Question about Canon PIXMA iP4000R InkJet Printer
Canon ip4000 flashing 12 times
I have a Canon ip 4000 and it blinks orange 12 times nothing has worked as I have just replaced the old with the new cartridges please can anyone help me I have tried the one when you have to hold both buttons down then turn on then push button twice while still holing one down and then pushing 4 times nothing seems to work
  • Alison Flood Jul 21, 2007
    my printer head won't move and it is 12 times it flashes any ideas
    Thankyou so much enjoy your weekend I know I certainly can thanks to you
  • 624 Answers
For 11 orange flashes (Canon doesn't list 12) Canon says its an automatic print head alignment error: -make sure ink tanks are snapped in correctly http://www.usa.canon.com/consumer/controller?act=SuprtKnowledgeBaseAct&fcategoryid=184&modelid=10438 -place 8.5 x 11 paper in the automatic sheet feeder, anything smaller will cause this error. -Remove the printer from strong light; apparently a sensor in the paper output slot can be affected. -Also you said you replaced all the cartridges with new ones, were the new from HP? If not I would definitely try replacing them all.
Posted on Jul 21, 2007
  • Anonymous Jul 21, 2007
    Forget the link, it doesn't work. This is the info I wanted you to see:
    Refer to the following steps to verify the ink tanks are seated correctly:
    After confirming that the printer is powered on, open the paper output tray.
    Open the top cover and wait until the print head moves to the center.
    Open the inner cover and check that ink tanks are properly seated.
2 Suggested Answers
6ya staff
SOURCE:
Mike258
Justin Case
  • 1498 Answers
SOURCE: Canon ip4000 flashing 12 times
It sounds like the cartridge or one of the tanks may not be properly seated.
Pull out and then reinsert the ink tanks. Make sure they CLICK in firmly. Hold down the RESUME button for 5 seconds.
Helpful links:
Click here for the Canon iP4000 cartridge replacement page.
Click here for info on reseating tanks.
Click here for the correct order of the ink tanks
Hope this helps.
Mike
Posted on Aug 03, 2008
Canon Pixma IP4000 - Printer on/off button flashing orange light X 5 and then green. I have just re-newed all the ink cartridges Can you help ? will i be able to re-set printer ?
5 times orange means you need to replace the print head.....if the led are Blinking in Orange and Green Alternately you need to replace the sheet feed unit.
Mar 28, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
I have a Canon Pixma IP 4000 and keep getting the error message that the ink absorber is nearly full. Print quality is not good even after cleaning. What should I do?
Resetting Ink-Waste Overflow Counter Canon Pixma iP3000, iP4000, iP5000 Printers
1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
2. While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
4. When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
5. Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
6. Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 09, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My Canon pixma ip 4000 won´t print. The light at the turn on button blinks five times orange and then comes one green blink. I have tried to clean the print head but that didn´t change anything....
this indicates a the print head is not installed correctly or is faulty.
if the green and orange is alternating 5 times then it is caused by the sheet feeder.
Dec 08, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
New computer, can't find disk to install
Hello my name Danny I am going help you on this matter If you go on this site and you can download drivers for your printer PIXMA IP  4000
http://download.cnet.com/BJ-Printer-Driver-Canon-Pixma-iP4000/3000-2116_4-10555918.html
Oct 03, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Why flash by 5 times the orange led?
Probably your waste ink counter should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Good Luck, I hope this helps?!
Aug 12, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
Canon ip 3500 7 flashes of orange
try unplugging it for a little bit and plugging it back in and see if this works.let me know if not then we will try something different.thank you for using fixya.
Dec 14, 2008 | Office Equipment & Supplies
Pixma ip4000 5 blinks error
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10239
If you type in 'flashing power light' in the problem box, for 5 you get print head failure, often it means the connectors between cartridge and print carriage are dirty, can be cleaned with a pencil eraser and a soft cloth. there is a sequence of checks and repairs to follow on the canon service page
Jul 25, 2008 | Canon PIXMA iP4000R InkJet Printer
Helpful links:
Hope this helps.
Mike
Jul 11, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
The light blinks 12 times, and nothing will print
suggest you need a new set of printer drivers
remove old version first
go here for new ones
re install
Mar 20, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Pixma IP4000 12 flashing lights error 6A00
IP4000 12 flashing lights error 6A00 problem, and notify you when a new solution is offered.
Dec 02, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000R InkJet Printer Logo
332 people viewed this question
Clive
Clive
old marine
old marine
Ekse
