Question about Acer Aspire 3050-1733 Notebook
Sound and freezing
My computer get hot rapitly when in use so can you tell what is the cause
    Sergeant:
  • 250 Answers
There is a processor in the pc/laptop/notebook it gets hot while you on the unit.to keep it cool there is a fan .if that fan is not spinning properly or getting blocked by any dust particles this happens.it is also possible that fan is now turned weak as its motor is turned weak.so it needs replacement to keep the processor cool.also to avoid further damage just dont use your notebook till it get repaired.
Posted on Jan 27, 2009
I have a medion 2210 mim laptop when i first switch it on it boots up then when on internet after half an hour it freezes then i have to wait a couple of hours to get back on the net and the same thin
The cause could be, as you said, that there is one component getting too hot and the computer go into protection mode and does not work anymore.
First of all you should check if you have any virus or malware that brings the processors and the ram to its maximum causing the computer to freeze.
Second of all you should update all of your drivers and programs (could be new version of browser or flash player).
If this does not solve the cause could be the fan that cannot make the component more cold. In this case you should bring the computer to assistance because it is not a simple work and also you will lose any warranty on the computer
Feb 06, 2013 | Computers & Internet
Asus k53e keyboard freezes and then fan blows out hot air
sounds like it's overheating turn over after shutting down and look to see if there's clogged vent for fan
use a plastic tip on vacuum to get dust out then try it again
May 22, 2012 | ASUS K53e B1 Notebook
My car doesnt hold any anti freeze it leaks out the middle of my engine
Sorry to be the one to tell you but it sounds like you have a cracked block! Or at the very least a blown head gasket.
Did your car get hot all of a sudden and then you got a lot of steam? Cracked block.
It probably started with something minor that you didn't notice which caused the engine to overheat and then it cracked.
Jul 01, 2011 | Pontiac Grand Am Cars & Trucks
White smoke out the exhaust
Sounds like antifreeze, possibly a blown or leaking head gasket. Check your engine oil dipstick to verify the oil is not creamy white indicating head gasket. Hope this helps
Jan 19, 2011 | 1992 Lexus Es 300
The xbox360 is leaving a ring around all my games causing them either to freeze up or not play at all the system keeps getting very hot please help
First of all you should scan your Windows registry which is the root cause of computer freezing. you have to repair your registry using reliable registry cleaner and PC optimizing tool. When there is error in registry then its data is disorganized. And this data is not in good condition to run games at an acceptable speed. PC optimization tools use defrag technology which is helpful to fix computer freezing...
or click here to download repair guide
Dec 28, 2010 | Microsoft Xbox 360 Console
Car idols rough and has started over heating had auto zone pull codes and they said it is the fan. needles to say we replaced that and the problem did go away. had a/c relay switch replaces 4 months ago....
a/c relay has to do with a/c compressor. Do you have a/c? If so it's not that. You could have a bad thermostat. Have you replaced one yet? That would cause the over heating. The rough idel I'm not sure what to tell you there. Sorry.
Aug 12, 2010 | 2004 Chevrolet TrailBlazer
My hard drive has been making a clicking noise for a while, the computer freezes up at times, I do not think the cooling fan is working, could this cause the issue with the hard drive making noise, and if...
More than likely, your hard drive is failing. This COULD be the cause for the freezing. The other thing that could cause the freezing is if the processor is getting too hot due to the failed fan. Either way you will need to have your HD replaced before it fails completely. The clicking you are hearing is the read head hitting the case of the hard drive. It might have started from being too hot. If the parts of your computer are getting too hot, it will increase the chances that they will fail in the future.
Jan 24, 2010 | Dell Inspiron 530 Desktop Computer
Froze. very slow. very hot
Sounds to me like the cpu fan,has died and the cpu is overheating causing the freeze, the slow running, and the excessive heat. the cpu is probably fried.
Jul 12, 2009 | HP Pavilion dv6000z Notebook
My computer freezes
The most common cause is memory. So, I would suggest removing and testing your memory modules one at a time to see which module is faulty. Good luck
Jul 06, 2009 | Microsoft Windows XP Home Edition SP3 for...
Acer Aspire 3050-1733 Notebook Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
