Question about Avent Baby Care
Steriliser short circuit - Avent Baby Care
Get rid bad taste in water dispenser
Empty water, fill with fresh and then add a Milton sterilising tablet (or similar as used for sterilising baby bottles. Follow the instructions on the sterilising tablet pack.
DON'T run the water through the machine, but tip it out and rinse well.
Jan 27, 2014 | Sunbeam Coffee Makers & Espresso Machines
Our Haier HDC1804TW counter-top dishwasher does not complete the washing cycle. It stops after 90 minutes which should be 115 minutes for heavy washing according to the manual. The washing light is...
Since mine does the very same thing, it's my guess that is the sterilising cycle as by this point it has already washed, done a short fill to remove any remaining detergent, and two rinses. I'm also assuming the second short fill is just to cover the heating element and/or to to generate an amount of steam having being heated by the element (I'm basing that assumption on the heat of the dishes at the end of end of the cycle and the heat of the water when it drains)
Mar 05, 2011 | Haier HDC1804TW Dishwasher
Hi. I bought a Philips Avent Digital Steam Steriliser about 3 monts ago but it's not working now. No light on it, no function. Is there any tecnical service of Philips ın Cyprus for Philips...
first of all have you check the fuse in the plug
otherwise here is the contact details not sure if i have the country correct I put in greece/english but you can change at the top of page
http://www.support.philips.com/support/contact/contact_page.jsp;jsessionid=DB484F327F9A8A166463A0ED12878AC0.app107-drp1?userCountry=gr&userLanguage=en
Nov 01, 2010 | Avent Express 6 Bottle Steam Sterilizer
How do I clean my jetstream second stage
Why are you trying to clean it? if it leaking air try a good vigorous wash in fresh water. If it smells try using sterilising fluid such as milton.
Aug 28, 2010 | Poseidon Odin/Jetstream Regulator
Can you wash in cold water only
Yes , you can look into the program and find an easy economical quick wash which will has a fast wash with cold water, rinse and short drying cycle.
The normal/regular wash uses the heater as with warm water the dirt comes off well and is sterilised wheras in cold wash the average dirt might go off but not as clean as in a hot wash.
So you can use the programs as required for the clothes in question.
Aug 21, 2010 | Whirlpool AWM6120 Front Load Washer
3 months ago my wife used some blue dye in our washing machine. She cleaned the machine afterwards including a hot wash with bleach but every couple of weeks she get traces of blue dye appearing on...
Check filter, make sure there is no debris that has absorbed the dye, also check the outlet if i'st connected directly under the sink via a spigot, remove hose from spigot and unscrew spigot from joiner on sink plumbling to be sure it is completely clear. Run a 90 degree wash with a couple of mugs of baby sterilising fluid such as miltons (I buy shops own brand as it's much cheaper and just as effective). I run a maintenance wash in my w/m every 4 weeks with 1/2 mug sterilising fluid to remove bacteria build up and combat the stale smell it produces on all the low temp washes. You may want to consider running a periodic wash also, this will ensure the machine is squeaky clean and therefore will be more effective.
Hope this helps, good luck.
Jul 11, 2010 | Bosch Washing Machines
I wash the DW with finish DW cleaner.All items smell rotten eggs
Try running a wash with a couple of caps of baby sterilising fluid. If the d/w is connected directly to the sink, remove the spigot and check there aren't any blockages. I run a dishwasher cleaner thru my d/w every 3 months and every couple of week I will load the machine for a wash, add tab to dispenser and just after starting a 65 degree wash, I will open the door and tip in approx one capful of sterilising fluid.
Good luck
baby fluid also good as a sluice wash for your washing machine on 90 degrees (w/m empty, approx every 4 weeks).
Jul 08, 2010 | Bosch 24 in. SHV55M03GB Built-In...
My philips avent 1q24 electronic steam wont come on
Most likly a bad capacittor on the little circuit board inside the unit. As it is thermosealed you cant open it without voiding the warranty. The repair however is fairly simple and anyone with rudamentary electronics experience can fix it for you. If you are still having problems let me know on devar11@yahoo.com
Apr 11, 2010 | Philips Baby Care
Even the voloume level set high, audio out put is very low
cleaning your speaker with a steriliser/spirit pr changing it may assist
Aug 31, 2009 | Nokia 6233 Cellular Phone
Baby Care Logo
41 people viewed this question
Top Avent Baby Care Experts
ray gallant
Tom Chichester
masud
masud
Are you an Avent Baby Care Expert? Answer questions, earn points and help others
