Question about Yamaha HTR-5740 Receiver
Have no power to my receiver yamaha htr- 5740 . i have changed out fuses and still no power just a click.
  • 4 Answers
SOURCE: Programming manufacturing code
I tried to program the remote supplied with my Time Warner HD-DVR, only to discover that ... using the proper Yamaha code only allows you to turn the HTR-5740 off ... not ON!
I had to get the programmable version of the remote, and use its "learn" function to assign the "power on" function to an unused keystroke combination on the remote!
Posted on Dec 22, 2008
rteemon
  • 578 Answers
SOURCE: HTR-5740 Receiver Subwoofer Problem
as long as there is a speaker out from the receiver you should be ok just make sure polarity for spkr is right --remember you workng with AC current bad wire will cause fire==
Posted on Jun 26, 2009
smarthome2
  • 1114 Answers
SOURCE: HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
Grubhead
  • 5190 Answers
SOURCE: Yamaha receiver model HTR-5840 will not switch
By fuse OK you do mean the one inside it? If so check the power switch, then check the power transformer.
Posted on Mar 05, 2010
futurework
  • 70 Answers
SOURCE: I've had the same
Sounds like the unit is set to shutdown if it detects a short in the amplifier. The problem can be within the supply but it is most likely in the amp section of the unit. Transistors will go out over time and need to be replaced. Find a local repair shop and have them estimate the repair for you. the cost on something like this can be in the 70.00 range depending on shop rates in your area and the extent of the problem.
Posted on May 04, 2010
The htr-5740 will not always turn on both with the remote and using the panel on switch
One possibility is dirt in the switch. Clean it with contact cleaner ... but unplug it first!
Jun 18, 2014 | Yamaha HTR-5740 Receiver
Since our downstairs circuit tripped due to an oven heating element fault, my Yamaha HTR-5740 won't turn on. The unit was not on at the time and the power supply is working fine.
it is possible that the standby power supply circuit has become defective in the receiver...this power supply supplies power to the remote control and microprocessor even when the unit is off...this is so it can pickup the remote signal when needed...this supply consists of a small transformer and associated regulation components...it may be possible that the power surge sent when the element overheated n kicked the breaker that the small transformer may have an open primary..or it may just be a fuse for this supply...you can remove the cover of the unit and look at the small glass fuses...you may have to remove them to see if they are defective...remember to only remove them one by one as you do not want to put them back in the wrong place...if it's not a fuse..then more likely the transformer has opened up...you will need to have the unit serviced by a qualified service person
Jul 17, 2011 | Yamaha HTR-5740 Receiver
I need a dishnetwok remote code for my HTR-5740 YAMAHA reciever
my phone say that initial programming needed can you sold this for me
Nov 01, 2009 | Yamaha HTR-5740 Receiver
How do i hook up my xbox360 to my yamaha 5740
You can use Optical SPDIF cable. Both yamaha and xbox supports it. You can find cheap optical cables on ebay ($1-5 max.)
Sep 02, 2009 | Yamaha HTR-6130 Receiver
Jun 26, 2009 | Yamaha HTR-5740 Receiver
I need the remote code for the Yamaha HTR-5740 Surround Sound System. It is for the 3 in 1 Comcast Remote.
follow the comcast instructions, then enter 30176 when you are to enter the 5 digit code.
Feb 28, 2009 | Yamaha HTR-5740 Receiver
I'm trying to figure out the same thing, so if you ever figure it please let me know, I will do the same. thanks.
Jul 21, 2008 | Yamaha HTR-5740 Receiver
Yamaha HTR-5740 Receiver Logo
54 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
