Harmon kardon hkts 5 subwoofer pops, has static sound.
As stated, subwoofer pops and has a static noise as soon as you turn it on. The speaker is jumping too, like you are putting actual voltage on it instead of watts. after about 4-5 minutes it calms down, but has very little volume, even with a cd player connected strait to it. can barely hear it. took the amplifier out and there is a blackened area on the board with the heat sink, but nothing appears to be bad. it is black at location r146, to c117, to d109, to r111, to r149 all around the area on the board where those components are located. please help? thank you
  • cmiller1938 Jan 23, 2013
    Ok, I found some loose connections on the main pcb, after re soldering them, the sub now just makes one small pop when power is turned on, will not come out of stand by mode. I can hear it clicking on and when its turned off, right before the red light goes off, it turns green for just a split second.
furion187
  • 54 Answers
SOURCE: 4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Posted on Dec 09, 2007
SOURCE: Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Posted on Mar 05, 2008
  • 7 Answers
SOURCE: I believe an amplifier problem
I had a problem with no audio and I recently found the fix. When thesub still worked and you turn it on you hear one relay click and thenabout 5 seconds later a second relay clicks and the audio comes on. Theproblem I had lies with that second relay. When you take the case apartthere are 4 circuit boards. The big board with the two big bluecapacitors is the main board. Well next to the two blue capacitors is ablue relay. That relay had a pin that came un-soldered from the circuitboard. I re-soldered that pin and the sub works just like new. If yougo here http://www.eserviceinfo.com/downloadsm/20627/sony_sawm500.htmlyou can find a free service manual that has the wiring schematics forthe amp. Hope this helps!
Posted on Jul 13, 2008
  • 7 Answers
SOURCE: Subwoofer Line In/Out Mix-up
I had a problem with no audio and I recently found the fix. When the sub still worked and you turn it on you hear one relay click and then about 5 seconds later a second relay clicks and the audio comes on. The problem I had lies with that second relay. When you take the case apart there are 4 circuit boards. The big board with the two big blue capacitors is the main board. Well next to the two blue capacitors is a blue relay. That relay had a pin that came un-soldered from the circuit board. I re-soldered that pin and the sub works just like new. If you go here http://www.eserviceinfo.com/downloadsm/20627/sony_sawm500.html you can find a free service manual that has the wiring schematics for the amp. Hope this helps!
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
WHY is my harman kardon HKTS 15 subwoofwer is making a booming sound
Disconnect the cable and check the impedance/ohms with a meter.If rated at 4 ohms then it should read near that value.For 8 ohms also the reading should be near that value.You can buy a cheap Volt ohm meter for under ten dollars.After taking the ohm reading,it will be easier to diagnose................
Aug 19, 2014 | Harman Kardon HKTS 14 System
Hkts 12
It is either blown or you are overloading it and it is close to blowing. Check your wiring and make sure your amp is matched properly with how you have it wired.
Feb 10, 2013 | Harman Kardon HKTS 12 System
My hkts 15 subwoofer sounds blown. Ive tested the speaker and its not. I sent it in for repair and they could not find anything. Now I thinking its the amp? One day it started working fine and then sounded...
It could be either bad parts or bad solder connections or both but I agree with you if did what you said. Amp will have to be run for a while to know if it or something else.
A scope monitoring the line with the issue will be able to see when it fails.
Dec 21, 2012 | Harmon Kardon HKTS 15 5.1 Home Theater...
Can I connect a Harmon Kardon TS200 speaker system I bought an auction to my iMac or do I need some kind of amp/receiver?
Does the speaker system have its own Built in amp to the sub, If it has a built in amp, Then you can hook it up to thje computer with the proper patch cord,
Dec 02, 2012 | Harmon Kardon Harman/kardon Hkts 200 Bq...
I am getting no sound from sub. The turns on, but so sound. I have connected to two different receivers to verify it isn't the receiver sub output.
Bear with me on this.
Just because two systems don't light this sub up doesn't prove the amps are faultless unless they work with other subs. Can you assert that?
See page 14:
http://www.retrevo.com/support/Harman-Kardon-HKTS-14-Speaker-Systems-manual/id/386ci056/t/2/
How are you driving the sub - Speaker or Line Level?
Jan 30, 2011 | Harman Kardon HKTS 14 System
My HKTS 7 Sub woofer makes no noise,the led burns from amber to blue as normal,and every so often i hear a low rumble noise. The Sub is powered and has 1 cable to the receiver, the fuse is also good.
Subwoofer is center speaker from A+B speaker signals. first check your wire to the receiver. Otherwise you need electronics service on the amplifier inside the speaker.
Dec 04, 2010 | Harman Kardon HKTS 7 System
Subwoofer buzz & rattels & won't play music have to turn up to highest volume then sound comes out very low & still buzz & rattels off & on
That might be the woofer itself in the subwoofer, or the ampliifer.
5 year warranty on the woofer, one year on the electronics.
The woofer can be removed and checked; it should be about 3.4 ohms DCR.
Other wise,
To find the authorized Harman kardon service center in your area:
  • Go to: www.harmankardon.com
  • Click on United States
  • Click on Support at the top
  • Click on Find My Product
  • Enter your Model Number or Select your Product from the drop down list; then  SUBMIT or SEARCH
  • On the list on the left side, click on Service Center
  • Supply your zip code at the next screen, then FIND
  • A list of service centers in your area will come up.
Nov 21, 2010 | Harman Kardon HKTS 6 System
I moved from one apartment to another and when I plug my sub woofer in now it is distorted even without connection to the reciever. What coukld it be ?
There is a possibility that you might have damaged the diaphragm in the process of moving which would create the same noise as you described.
Nov 17, 2009 | Harman Kardon HKTS 5 System
67 people viewed this question
 Grubhead
Grubhead
