Question about Hotpoint Ultima WF860 Front Load Washer
F10 FAULT CODE
Does one complete wash and then on the second wash - displays "F-10" (Flashes)
any ideas what f10 means?
  • Hotpoint Master
  • 3,463 Answers
F10 means that the pressure switch (water level switch) is not sensing the correct water level.
This can be for one of several reasons.
Firstly ,clean filter, if no filter at front behind bottom panel ,then remove lower rear panel, remove large black hose from bottom of tub, remove and clean filter inside..
Detach pressure switch hose attached to plastic chamber which comes from large black hose, this is a small plastic hose, blow down it , and you should hear the switch click if you listen carefully.
If you cannot hear it click, then switch is probably faulty, follow hose to switch.
Make sure the plastic chamber is not blocked where the hose is attached at bottom end.
Plz rate my solution.
Thanks.
Posted on Jan 27, 2009
What does code F-10 means?
F10 is a pressure switch fault which could just be the pressure chamber is blocked and needs cleaning out
use this link for error code Domestic Appliance Help
Oct 03, 2016 | Indesit Washing Machines
Crosley oven dont work f 10 gas
The "F10" oven error code means "Runaway temperature"
try this link http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/70424-what-does-f10-error-code-mean.html#ixzz2VTV50IJ4
Jun 06, 2013 | Ovens
It has stopes at beginning of a programe with fault f10 displayed on the display
Dyson fault 'F10' decodes as 'overspeed, motor triac failure'.
Sorry but that means an engineer call ;-0(
Although it is bad news, if this has clarified the situation for you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 29, 2011 | Dyson Washing Machines
Spinning stop and flashes 10
Fault code F10 means the motor is overheating. You may have a failing transmission or corroded wiring. Or the motor may just be failing. Start by trying to run smaller loads and see if this still happens.
"F/10" Motor Control Unit (MCU) Heat Sink Thermal Trip
If the thermal protector on the MCU heat sink gets too hot, it will open the thermal protector on the heat sink which will stop motor functions and an "F/10" will be displayed.
  • Check for Proper Installation, verify the unit is not located near a source of heat and has proper ventilation.
  • Check Wire Harness connectors to the MCU, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check Motor
Jan 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error F10
There is a topic alryde about the F10 error
You will get your answer here
http://www.fixya.com/support/t1461650-wf840_f10_error_code_get_worse
Good luck to you!
Please take a moment and rate my answer
Nic
Feb 06, 2009 | Hotpoint Ultima WF860 Front Load Washer
Alarm Code 10 - Meaning Please?
You can download the manual from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/HB00503_WF840_860_865_19504206802_jan05.pdf
You will need to contact the service helpline for the explanantion of the F10 display
Dec 30, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima W860
hi there f10 fault code means pressure switch not sensing,
this could be to do with low water pressure or a bad connection on the pressure switch or control module which is located at the back left hand corner of the machine, remove backplate to gain access and remake all connections on module, if this should not resolve the fault i would be looking to replace the pressure first part no= C00112659 cost about £15
ps. always disconnect from mains before carrying out any work
Oct 20, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
218 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
