Question about Microwave Ovens
MAYTAG microwave # mmv4203ds00 touch pad is locked
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave touch pad work light doesn't work
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
SOURCE: Maytag MMV5000 microwave touchpad will not recognize touches
bought a new microwave;
Posted on Dec 12, 2009
SOURCE: unlocking child lock on the sharp microwave model R316FSC
The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
Or just unplug it, wait 1 minute, and plug in.
Posted on Jan 02, 2011
KevinWhite
  • 1902 Answers
SOURCE: I have maytag over the
Hello & Welcome to FixYa
SE or 5E means shorted keypad and to solve this problem the keypad needs replacement,
PART NUMBER: W10258190. Please get back to me if you have any other questions.
Kevin
Posted on Aug 10, 2011
MicrowaveSvc
  • 9098 Answers
SOURCE: Maytag Over the Oven Microwave Model MMV5100AA
"SE" means you have a shorted membrane keypad.
You did not give us the full model number. It will be one of these:
MMV5100AAB
MMV5100AAQ
MMV5100AAS
MMV5100AAW
On these models, you would need to order a control panel frame which comes with a new keypad already installed. It's a simple do it yourself fix.
You can look up and order that part from the Pros here, our favorite supplier. If it's not in stock immediately, they will have it to you in a few days.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays have a lock:
Posted on Oct 06, 2011
Microwave is in Lock -- how do I unlock it?
" 1. CHILD LOCK
The Child Lock prevents unwanted oven operation
such as by small children. The oven can be set so
that the control panel is deactivated or locked. To
set, touch Custom Help, the number 1 and Start/
Touch On. Should a pad be touched, LOCK .
.. ON will appear in the display.
To cancel, touch Custom Help and Stop/Clear. "
Also, to find manuals........
Oct 03, 2014 | Sharp R-1480 Microwave Oven
WHAT DOES IT MEAN WHEN MY MAYTAG MMV4203DS00 DISPLAYS "SE"?
My research came up with a shorted keypad (shorted key). The part number I came up with was W10258190 this is for stainless. I hope this information helped. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 30, 2014 | Maytag Microwave Ovens
Unlockmy lg microwave oven
As with most situations, it depends on the model number, but try this:
To set child lock:
1. Touch STOP/CLEAR pad.
2. Touch and hold 0 pad more than 4 seconds. LOCKED will appear in the display window and oven will beep twice.
To cancel child lock:
1. Touch and hold 0 pad for more than 4 seconds. LOCKED will disappear from the display and the oven will beep twice.
Sep 10, 2013 | Microwave Ovens
I have a Maytag Microwave/Hood MMV4203DS00. Twenty minutes after its last use as a microwave oven, the Vent Fan spontaneously went on and the Display Shows: VENT...FAN..--5E-- (or SE?). The microwave...
"SE" error means you have a shorted membrane keypad.
On this model, the membrane keypad is not available as a separate part, so the control panel frame assembly (which comes with a new keypad) would have to be ordered and replaced.
It's actually a pretty simple DIY repair.
The frame assembly is part number W10258190 and you can get it for $67.98 (subject to change) from the Pros here. You can also order the thermostat (part number WB27X10567 ) from them.
Their is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad as per the photo below.
positivelock.jpg Then move your circuit board into the new frame. Be careful, the display is made of glass.
Sep 01, 2013 | Microwave Ovens
Maytag Microwave mmv4203ds00 SE Error code
Not always is in the keypad the problem,in my work the problem was in one of the connectors in the control board.Resolder the contacts and it'll be fine.
Nov 22, 2011 | Microwave Ovens
Maytag MMV5186aaq touch pad doesn't recognize touches on all pressure points. I can't even set the clock.
That looks like you are in need of a replacement key pad.
I can't advise where to get one from as I don't know which country you are in.
Mar 14, 2011 | Maytag MMV5000 Microwave Oven
Sharp Microwave on "Lock" and
The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
Mar 08, 2011 | Microwave Ovens
Microwave is locked
Try this:
To cancel the child lock.
1. Touch and hold ENTER/START pad more than 4 seconds.
LOCKED will disappear and you hear two beeps.
May 07, 2010 | Maytag MMV4205 Microwave Oven
Nothing on my touch pad works
My microwave way manafacture May 2008. Nothing on the touch pad works.???. It just abrubtly stopped
after a few seconds.
We brought it in July or August
Debbie
Mar 27, 2009 | Maytag MMV1153A Microwave Oven
Microwave Ovens Logo
48 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
