Neptune MLE2000A Front Load Stacked Washer / Dryer
Problem for Neptune MLE2000A Front Load Stacked Washer / Dryer
Water left pooled inside maytag neptune front loading washer
By kchang9798 on Jan 27, 2009
I have a stacked maytag neptune washer MLE2000. It is about 4 years old. I did a wash last night and it drained properly and there was no water left inside the washer. The next morning I went to do another load but found a pool of standing water inside the machine. What does this mean and how can I fix it? Should I still use the machine?
Best Solution
posted on Mar 26, 2009
Very Helpful)
Cleverer2
Rank: Guru
Rating: 86%, 132 votes
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The valve is either electric solenoid or plastic/rubber clapper in a cylinder. Your call whether to fix or not depending on ease and cost. Probably a $20.00 part.
Cheers!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Neptune MLE2000A Front Load
Questions and Unsolved Problems for Neptune MLE2000A Front Load
Do you recommend Neptune MLE2000A Front Load Stacked Washer / Dryer?
Answer
Answer
does anyone make a bearing and seal kit for the outer tub for a mle2000akw
Answer
maytag neptune stackable keeps stopping in the middle of cycle?have to keep pushing start. 10 times... (More)
Answer
the unit will not spin. have power at wax motor. and R/R wax motor. no spin. But if i by pass the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
