transaxle is a compact, lightweight, next generation electronically controlled, 6-speed automatic transaxle that employs a Ravigeneaux-type planetary gear.
Oct 12, 2016 | 2005 Ford Freestyle
Why does the fuse for the radio/power windows keep blowing on my 2005 ford freestyle
There is a short somewhere in the wiring to the devices supported by that fuse. Tis may be hard to track down, but I would start at the driver's window controls and wiring inside of that door.
Dec 04, 2014 | 2005 Ford Freestyle
My 2005 ford freestyle shuts off while driving....takes a few minutes to restart
This could be intermittent failure of the powertrain control module (PCM). Your vehicle should have a diagnostic check made to isolate the problem.
Sep 10, 2014 | 2005 Ford Freestyle
Location of ecu on a 2005 ford freestyle
Keep in mind the definitions:
* ECM = Electronic Control Module (prior 1995 computer, OBD1)
* PCM = Powertrain Control Module (1995 and newer, OBD2)
Ford Freestyle 2005 - Powertrain Control Module The PCM is located in the ine compartment, passenger side, mounted to the cowl. Removal & Installation procedure:
  1. Retrieve the module configuration.
  2. Remove the cowl panel grille.
  3. Disconnect the 3 PCM electrical connectors.
  4. Remove the bolt and the PCM.
To install:
  1. Installation is the reverse of removal.
Hope helps (rememnber rated this).
Jul 14, 2010 | 2005 Ford Freestyle
I have a 2007 Freestyle. The driver's seat heated
I am having exactly the same problem (also with 2007 Freestyle). The light comes on for a short time, and then goes off.
Dec 28, 2009 | 2006 Ford Freestyle
'05 Freestyle Heater/AC blower only works on high(4). How do I get at the switch or blower motor. Everything is plastic! Does anyone have a solution? Thanks, Bob.
here is what my book says:
Blower Motor Speed Control To Remove:
  1. Remove the right lower instrument panel insulator.
  2. Disconnect the electrical connector from the blower motor speed control.
  3. Remove the blower motor speed control mounting screws.
  4. Remove the blower motor speed control.
Jul 06, 2009 | 2005 Ford Freestyle
New car seat, quinny freestyle
what you need is a maxi cosy infant seat. these are the ones designed to fit quinny freestyle frames. you will also need attachment bars that you can easily buy on ebay for a coulpe of pound.
hope this helps
Mar 10, 2009 | Quinny Freestyle 4 Marina Stroller
Bose FreeStyle TV Speakers Logo
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
