Question about Cisco 7940 IP Phone
Cisco ip phone 7940 does not ring for incoming calls.
The phone displays DND. I do not know how to get rid of it, nor do I kno how to turn it on. So the phone does not ring for incoming calls.
  • abrown112281 Feb 04, 2009
    cant dial out, number dosen't show, dnd is on the phone, no dial tone
It sounds like you have enabled Do No Disturb accidently. This can be turned on and off by pressing the DND softkey button along the bottom of the LCD display. You might need to press the 'more' softkey to display all options.
Posted on Sep 24, 2009
I have the same problem on my 7940. The phone won't ring for incoming calls and there is a DND symbol at the bottom. However, there is no soft key to turn it off? Any ideas?
Posted on Oct 09, 2009
My phone DND turns on the DND, but won't turn off. However, if I dial my number from the phone, wait for the voicemail, and then transfer that call to my number, DND will finally cancel.
Posted on Apr 01, 2010
  • 48 Answers
Your Cisco phone can't dial out? Use IdacomUSA for all of your Cisco Repair and Refurbishing needs! For more info, please check out our website
http://idacomusa.com
Posted on Feb 18, 2009
  • Ryan Paterson
    Ryan Paterson May 13, 2009
    I suppose I wasn't very clear with this one. Your problem is because of corrupted firmware. A factory reset or an updated firmware will fix your phones. You can call me if you have any questions...
    1-800-903-9190
My Cisco SPA502G does not ring for incoming calls
It is a problem with the router. if you assign it a public ip adress it will stay on line the other option is a router that will allow consistent nat translation
May 12, 2014 | Cisco SPA502G IP Phone
How do i get my cisco 7940 working in my home
You would need either a call manager or call manager express to configure the phone and connect to the phone line.
Sep 06, 2010 | Cisco 7940 IP Phone
Phone display shows DND is active however phone still rings. How do we remove the notice?
Using the soft buttons at the bottom of the display, click the last button on the right (More). This will provide another set of options. The third option from the left should say "DND". Press the soft button below this option to turn off DND.
Aug 17, 2010 | Cisco 7940 IP Phone
One of the remote branch is having a problem that they are not able to hear the ring when there is an incoming call. What might be the cause for that and how to resolve the same??? pls help??
OK I am gonna throw an idea at you. Give more details...
I would guess that depending on your configuration your phones are unable to load whatever ring type you called for at the current location. example: I pre load the phone at site "a" with ringtype 1, but ring type 1 file does not exist on current branch server.. just some thoughts... let me know if this can help.
Jul 09, 2010 | Cisco 7940 IP Phone
'in call' volume cisco 7940
The handsets will eventually go bad. If it is every single handset that you have, the problem is with the system. But if the problem is only with a few of your phones, you might consider replacing the handsets. We at IdacomUSA.com have replacement Cisco handsets for sale at only $25. Hope this helps you out :)
1-800-903-9190
Mar 04, 2009 | Cisco 7940 IP Phone
My Cisco ip Phone 7940 will not ring.
Give me your number, and i'll call you! Solved! =-D
Jan 27, 2009 | Cisco 7940 IP Phone
Cannot program Speed Dial
Try adding Cisco 7914 (time two) for additional (other) phone lines, or define caller group so phone call rings around.
Jan 17, 2009 | Cisco 7940 IP Phone
Can't remove DND off display
press the [world] setting button, then choose settings
choose call preferences.
change DO Not Disturb to NO
press save (middle button)
press back
press exit
johanvt
Jul 28, 2008 | Cisco 7912G IP Phone
Cisco 7940 call conferencing
No most system are maxed on the phone ... but if you had a panasonic system they are know for multi conferencing.
Apr 08, 2008 | Cisco 7940 IP Phone
Open Questions:
See all Cisco 7940 IP Phone Questions
Cisco 7940 IP Phone Logo
8,330 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
