Question about Samsung Televison & Video
Ah59-02334a lost all function to the tv eg. can not change chanel or volume. All functions still work to the surround sound.
SOURCE: the 'meteo' function doesn't work when I press the watch face.
This seems to ba a common problem. On mine both the Meteo and Altimeter stoped working. Apparently these watches have a fault with the water proofing and should not be worn in water!
Posted on Oct 23, 2007
SOURCE: Yamaha HTR 5740 no surround sound with DVD
I found that I needed to use fiber optic or digital Coaxel (sp?) to get it to work. The RCA didn't work for the sorround. Since I didn't have fiber optic on the DVD player I had to re-assign the coaxel plug to DVD. Do you know how to do that? Like you, by the way, it worked in my old home but couldn't get it to work in the new home.
Once I was able to plug in the digital coaxel cable in from the DVD player, it worked fine. If you have a fiber optic plug on the DVD player already you don't need to mess around we "re-assigning".
Posted on Dec 03, 2007
josh1856
  • 105 Answers
SOURCE: Jensen JR500 Remote Volume Control
Try reprogramming the codes into the TV for the volume control.
Jensen JR500 manual - If you cant get it to work using one of these codes it does not support your unit.
http://157.254.235.130/public/IBJ34500SE.pdf
or
http://157.254.235.130/public/J3_4_500_MANUAL_S_E.pdf
Hope that helps! DONT FORGET TO RATE ME on FIXYA!
Posted on Jan 30, 2008
  • 8 Answers
SOURCE: Most of the functions don't work
http://157.254.235.130/public/RCR860.pdf
http://157.254.235.130/public/RCR860_code_list.pdf
These are the Manual and The Codes List!!
Enjoy!!
Posted on May 29, 2008
mighty thor
  • 51 Answers
SOURCE: Magic-Sing EG-18000 works, no sound
look and see if the RF light is coming on, if it is not then the transmitter (mic) is not on the same frequency as the receiver.
Posted on Nov 24, 2008
Have no sound on my surround sound sony
Could be a number of things try each and test!
  1. Make sure the MUTE function has not been activated.
  2. Try turning up the volume level.
  3. Check that there are no headphones connected.
  4. Try setting the Audio/Video (A/V) receiver to a different Surround Sound mode. IMPORTANT: Verify that the source you are playing is encoded with Surround Sound audio. If not, the audio will be very difficult to hear using a Surround Sound setting. Set Surround Sound to OFF when playing a source that is not encoded with a Surround Sound signal.
  5. Check each speaker to make sure they are properly connected to the A/V receiver.
  6. Perform a Test Tone function to verify if the speakers are working correctly.
  7. Verify all external audio sources are securely connected to the appropriate inputs on the A/V receiver. NOTE: If the audio is being sent from a television to the A/V receiver, then it may be necessary to disable the internal speakers of the TV or set the audio output of the TV to FIXED or VARIABLE. If the audio output of the TV is set to VARIABLE, then you will need to increase the volume level of the TV.
  8. Make sure the correct audio input is selected on the A/V receiver.
  9. Confirm what type of HDMI devices are connected to the A/V receiver and then check the following:
    1. Test each one of the HDMI inputs on the A/V receiver to confirm that all of the inputs for the A/V receiver are working.
    2. Try a couple of different HDMI cables to verify there is not a bad set of cables.
    3. Unplug the video source from the A/V receiver and connect the source directly to the television. If there is still a problem with the audio, continue to the next step. If connecting the source to the TV corrects the sound issue, service will be needed on the A/V receiver.
  10. Verify the DEMO (demonstration) mode is not active.
  11. Change the ATT (attenuate) setting. NOTE: The procedure to change the ATT feature varies by model.
  12. Reset the A/V receiver back to factory specifications.
Dec 21, 2014 | Sony Audio Players & Recorders
Iv lost the remot for my nec cromavision flat tv and the child lock is stuck on
Just check an other code from the remote catelogue for NEC. Some codes might not work all the functions to TV.
Mar 30, 2012 | Televison & Video
I HAVE AN OLD (1987) RCA TV AND REMOTE, LATELY THE ROMOTE TURNS THE TV ON BUT DOES NOT CHANGE CHANELS OR VOLUME IT WORKS ON OTHER TV
pls check "LOCK key "function is on reset on remot lock key off then remot is working normally
Oct 28, 2009 | Televison & Video
Setup correct but operations not so well (urc-3445)
Universal remote controls may not have codes for all functions of a device.
May 25, 2017 | One For All URC-3445 Remote Control
Volume on surround sound speakers not working. Sound coming out of speakers but volume when turned to maximum is very low. Please help.
Most receivers you can adjust the different chanel levels. If you refer to the manual on adjusting chanel volumes in surround sound mode.
May 26, 2008 | Audio Players & Recorders
Have a philips tv and a home theatre system but the remote off the surround system just changes the tv settings. Its kind of frustrating when I want to watch a dvd! Do I have to assign a freq?
When you press a function key on the remote control, not only does it change the function on the system (eg DISC, TUNER, TV etc) but it also changes the function on the remote.
However, if you change the function or source on the system, then only the system changes.
It sounds like you have changed the function on the system to DVD, but the remote is still set to TV. When in TV mode the remote will send Philips TV codes.
Press the DVD or DISC button on the remote.
May 10, 2008 | Televison & Video
No Remote - Need to access Menu
We had the same problem - this worked for us:
1. Unplug TV
2. Press Channel up and Volume up at same time, while plugging TV back in (two person job - it will pull up a service screen)
3. Press Channel up and Chanel down at same time. (Access to menu screen)
4. Use Volume up and Volume down to switch between menu options. We finally found the EZ set up screen.
Somehow in the process we muted the TV and are now working on getting the sound back. :)
Good luck to you!
Apr 28, 2008 | Sharp 25N-M100 25" TV
Righ & Left Front speakers not functioning
SOUNDS LIKE HE HIT YOUR SPEAKER CHANELS 1 OR 2,,, PUSH 1
Mar 15, 2008 | Onkyo TX-SV545 Receiver
Exiting service mode (i think)
if you have pp button on remote press it.or try with main sitch
Jan 25, 2008 | Haier HTF24R21 24" TV
Televison & Video Logo
88 people viewed this question
Henry  Thomas
Henry Thomas
