Dell Optiplex 754 Battery - Computers & Internet
Replace cmos battery of optiplex 740
hello
Here is how the cmos battery looks like(look at video) at 2:15 running time of video shows you the cmos battery that is simular to a big watch battery. here a link for battery
http://www.ebay.com/itm/Dell-OptiPlex-Desktop-New-Motherboard-Lithium-Battery-Bios-CMOS-3V-Clock-CR-2032-/200692910229?pt=LH_DefaultDomain_0&hash=item2eba3ac895
Feb 22, 2013 | Dell OptiPlex 740 PC Desktop
Were do the jumpers go on a optiplex 330
There is the Password jumper (PSWD), and the CMOS jumper.
The CMOS battery is also termed the RTC battery.
Real Time Clock battery.
The CMOS jumper is labeled as RTCRST.
Real Time Clock ReSeT.
Jumper pin location is confusing if you go with Dell documentation.
http://support.dell.com/support/edocs/systems/op330/en/ug/mtparts.htm#wp1607303
Dell Support documentation shows the RTCRST jumper pins near the Intel chipset, and PSWD jumper pins near the outside edge of the motherboard.
I'm also looking at the Dell Optiplex 330, Technical Guidebook, Inside the Optiplex 330,
http://www.dell.com/downloads/global/products/optix/en/optix_330_techspecs.pdf
Location of RTCRST jumper pins, is near the left corner of the Intel chipset, instead of the right as shown above, and PSWD jumper pins are in the same location.
And several views of Optiplex 330 motherboard's on Ebay,
http://www.ebay.com/itm/Dell-Optiplex-330-Motherboard-Socket-775-KP561-/140870576837?pt=Motherboards&hash=item20cc8a6ac5
(Nice to have that Zoom in feature on Ebay now)
Jumper pins close to the white SATA 2 connector, are the RTCRST jumper pins.
Jumper pins at the bottom side of the Intel chipset are the PSWD jumper pins.
Jumper cap stays on PSWD jumper pins.
No jumper cap on the RTCRST jumper pins.
http://en.community.dell.com/support-forums/desktop/f/3514/p/18683374/18806360.aspx
Regards,
joecoolvette
Oct 23, 2012 | Intel Motherboard
Fitted new battery still says voltage is low
If its still showing low battery,then recheck that you inserted proper new battery.If you have any more spare battery try that too.But if its still showing same battery low message,then click the link below :----http://technoanswers.blogspot.com/2012/01/low-batery-message-on-dell-optiplex.html
-------This will help.Thanks.
Jan 27, 2012 | Dell OptiPlex SX270 PC Desktop
Where can I buy a new battery for Dell Optiplex GX270? (I brought it second hand from my last employer. At the front it says Optiplex GX270 it does look like a other ones on ebay, but the sticker on the...
I am guessing you mean the motherboard CMOS battery.
Here is one place
http://www.cellularfactory.com/wholesale/computer/DELL/4/43460/623191/
Replacing the battery
http://www.dicom-info.com/dicom/dell-pc/GX270-Users-Guide/battery.htm
Feb 14, 2011 | Dell OptiPlex GX270 PC Desktop
OptiPlex GX110 PC Desktop: Hello.. I'm having Dell Optiplex machine.When I t...
Generally an indication that the Hard Drive isn't detected
Things to check, go to BIOS F2, reset defaults and reboot, see if the HDD is seen. If it is, the battery on the motherboard is likely dead and needs replacement (Watch battery at Walmart, 3 dollars)
If the HDD doesn't detect after resetting the BIOS, then most likely a Hard Drive failure
May 18, 2010 | Dell OptiPlex GX110 PC Desktop
What type of CMOS battery do I need for Optiplex SX270
CR2032 battery, located on the motherboard here,
http://support.dell.com/support/edocs/systems/opsx270/en/ug/battery.htm#1095363
Jan 05, 2010 | Dell OptiPlex SX270 PC Desktop
My dell optiplex gx200 bios can't boot
maybe try taking out the cmos battery located in your case, looks like a small watch battery, that will clear bios settings and start from scratch, if there is no battery then there is a jumper sequence to do this
Feb 17, 2009 | Dell OptiPlex GX200 PC Desktop
What is bios password for entry to setup mainboard dell optiplex 170L
Take the battery out and find the jumper or just leave battery out for a while (30 minutes) Pass word will no longer be stored.
Jan 13, 2009 | Dell OptiPlex 170L PC Desktop
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
