Question about Coffee Makers & Espresso Machines
Miele CVA 620 part 9161.391.xx0 where does it go ? Can I obtain instructions for setting up a new grinder ?
    New Friend:
Miele CVA 620 part 9161.391.xx0   where does it go - miele-cva-620-part-9161-391-xx0-go-nsr413nfwic5kgfniqnnhys0-3-1.jpgIt is the cover of ground coffee quantity. You loose it when you unscewed the first scew of coffee bean container base.
Posted on Mar 21, 2015
Hello James. I also have the same problem. Part 9161.391.xx0 also dropped out of my machine too! Can you tell me where it goes? Many thanks, Tom.
Posted on Jan 02, 2014
Ya1da
  • 4 Answers
SOURCE: can you give me the process to descale the miele cva 615 coffee machine?
Here you go just click on this link I put the manual on my site: http://yalda.us/CVA615_us[1].pdf
Posted on Mar 12, 2008
SOURCE: My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
Posted on Mar 15, 2010
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Posted on Jun 03, 2010
SOURCE: No 'real' coffee taste or crema - despite following instructions
Set the machine for the finest coffee and the least water.
You should get a decent espresso.
For a regular cuppa, keep the settings the same and make either a medium coffee combined with a small coffee (jolt) or
make two small coffees.
I have this machine and the crema is nice at this setting.
Posted on Oct 03, 2010
  • 128 Answers
SOURCE: I have a three month old Miele CVA 4066. I have
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Posted on Feb 24, 2011
I have Miele coffee system CVA 4062 the grinder is not working properly? I have cleaned everything, Descaled all that good stuff.
Its likely to be the brushes in the Grinder motor. These are replaceable but Miele does not sell them as a spare part. You may be able top fabricate your own if your technically minded and experienced and can disassemble the machine. Otherwise grinder needs to be replaced. Regards
Jan 18, 2017 | Miele Coffee Makers & Espresso Machines
Miele CVA5065 coffee machine- the manual states : "fill the big plastic container to the max level". What is the volume to the max level?
Filling The Water And Coffee Bean Containers - Miele CVA ...
www.manualslib.com > ... > Coffee Maker > PW 5065 > User manual
Miele CVA 5065 Manual Online: Filling The Water And Coffee Bean Containers. Thecoffee machine must be cleaned thoroughly (see ''Cleaning and care'') before you... ...up to the "Max." mark. A valve at the front of the water. container will ...
[PDF]Operating and installation instructions Built-in coffee ...
Nov 25, 2015 | Miele Coffee Makers & Espresso Machines
I have a three month old Miele CVA 4066. I have recently cleaned the unit twice (using little tablets in coffee grinder), as well as descled. The coffee, expresso, etc. is barely dripping out of the unit. ...
Feb 10, 2011 | Miele CVA 4066 Stainless Steel
Aug 01, 2010 | Miele CVA615 Espresso Machine
I need directions to clean my miele CVA 4070
The cleaning instructions are on page 34-45 of the owners manual =>
http://www.miele.com/manuals_pdf/Residential/Coffee_System/CVA4070_us.pdf
Please leave feedback. Thank you.
Dec 11, 2008 | Miele CVA4070 Coffee Maker
Coffee Makers & Espresso Machines Logo
380 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
