Question about Microsoft Visual Basic 6.0 for PC
Opening pdf or html file using common dialog control
How can we open a pdf file or a html file using common dialog control or using a command button
Sir how can i solve this
Posted on Jan 29, 2009
Adobe Acrobat Pro 9.x not displaying some PDFs correctly
You can use the following steps to prevent PDF file from being corrupted...
1. Click Add file button to add a file.
2. Select PDF file from the dialog box
3. In the Add file dialog box, click Advanced button.
4. Set File Type to Binary in the combo box.
Also if this guide can't help you, look at next resources...
http://www.filerepairforum.com/forum/adobe/adobe-aa/pdf/1409-corrupted-adobe-pdf-files - in case you can't restore your .pdf file manually
https://www.repairtoolbox.com/pdfrepair.html PDF Repair Toolbox - alternative solution with free demo version
http://www.instructables.com/answers/How-to-repair-corrupted-PDF-files/ - where you see similar trouble and offers for struggling with it
May 24, 2015 | Adobe Acrobat Computers & Internet
Tip
Windows xp keyboard tips
and also
and
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Mouse click/keyboard modifier combinations for shell objects
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
General keyboard-only commands
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Shell objects and general folder/Windows Explorer shortcuts
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
To copy a file
Press and hold down the CTRL key while you drag the file to another folder.
To create a shortcut
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
General folder/shortcut control
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
Windows Explorer tree control
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
Properties control
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Accessibility shortcuts
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Microsoft Natural Keyboard keys
  • Windows Logo: Start menu
  • Windows Logo+R: Run dialog box
  • Windows Logo+M: Minimize all
  • SHIFT+Windows Logo+M: Undo minimize all
  • Windows Logo+F1: Help
  • Windows Logo+E: Windows Explorer
  • Windows Logo+F: Find files or folders
  • Windows Logo+D: Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F: Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB: Cycle through taskbar buttons
  • Windows Logo+Break: System Properties dialog box
  • Application key: Displays a shortcut menu for the selected item
Microsoft Natural Keyboard with IntelliType software installed
  • Windows Logo+L: Log off Windows
  • Windows Logo+P: Starts Print Manager
  • Windows Logo+C: Opens Control Panel
  • Windows Logo+V: Starts Clipboard
  • Windows Logo+K: Opens Keyboard Properties dialog box
  • Windows Logo+I: Opens Mouse Properties dialog box
  • Windows Logo+A: Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S: Toggles CAPS LOCK on and off
Dialog box keyboard commands
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item: Move to the corresponding item
reference: http://support.microsoft.com/kb/126449
on Nov 12, 2014 | Microsoft Windows XP Professional With...
How to use Notepad++vs6.4.2
The easiest way to open a new document is to press Ctrl and N together. Then press Ctrl + S to save the file. The default title will be new with a number. Press Ctrl+Alt+S to get the File Save As option to rename your document. Use the Find and replace command to remove the desired text (Ctrl+H from the keyboad). NotePad++ can have a Menu Bar and Tool Bar displayed or hide them. Many like to use the keyboard commands and hide the toolbars. If the Menu Bar is open, File > New. From the Tools bar, click on the page symbol with the green + on the left side of the bar.
The full manual is available as a compressed PDF or a compressed HTML file. See: http://sourceforge.net/apps/mediawiki/notepad-plus/index.php?title=NP%2B%2B_Guides . For either file, you will need to use your preferred zip program to extract the file. (In most Windows versions, right click on the file after saving it to the Desktop or your Downloads directory and choose Extract All.) Then use Adobe Reader or a similar program to read the PDF manual. Use your preferred browser to read the HTML version. A full list of the keyboard commands is available here: http://sourceforge.net/apps/mediawiki/notepad-plus/index.php?title=Keyboard_And_Mouse_Shortcuts .
Nearly any editor will do what you want to do. In Windows, the Notepad may not hold enough lines for this. WordPad probably would work (that's the default .DOC reader). Just remember to save as plain text if you don't want to have an Rich Text Formatted document.
I hope this helps.
Jul 11, 2013 | Computers & Internet
Hello... i have converted a word doc to a pdf file which hass images in it. these images are hyperlinked. when i click on any image in the pdf it opens up in MS paint (one of my colleagues is using I.E. 8)...
May be under create a link option open a file has been selected,that is why it is opening in MS PAINT.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Select the “Link Tool” found in the “Advanced Editing” tool bar>A set of “cross hairs”, which resembles a “+” sign, will be displayed in the window. Use these cross hairs as your cursor to highlight the text to be linked. Open create link dialog box>chose option CREATE A LINK> Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
  • Select “Open a web page” in the “Link Action” section of the dialog box.
  • Click the “Next” button.> Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
    • Another dialog box will be displayed requesting the link.
    • Enter the link. (It is strongly suggested that you copy and paste the hyperlink directly from the Internet page to avoid making mistakes when typing the URL manually.
    • CLICK OK
Sep 07, 2010 | Computers & Internet
I want the code to open the following files(.jpg,.bmp.doc.ppt) using the command button in vb 6.0 can any one help me?
Are you looking for Open Dialog box options?
Then this can help you...
http://vbadud.blogspot.com/2007/06/visual-basic-common-dialog.html
even look at this too..
http://msdn.microsoft.com/en-us/library/256tssz7.aspx
Oct 19, 2009 | Microsoft Visual Basic 6.0 for PC
A 2 MB xlsx file is taking long time to open and save - consuming 50% of CPU - making Excel screen go white - using 55 MB RAM - auto calculation off - any ideas to resolve this
Solution 1.) If you have installed PDF maker, which can get installed when you install scanner software, the Excel add-on can potentially cause Excel to open slowly. This is more common in Office 2007.
* Close Excel and any other window you have open
* Open "My Computer" and browse to C:\Program Files\Microsoft Office\Office12\XLSTART
* When you open Excel, check to see if the time it takes to open the xls/xlsx is shortened.
Solution 2.) This can be fixed by reinstalling Office but there is a faster way to fix this .
* Go to your Control Panel, (click on Start then Click on Control Panel)
* Click on Folder Options, then File Types,
* scroll down to and select (DOC for Word files) or XLS (for Excel files),
* click Advanced and select Open entry,
* click the edit Button.
* deselect "Use DDE"
* append "%1" (include the quote marks) to the end of the application command line,
* Remove /dde if it is at the end of the command line
* Then click on OK three times.
If the issue was being caused by DDE, then when you now open a Word doc file or Excel els; they will now open faster, without a long pause.
Aug 14, 2009 | Microsoft Office Excel 2007
PhotoShop CS3 Droplet automation
Try the following steps
  1. Choose File => Automate => Create Droplet.
  2. Specify where to save the droplet. Click Choose in the Save Droplet In section of the dialog box and navigate to the location.
  3. Select the Action Set, and then designate which action you intend to use within the Set and Action menus. (Select the action in the Actions palette before you open the dialog box to preselect these menus.
  4. Set Play options for the droplet:
    a. Override Action “Open” Commands Open commands in the action refer to the batched files, rather than to the file names specified in the action. Deselect Override Action “Open” Commands if the action was recorded to operate on open files or if the action contains Open commands for specific files that are required by the action.
    b. Include All Subfolders Processes files in subdirectories.
    c. Suppress Color Profile Warnings Turns off display of color profile messages.
    d. Suppress File Open Options Dialogs Hides File Open Options dialog boxes. This is useful when batching actions on camera raw image files. The default or previously specified settings will be used.
  5. Choose a destination for the processed files from the Destination menu:
    a. None Leaves the files open without saving changes (unless the action includes a Save command).
    b. Save And Close Saves the files in their current location, overwriting the original files.
    c. Folder Saves the processed files to another location. Click Choose to specify the destination folder.
    Note: You can record an action that saves using a specified file name and folder. If you do this and deselect Override Action “Save As” Commands, the same file is overwritten each time. If you record your Save As step in the action without specifying a file name, the droplet saves it to the same folder each time but uses the file name of the document being saved.
  6. If the action includes a Save As command, choose Override Action “Save As” Commands to make sure files are saved to the folder you specified (or to their original folder if you chose Save And Close.) To use this option, the action must contain a Save As command, whether or not it specifies a save location or file name; otherwise, no files are saved.
    Some save options are not available in the Batch command (such as JPEG compression or TIFF options). To use these options, record them in the action, then use the Override Action “Save As” Commands option to make sure that your files are saved where you specify in the Batch command.
  7. If you chose Folder as the destination, specify a file-naming convention and select file compatibility options for the processed files:
    a. For File Naming, select elements from the pop‑up menus or enter text into the fields to be combined into the default names for all files. Elements include document name, serial number or letter, file creation date, and file extension. Starting Serial Number specifies the starting number for any serial number fields. Serial letter fields always start with the letter “A” for the first file.
    b. For Compatibility, choose Windows, Mac OS, and UNIX to make file names compatible with Windows, Mac OS, and UNIX operating systems.
  8. Select an option for error processing from the Errors pop‑up menu:
    a. Stop For Errors Suspends the process until you confirm the error message.
    b. Log Errors To File Records each error in a file without stopping the process. If errors are logged to a file, a message appears after processing. To review the error file, open it in a text editor after the Batch command runs.
Give it a try.........
Jul 30, 2009 | Computers & Internet
Cannot compress a PDF
I assume you have tried the "reduce filesize" command. Try opening the file in Preview and print it - in the print dialog box select the pdf button, type a name and print. You get a file in the location you selected. This can reduce the size considerably.
Jun 26, 2009 | Adobe Acrobat 7.0 Professional for Mac
Name some common dialog boxes and mention its uses.
There are numerous common dialog boxes in windows, please note i am very specific to windows (and not VB since VB has difference nominclature for common dialog boxes)
following are some windows common dialog boxes:
  1. UserInput dialog box: to fetch user input.
  2. Alert dialog box: to display some alert information to the user.
  3. File Open Dialog Box: to browse and open file from selected filesystem.
  4. FileSave dialogbox: to save a file to a filesystem on selected path.
  5. Print dialog box: to setup printer preferences and print setting commands routing to printer.
Thanks.
Mar 07, 2009 | Acer Computers & Internet
Ms word n2003
Make sure that file is ms word n2003 or use some converter to conver it in another file like pdf etc....
Oct 15, 2007 | Computers & Internet
Microsoft Visual Basic 6.0 for PC Logo
98 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
