Green TV Screen
When I turn on my TV, the screen is green. I can move the channel but the screen is stil green. Could you please help me ? Thanks a lot
  • 2 more comments
  • mzafimehy Jan 30, 2009
    It's a Philipps TV. I bought it in 1999. I don't know the model. I'll find it. Thanks
  • mzafimehy Feb 06, 2009
    The band of the TV is Philips. I don't know the modèle.
  • micromaster
    micromaster May 11, 2010
    May i know what exactly the model that you have..?
    Also, since when you experience this problem..?
    Thanks
  • micromaster
    hi there,
    may i know the exact model of your TV??
    Brigadier General:
  • 3,614 Answers
Thanks
Posted on Jan 30, 2009
Blue red and green screen
I too have this problem and am unable to find a solution. Someone please post a fix for this issue if possible??????
Jun 30, 2012 | Sylvania LD320SSX LCD TV
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
My plasma tv have a lots of green in the picture
This can be either the z-sustain board or the digital board. I would have it evaluated by a service company.
Oct 29, 2009 | Daewoo DSP4210GM 42 in. Plasma Television
The TV is only two months old.. There are green spots everywhere
Hello, The LCD screen is going bad. The green spots are where the LCD junction is not being activated by the voltage. This usually happens when the screen is begining to malfunction. Also I would check the connectors between the screen and the screen driver board. I hope this helps Thank you, Shuttle83 http://www.electron-age-tecgnologies-llc.com
Jun 12, 2009 | Samsung LN46B530 LCD TV
MOVED TV NOW NO PIC JUST RED BLUE GREEN ON TOP HALF OF SCREEN
Try re-soldering convergence IC pins first, they might get loose when you moved the TV.
May 27, 2009 | Panasonic PT-61HX40 61" Rear Projection...
TV KOLIN 21"
hello.... do you have any speakers near your television? what color is the circle your talking about? Do the green,pink colors are scattered all over the screen and specially on the corners?
If you have or had speakers near your tv? then do this try to get a magnet.a magnet on a speaker would do.what you have to do is to place the magnet near the screen of the tv approx. above the green,pink color (turn it on first).you will notice the that the color will react with the magnet try to pull it on the side you will notice that the green,pink color is moving on the same direction do it until its gone.NOTE make sure youll not scratch the screen ok.email me what happened. jaredreyesbalderama@yahoo.com GOODLUCK
Jan 21, 2009 | RCA 20F512T 20" TV
Green Screen - LG 42PX5D
hello, seems to be panel trouble, plasma and lcd main panels are not fixable, the color green isnt a good sign or it is a symptom of the panel being bad,
i know its a bad diagnosis but this is true with this color on a panel.
if it is a worth while set and you want to restore it theres few options one is replacement trough your waranty
the another is having the screen replaced by a service center this is to costly and rarely done by them they would advise you to get another set. at a retail price a screen replacement is as much or even more than the tv itself.
finally you may search online listings for a servicable tv same model and exchange the parts .
the third option is the best if your waranty is expired.
good luck hope this helps
happy holidays.
Dec 27, 2008 | LG 42PX5D 42 in. Plasma HDTV
Wharfedale 37 inch lcd tv
sounds like screen control is set too high
Sep 02, 2007 | Televison & Video
Color Turns Green
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
May 13, 2007 | Sharp 27H-S60 TV
Some part of TV has been fused causing no picture on screen , only bright green horizontal lines , not even video channel could be set ,cannot see menu on screen please help by specifying possible...
if the screen is real bright green with thin small white lines in it its probably a shorted picture tube. Or a shorted Green driver Transistor. Good Luck
Apr 12, 2006 | Thomson 14MG135 14" TV
Televison & Video Logo
231 people viewed this question
Top Televison & Video Experts
Electro Med Services...
