Question about Hotpoint Dryers
My hotpoint ctd 40 wont heat up
My hotpoint ctd 40 dryer is goin but isnt dryin the chlothes and the lights next to the delayed time and high heat are flashing and also my on/off button
    Sergeant:
  • 250 Answers
Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Posted on Jan 27, 2009
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
Hotpoint dryer ctd40
hi the problem you are having is more than likely going to be associated with the pcb board failing this controls the heating element and the temp sensor you will probably find a bad solder or failing component on the pcb side of the board these can be replaced but you need to work out the age of the drier compared to what else might go wrong let me know ok
Feb 11, 2008 | Dryers
Hotpoint Tumble Dryer CTD40G At the end of a cycle the on/off light was flashing plus Time Delay and High Heat lights were illuminated. The drum rotates but the clothes remained wet. There is no obvious...
that isn't a good model number open the door,look around the opening where you put the clothes in and you'll see the model number,you could have a bad thermal fuse or another t-stat is bad,you have to get in there with a meter and check out the parts for continuity
Dec 16, 2017 | Hotpoint Dryers
Not heating up
first thing to check is the heating coils,,if ok go to the censor just over the top of the door,,,this is most likely the dud part
Jul 10, 2010 | Hotpoint Dryers
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
Hotpoint CTD 40
Thermostats do not have a reset
IF the dryer has failed by overheating, the device is called a thermal fuse, it is a one-shot protector, and needs to be replaced.
If the thermal fuse has blown the dryer is likely {expletive deleted} with lint and needs to be cleaned.
STILL require make and model details for replacement instructions
Oct 08, 2008 | Dryers
Help
stats come as a kit and often go faulty. if you are in uk, try currys masterpart
Aug 07, 2008 | Dryers
Hotpoint ctd 40 is not heating up. It goes through a normal cycle for about an hour without heating despite selecting the high heat setting. After about an hour the lights of time delay, high heat and the...
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
http://www.repairclinic.com/0088_8_1.asp
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 04, 2008 | Dryers
Hotpoint t/d ctd40
my dryer doesn,t heat up & after a while the time delay,high heat & on off button flash.
Feb 11, 2008 | Hotpoint TDL14 Electric Dryer
Dryers Logo
190 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
