Question about KitchenAid KUDC10IXSS Builtin Dishwasher
Kitchenaid kudc101xss stopped working
Control panel not working
2 Suggested Answers
  • 37 Answers
SOURCE: kitchenaid dishwasher, control panel is not
I don't know your technical ability, but there is a fuse located next to the control board inside the console, this is a good place to start. Kitchen Aid is good about putting tech sheets on the back of the kickplate and it should have wiring and diagnostic info there. Just be sure to put the sheets back so the next service tech to work on it will have them :)
Posted on Sep 01, 2009
Kitchenaid microwave KBMC140HH03
If you wish to get some details about microwave oven repair then check the following link
http://electro-medical.blogspot.com/
Aug 16, 2016 | KitchenAid Microwave Ovens
How to reset control board on kitchenaid dishwasher
Check to see if there is a manual behind the bottom panel. It should tell you what that error code is. It may be the heater is not working or some other issue. You will have to repair the problem before this will stop.
Oct 02, 2014 | KitchenAid Dishwashers
Kitchenaid refrigerator control panel
Light switch has gone bad use your model number to order a new one
Jul 25, 2013 | KitchenAid Refrigerators
Model KUDS30FXSS1 Kitchenaid dishwasher control panel stopped working at the end of a cycle.
I had a similar problem: unresponsive buttons, then the 1 hour wash button led was on but the other buttons weren't working at all.
I power off for more than 30 seconds and after that everything return to normal.
Thank you for the hint!
Nov 03, 2012 | KitchenAid Dishwashers
Control panel will not light up, the dishwasher was running and now it has stopped mid cycle and will not do anything. I just replaced the control panel (black plastic with buttons, not control...
I have a kitchenaid dishwasher model # KUDC10FXBL1 I went to start it and none of the buttons were working. I have checked the breaker and the wiring and everything seems to be in order.
Jan 13, 2011 | KitchenAid 34 in. KUDP01FLSS Stainless...
Kitchenaid Range KGRA806PSS Control Panel Not Functioning
You're right about not using the self clean option. Your oven gets up to over 800 degrees when you use that feature. You can choose to simply keep your oven wiped out, rather than self clean it. The timer is most likely going out if the "stop" button doesn't work after cleaning. Please call or email us and we will be sure toget the right part for you. I hope this solves your problem. Ella
Sep 09, 2009 | KitchenAid KGSI901PBS Gas Kitchen Range
KitchenAid dish washer: Control Panel Problem
Circuit board/ Electronic control assembly needs to be replaced.
Jul 24, 2009 | Dishwashers
Kitchenaid superbra 24 oven
select clean on the control panel and set stop time then push start
Jan 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Dishwasher stopped working during rinsing cycle.
1. Disconnect power to dishwasher. Remove screws holding the control panel from the side of the inner door. Remove control panel. If it does not come off - remove all screws on the inner side of the door and separate the inner and outer door.
2. Fuse is on the right side on top of the control board. it usually has tan or black or yellow wires to it. Disconnect wires and check fuse for continuity. if none - replace fuse with wiring harness supplied with it.
Good luck
Vlad
First Choice Appliance
Jan 05, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid KUDC10IXSS Builtin Dishwasher Logo
22 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
