Question about Sanyo DVW-5000 DVD Player/VCR
DVD player I was using the setup function to set my speaker distance on my dvd/vcr home theater system and pushed the progressive scan button to see what that did. Now I have a blue screen on the TV that says "progressive scan mode" and it wont go away. I need to see the setup screen so I can go back to normal mode but I cant. How do I grt rid of Progressive scan mode screen. We cant view any movies either we can hear them but only see the blue screen.
  • Diane Richardson Jul 23, 2007
    I called Sanyo for the solution. First ... there is no progressive scan button to push so that wouldnt work. But thanks for your suggestion. :) Here is what worked. Hold down the stop button 3 times on the front of the system, on the 3rd time hold it for 10 seconds. Ta Da! Blue screen gone!!!!
  • Nora Harvey Dec 29, 2018
    I tried both of those stop button solutions but neither worked. My screen says no signal but if I switch to VCR side it has a signal. The progressive light is on and it won't go off. My two yr old did this by pushing buttons on front of DVD player, seems like it could be fixed.
Unplug it and plug it back in and press the progressive button to turn it off, should work. Yeah that blue screen sucks, i would have thought you can get to the menu no matter what but that's sanyo for you, well most other brands also...
Posted on Jul 23, 2007
6ya staff
SOURCE:
Toshiba SD-V55HT stuck in Progressive scan mode.
Hello
Progressive Scan Video provides the highest resolution
pictures with less flicker and line structure
If you are using the COMPONENT/PROGRESSIVE
SCAN VIDEO OUT jacks, but are connecting the
DVD/VCR Receiver to a standard (analog) television,
set Progressive Scan to Off
If you are using the Component Video jacks for
connection to a TV or monitor that is compatible with a
progressive scan signal, set Progressive Scan to On.
To ON and OFF this function, Press "Setup" to display the setup screen.
Surf through, and hilight "Progressive scan" and press "Ok or Enter"
Here you can set this function ON or OFF. If you wnat to get it OFF, select OFF and press Enter.
OK.
Jun 25, 2011 | Toshiba SD-V55HT DVD/VHS Home Theater...
Why do my tv screen appears in three sections when i put a dvd disc? it appears normal when i put a vcd!
hi,
check is your tv supports progressive scan, if not switch off the progressive scan mode on your sony home theater system.
For switching off the progressive scan mode do the following in ur home theater's remote.
Do this setting if your connected the component video
1. Press the FUNCTION BUTTON on the remote.
2.Press the VIDEO FORMATE button to select interlace scanning.
If you are connected the HDMI then do the following setting
2.Press the VIDEO FORMATE button to select the resolution
Select 720 * 480p
Jan 17, 2011 | Sony BRAVIA DAV-HDX267W Theater System...
Someone gave me this system without a remote. When I turn up the volume, my TV and the system echo each other. What can I do?
It's customary to mute the TV speakers if you're using external, presumably better, speakers. The best TV-related audio would be obtained not from the TV but from the original source you're watching - CD/Cable/DVD/BluRay/Game.
If you have the manual you might also want to see the settings for speaker distance from the listening position as that can cause an indistinct sound image if grossly incorrect.
Dec 09, 2010 | Progressive Computer JSI 6 spkr. Home...
I cannot get video picture,But ican hear all audio functions.
put a disc in the player and once it starts to play press stop, then press and hold the stop button for 5 seconds this will turn off the progressive scan feature.
Apr 26, 2009 | Zenith DVT412 System
Progressive scan turned on - how do you turn it off?
I'm not very familiar with this namebrand on electronics, but they are all the same anyways.To check if this function is on, usually the player's lcd screen would have a "P", "PROGRESSIVE" or "P-SCAN" on it. First, make sure you remove all dvd's or cd's from the player, then look for a button on the remote, or the unit itself that say's "P-SCAN", "PROGRESSIVE" or "RESOLUTION", once you find it, push it, sometimes they would indicate the resolution on the player's lcd screen (480i, 480p,720p,1080i, 1080p), if not, on the tv itself. The resolution you are looking for is 480i for the type of cables you are using (composite RCA). Give it a try, and let me know how it goes...
Jun 09, 2008 | kawasaki 5-DVD Home Theater System - 1152...
Showing red image
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Jan 08, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Question on setup
If you set Progressive Scan to
ON in error, you must reset the DVD/VCR. First,
remove the disc in the DVD/VCR. Next, press STOP
and hold it for 5 seconds before releasing it.
Oct 18, 2007 | Sanyo DVW-7000 DVD Player/VCR
Static/White Noise
Scroll down to the speaker set option. activate it then push the > button. You will see the test below the speaker diagram.
Feb 08, 2007 | Zenith XBS344 System
Sanyo DVW-5000 DVD Player/VCR Logo
246 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
