Error code 420 panafax uf-5600
Error code 420
5 Suggested Answers
  • 31 Answers
SOURCE: Panafax UF S2 Memory Full
turn off your unit for 3 minutes. plug it again
if nothing happens, contact your nearest panasonic service center
Posted on Mar 11, 2008
  • 82 Answers
SOURCE: Pnafax UF-322
do you get the error code immeditely after turning it on or shortly after on
Thank You,
Mikey
Posted on Apr 05, 2008
  • 134 Answers
SOURCE: panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Posted on Jun 14, 2008
leroyal
  • 2120 Answers
SOURCE: Replacing the LCD battery on a Panafax UF-885
Open up the document feeder by pulling straight up.
You will see a white tab sticking out of the black base.
Push FIRMLY towards the rear with your thumb.
The battery is a CR-2032 as printed on it.
Posted on Feb 02, 2009
Error Code 720 on Panafax UF-9000
error 720 means unable to connect to the POP server.. incorrect POP server ID or POP server is down
Apr 24, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Mar 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error Code i can't fix
The main drive motor is stalled or not turning.
Pull out the toner cart and see if it runs.
Mar 17, 2009 | Panasonic Panafax UF-990 Plain Paper Laser...
Fax can not be send and received
press the monitor key...you should hear a dial-tone...if not try below.
Check the phone line with a regular phone plugged into the wall jack.
Mar 11, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Panasonic Panafax UF-550 not receivng faxes
Check your line for static, should sound a clear tone. 95% of communication problems are related to line quality (phone company fix this). The other 5% is the modem PCB of the fax machine
Feb 12, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Panafax uf-s10
error 406 means you or the person your trying to fax has a password on the machine so you need to looking at that.,
Sep 05, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
PANAFAX UF-6000
error code 634 means that you have reached your limit of redials
Jul 29, 2008 | Panasonic PANAFAX UF-6000 Fax
Pnafax UF-322
Thank You,
Mikey
Apr 03, 2008 | Panasonic Panafax UF-333 Plain Paper...
485 people viewed this question
k24674
jasbo
jasbo
