Question about Visioneer OneTouch 8920 Flatbed Scanner
I've been using this scanner for over a year For some reason, it keeps telling me that scanner is not connected I checked and it's both connected to the USB port and the wall
  • Roberta Smith
    Roberta Smith May 11, 2010
    unplug the usb and plug it back in... that may fix the issue
    President:
  • 2,692 Answers
Scanner keeps shutting off
Is it a 528 ? Mines doing the same thing ,,,can't figure it out
Feb 27, 2013 | Radio Shack Radio Communications
Won't Scan -- "Cannot properly communicate with the scanner"
I think the USB cable is defective or the scanner is failing.
Apr 25, 2017 | Epson Gt-15000 A3 Flatbed Scanner Eu-45
Scanner is disconnected or Turned off.
Try going to manufactures web site and downloading drivers for the printer from there. Also you might check your device manager to see if the unit is being recognized by your computer. it should show up iunder USB or Printers. I had an Epson that did the same thing but mine was a wireless and I had to re-establish coneection and go through setup again to have my IP address recognized. Most of the time plug n play will pick up the new device.
You might also try running security and windows updates on your computer, there might be an update that is keeping the computer from recognising the printer anymore.
Its just a start of what could be going on, hope its an easy fix.
May 29, 2012 | Canon PIXMA MP495 InkJet Printer
I have installed HP PHoto and Imaging Softward for ScanJet 3570c 48 bit. Everytime I try to click on icons on the scanner, my computer shows an error message that there is a problem with connecting to the...
Does the same error occur if you launch a scan from the computer? What OS do you have? Vista only has a basic driver available and does not support the scanner buttons. (You can launch the scans from a number of options: third-party software, Windows Fax and Scan (new scan), Microsoft Paint (File > Import from Scanner or Camera > New Scan) and Windows Photo Gallery.)
If the error occurs when you launch the scan from the computer, try a new data cable and different USB ports. Try a direct USB connection if you use a hub. Then check your USB ports and the drivers for the USB. (For Windows, look in the Device Manager. Start > Control Panel > System > Device Manager (exact directions will depend on the OS).
The HP Photo and Imaging software requires you to set the default scan destinations in the software before you can use the buttons on the scanner (for those OS/driver versions that support the feature). Always open the software and scan from the computer to see what the defaults will be. Each version of HP's imaging software set up these buttons differently; the help option is useful. Try Scan > Scan settings to find where to set the color and black & white destinations.
I hope this helps. If you add a comment with your OS and whether the computer can launch a scan, I'll provide additional help if I can.
(who inherited a scanner when a USB hub failure aggravated the original user into buying a new scanner thinking it was a scanner problem.)
Aug 12, 2011 | HP ScanJet 3570C Flatbed Scanner
Canon MP495 Pixma scanner says this when I try to scan something. Cannot comunicate with scanner for these reasons: -Scanner is turned off -Scanner is disconnected (It is disconnected from LAN, if...
Regarding the Cannon scanner error 2145,50. The MG5220 does this also. The actual problem is that the scanner will not communicate with the computer correctly if it is connected through a USB hub. A direct connection to the computer cures it, for me at least.
I know, I had that problem. I am a retired electronics design engineer.
Jun 30, 2011 | Office Equipment & Supplies
Hi. So my family has an HP Photosmart C4280 printer/copier/scanner which we have had for a few years. It is connected to our Windows XP. It has always worked up until lately. The printer and copier work...
No its not like that , There must be some software issue, the other thing can be that you must have attached new USB devices because of which the scanner is not getting as much as power needed from USB and hence telling that its not connected.. Try to remove all the USB devices and keep only All in One attached and then try to scan.
You can also try to scan from Scanner and camera wizard
You can find it under
Control Panel >Scanner and Cameras (If its in classic view)
Control Panel >> Printer and other hardware > Scanner and Cameras (If its in category view)
Please let me know if it does not fix the problem then we will go through extensive troubleshooting
Feb 27, 2011 | Office Equipment & Supplies
I have an older obd 2 code reader and I keep getting a check connection when I try to read codes on my 2008 gmc truck.
I'd say that means that the scanner won't work on your model year GMC.
So it keeps telling you to check the connection, because it knows something is connected, but does not recognize it.
May 15, 2010 | Measuring Tools & Sensors
Laptop doesn't recognize. but its red light is on and if i try to scan, it beeps, but no data is input into the computer
dear sir
if you are using some kind of converters or terminators please do replace it or try to connect the device directly to the computer
thank you
Sep 22, 2009 | HHP IT3800 Handheld
Mustek Scanexpress A3 USB scanner stopped working
my scanmagic 1200ub is recognized by my pc but i keep getting a message saying"cannot locate component.could it be that particular port?
Mar 29, 2009 | Mustek A3 USB Flatbed Scanner
Visioneer OneTouch 8920 Flatbed Scanner Logo
55 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Jeff Hogancamp
Jeff Hogancamp
Cosma Papouis
Cosma Papouis
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
