Question about Toshiba 57H84 57" Rear Projection HDTV-Ready Television
Will not power on.
I just got a factory refurbished Toshiba 57H84 rear projection tv. I got it home out of the box, pluged it in and it wont power up, no picture no sound nothing. The power indicator just flashes continously with no breaks or pauses. Did I miss a step in setup. Ive been through the manual 3 times and cant find anything that I missed. Thanks. Nic
  • 1 more comment
  • Nic Webb Sep 21, 2007
    Yes actually I got mine fixed. It turned out that there was a bad diod (sp?) on one of the boards inside the TV. If your toshiba is doing what mine was, thats an indication that there is something wrong internally with the TV and it will have to be repaired. Good luck getting it going!
  • breenme3202 Feb 29, 2008
    My screen turns blue and then the Television just shuts off! Could it be a fuse?
  • Anonymous Dec 26, 2008
    same problem here. Blue screen (with added burned dot in the middle), then it shuts off. It started doing it periodically, now it does it all the time and won't work at all.
  • 72 Answers
Your blinking red power light is indicating a problem with the set. It has read an error code. With my experiance with Toshiba I found that a dead set or blinking red light can be a whole bunch of diffent conditions. One common problem though, and I would check this first, is your convergence circut. It is very common that the the convergence IC's themselves and or some resisters in that circut have failed. Also check all the pico fuses on the power and sub power supply's. Hope this helps and good luck
Posted on May 04, 2010
Sorry i dont have any answers for you'r problem. I'm actually having the same problem with my 57H84 (though it says 94 on the back of the unit itself). Have you found out anything pertaining to the problem. I'm trying to learn more about the problem before just blindly taking it to the shop..i LOVE THIS TV and i've had it new for two years now.
Posted on Sep 17, 2007
SOURCE:
Toshiba 57h84 wont stay on
CRT type from the model number
When goes off what do you have: power light on or off?
If it stays on a short time what does the picture look like?
There is a difference between total dead and shuts off after ?
Mar 27, 2012 | Toshiba 57H83 57" Rear Projection HDTV
No picture, the little red light on the power button just flashes. I'm not sure if this is something relatively simple, like a bulb replacement, or if it's shot and I need to buy a new tv. Help! Toshiba...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem.....
Dec 31, 2010 | Toshiba 57H84 57" Rear Projection...
Flashing Power light
Ur power board ic inverter is dead.
U need a new board.
Aug 19, 2009 | Toshiba 57H84 57" Rear Projection...
SERVICE MANAUL FOR A 57H84 toshiba
Hi
Click on the following link: Click Here
Please remember to rate this solution as FixYa!
Kind regards
BearWeb
Apr 12, 2009 | Toshiba 57H84 57" Rear Projection...
Toshiba 57H84 57" Rear Projection HDTV-Ready Television Logo
590 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
