Question about Sewing Machines
Skipping stitches on model 219 huskystar sewing machine
  • 43 Answers
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
Posted on May 07, 2009
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
louislevel_2
  • 374 Answers
SOURCE: need sewing machince help????
hi;
breaking thread and thread below not hook up by upper thrread, this is due on not properly set up of thread tension,first check bobbins windin35caecd.jpgg see figure.the threads should
be counter clockwise.
the theading on upper set up should prorerly inserted follow figures.7dabcae.jpg
the dial set up tension should start at #3 to # 5
the stitch tension should be set to # 8 to # 12
use trial run for fabrics,diffferent set up in every fabric tru to study before sewing in other fabrics.have a nice day don't forget to rate me.thank s a lot
Posted on May 17, 2009
sodeep
  • 3267 Answers
SOURCE: I have a Huskystar C10.
There is one way out. Give the sewing m/c a thorough servicing job, Clear all the pieces of cloth/fabric/threads, etc Remove the bobbin and load afresh. Clear out the toothed sliders which pulls the cloth while stitching. the thread being used for stitching passes a sort of loop, the tension being controlled by how much the pressure the spring can exert such that depending on the material being stitched. Specially after stitching satin, which is tricky material to stitch in a sewing m/c since the cloth is slippery. Also clear sewing jam and the metal teeth like rack which pushes the cloth for the next stitch to start. This area if cleaned up properly and a little bit of oiling on the spring loader and the spindle assembly which moves up & down...............................sudeep
Posted on Aug 08, 2009
  • 76 Answers
SOURCE: i need an instruction manual for my Huskystar model 65
try this site
SewingManuals.com
Posted on Aug 28, 2009
My singer model 2263 will sew fine then it skips about 3 or 4 stitches. What causes this
needle /hook timing , incorrect needle thread tension or worn bobbin shaft
Mar 29, 2018 | Singer Sewing Machines
The User Manual does not have a complete stitch guide. Does my Huskystar 207 have a stretch stich?
FWIW, a stretch stitch is simply a stitch that stitches forward a few stitches and then reverses for a couple and then stitches forward again. Having had a machine with a stretch stitch, I found that using a zig-zag is just as effective and uses much less thread as well as less time at the machine. If the fabric is very stretchy, you can merely decrease the stitch length and increase the stitch width to give the stitch enough space to expand with the fabric without popping.
Viking Huskystar 207 Manuals
Jun 22, 2017 | Sewing Machines
What is the price of Husqvarna Huskystar 219/224
I would try checking with a sewing machine shop in your area to see what their price is, I did find a 219 on ebay for less than $200.00,
Dec 07, 2014 | Husqvarna Sewing Machines
Huskeystar219 how to thread the sewing machine
here is a link for a manual or you can check youtube for a video
Viking Huskystar 219 224 User Guide
Aug 01, 2014 | Sewing Machines
Huskystar 219 224 type buttonhole
Attach the buttonhole foot. Then pull down the arm to interact with the foot. It is next to the presser bar to the left. Select buttonhole stitch. Start sewing. It should stitch all four sides in one step.
Oct 13, 2013 | Sewing Machines
How do I get the stitch selector knob off janome 307?
Hello, I have the Huskystar 219/224 sewing machine.
The foot does not go down.
Aug 02, 2013 | Sewing Machines
Husqvarna Huskystar 207 Sewing Machine not stitching. It won't pull the bobin thread up to sew.
Be sure not to use Singer Needles. They are longer than standard needles. Don't know if this helps, but I did this once on my Huskystar 207 and that is what happened. It also damaged the bobbin thread.
Fairleigh
Sep 18, 2011 | Husqvarna Huskystar 207 Sewing Machine
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
