Question about White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
My white rodgers thermostat frozen can't move up and down
The screen show 45 degree I cannot move the temp higher
liteswink
  • 99 Answers
SOURCE: No Heat with new White Rodgers 1f85rf-275 Thermostat
The only way to resolve this problem and to distingush if its a thermostat issue on the system is to by pass the thermostat by putting a jumper between the hotwire and the heating wire if the system did run which happen most of the time. Call the HVAC technician to check your heating unit. Or call the White- Rodgers technical line at 18887259797 choose contrator division.
Posted on Oct 20, 2009
liteswink
  • 99 Answers
SOURCE: white-rodgers 1c26-101 owners manual, does anyone
Link: Installation Instruction
Posted on Apr 07, 2010
liteswink
  • 99 Answers
SOURCE: Keeps going to 62 like it's on a program
You need to manually operate the thermostat by using the hold button. You did not specify the model number but try this procedure:
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set toHEAT or COOL, momentarily press HOLD button. HOLD will be displayed. Use UP or DOWN to adjust the temperature.The thermostat will hold the room temperature at theselected setting until you press RUN button to return to program operation.
If you need further clarification please cal hometechline 18002842925. I hope this will help you a lot...
liteswink
  • 99 Answers
SOURCE: I need an instrution manual for white rodgers 1F85
Click this link: Manual
Posted on Apr 26, 2010
reddawgesq
  • 134 Answers
SOURCE: How do I program my
Download a PDF version of the Operating Manual HERE. ___ *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Posted on Feb 03, 2011
I have a white-Rodgers 1F86-244 thermostat. When I turn the temp down it clicks on. But when left to come on its own it does not. I replaced batteries & reset it several times. Do I need a new...
Hi. This is Aaron Moratalla from White Rodgers. The clicking sound indicate the relays inside 1F86-244 are working. Say you want heat and your room temperature reading (left side of LCD) is 70F and your set Temperature (right side) is 75F. When you push the down arrow and set it from 75F to 69F or lower then you should hear the soft clicking sound. Same thing if from 69F you increase it to 71F or higher. If you don't have the clicking sound it means your thermostat could be broken. If that is the case then call our Tech Support at 800-284-2925. It's line is open M-F from 7AM to 1Am CST and Sat-Sun from 7AM to 4PM CST. Thank you for choosing White Rodgers!
Feb 01, 2013 | Home Security
I have a White Rodgers thermostat series 1F78-151 that is displaying we at the top?
Hi. This is Aaron Moratalla from White Rodgers. For 1F78-151, "WE" means Wednesday. If left side temperature is stuck at 67F and there's no Hot air coming out then try ressting your thermostat by:
1. set system to Heat mode
2. press simultaneously the Up, Down arrows and Time button for 2sec.
3. the screen should blank out momentarily then show 62F in the right side.
4. set a higher temperature in the right side than the left side of LCD to have a call for heat.
If you are still having problems please don't hesitate to call our Tech Support line at 800-284-2925. Thank you for choosing White Rodgers!
Jan 24, 2013 | White Rodgers White-Rodgers 1F85RF-275...
White rodgers customer service phone number
we are not white rodgers /emerson --the following links can assist you but if the trooble shooting doesnt fix problem just replace the stat
White Rodgers White Rodgers White Rodgers Thermostats Thermostat AC Wholesalers How to Troubleshoot White Rodgers Thermostat eHow
May 30, 2017 | Heating & Cooling
I have a white Rodgers ac thermostat and the temperature in my apartment stays on 88 no matter how low I set the temp. If I turn it off, of course it gets even hotter. This started happening when I pressed...
I'm not quite sure I understand what you have done but, make sure your compresor(outside is running and, that you don't have the thermostat set to "fan". You want the display to show "cool" and then adjust your temp. It sounds like you have the system set to fan and not cool. Provide me with a model number and I will see about getting you a manual.
Jun 04, 2011 | White Rodgers 0754-1 Electric Water Heater...
Keeps resetting down to 62 degrees need to know how to set the temp higher and stay at the new temp
Jan 08, 2011 | White Rodgers White-Rodgers 1F85RF-275...
I have a problem with a White rodgers 1C20-101 thermostat. The lower heat setting for room temp goes up to 80 degrees when the thermostat is set at 70 degrees. Is this normal for this type of unit?
The Operating Manuals for many White-Rodgers thermostats can be found in PDF form HERE, however they are not indexed by model number so you will have to download each file in turn until you find the one you want. All of the file names beginning with "0037-" seem to be W-R products.*Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Oct 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Thermostat resets itself to 85 degrees a couple hours after I set it to 74 degrees
To manually operate the thermostat set the system to cool and fan to auto then press the HOLD button one time then release, you will see the hold word on the screen after that up the UP or DOWN arrows is setting the desired temperature.
Jul 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
My white-rogers 1F81-261 model thermostat keeps rgoing back to a 62 degree setting after the furnace kicks on at a setting of 72 degrees. I have reset the program, but that doesen't seem to help. What can...
MANUAL OPERATION
program operation.
This is on page 6 of the manual
Feb 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
42 people viewed this question
Top White Rodgers Home Security Experts
Nicholas Bannister
Tom Chichester
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
