Question about HP Deskjet F2180 All-In-One InkJet Printer
Hi ya, Im trying to print off a document but it's telling me that the printer is Paused!!!! What does this mean?? I've just tried the printer in on a diffrent computer and it printed off a doc no problem at all.
  • sally_scott Jan 27, 2009
    I did try cancelling everything, but then when I hit print nothing happens! :(
    Problem Solver:
  • 11 Answers
In the tray on the bottom right portion of your screen look for a printer icon click on it and a printer options window will appear. In there you should see atleast one printer spool and it should say paused. High light all current actions in the printer spool and cancel them. This should fix your problem.
Posted on Jan 27, 2009
  • Jonathan Gibson Jan 29, 2009
    Try uninstalling this printer on this PC. Go into the control panel click on this printer and uninstall it. Now shut downPC. Unplug the printer from the PC, turn on PC, after it boots fully turn it back off and than hook printer back up. Now turn the PC on. The PC should auto detect Printer and reinstall.
My printer is saying paused and will not print
Hi
If you open Devices and Printers, right click on the menu that comes up and click on "See what's printing", a dialogue box should come up with a list of documents to be printed. In the second column is the status of each document. The first one in the queue will probably say "paused". Highlight this, click on the document menu and remove the tick against "pause" and the printing should restart.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 04, 2015 | HP PSC 2355 All-In-One InkJet Printer
Paper feeds, but won't print. As far as I can tell there is ink.
Ensure the Paper Tray is Not Overfilled Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray Adjust the Printer Paper Guides Adjust the paper guides to fit the size paper being used (Figure 1). The guides should be close (1/16" or less) to the paper without touching, so that the paper stays properly aligned without continually rubbing the guides. Locate and Remove Any Obstructions Inside the Printer and Input Tray Open the front cover and make sure the kickstand (if there is one) is engaged. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects. Close the cover. Remove all paper from the input tray. Inspect the input tray for any obstructions. Remove any visible obstructions. Reinsert the paper. Determine if Multiple Sheets Are Fed at Once From the Paper Tray or ADF Determine if multiple sheets are fed at once from the the paper tray or Automatic Document Feeder (ADF). Verify the print media installed is compatible with the printer Clean the ADF Paper Feed Roller Disconnect the AC power from the printer. Open the cover of the Automatic Document Feeder (Figure 1). Figure 1: Raise the Cover of the Automatic Document Feeder Using a damp paper towel, gently wipe the rubber roller to remove any ink or paper debris (Figure 2). Figure 2: Paper Feed Roller on the Automatic Document Feeder Close the cover and reconnect the power. Reseat the Dell Printer Power Adapter If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a Dell? inkjet printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends. If the printer queue icon is showing in your system tray (by your clock), you may have documents that are paused for printing. To resume printing a paused document: Double-click the printer queue icon to check document status of the active printer. Right-click on any documents that show Paused under Status, and then click Resume in the drop-down menu. Try a Different Type of Print Media Many image quality and paper feed issues are caused by the type of print media being used. Try a different type of print media that is specifically made for this printer. Replace the printer.
Nov 22, 2009 | Dell 968 All-In-One Printer
Media is not picked up from the media tray
save the document to your desktop or copy and paste into word or notepad..
tell ya printer settings to clean nozzles.
remove paper.
place paper into tray area but not a whole lot....15-20 sheets...
now print...hows that..:-)
Sep 15, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Hi, i was trying to print something and it keeps telling me printer busy and then troubleshoot and when i turn off printer and turn back on, its telling me the same think. What should i do?
If you double click on the printer icon in the bottom right hand corner of your taskbar are there any print jobs that are paused. if there are any there then click on the print job and then click on document - cancel.
Aug 05, 2009 | Office Equipment & Supplies
Trying to print, but Status Paused is showing
Hi
Thanks for using FIxYa. Please turn the printer off and then cancel all the print queues pending in the bottom toolbar by double clicking on the printer logo if you want to delete all the pending printing files. Now turn the printer on. If you do not want to cancel all the printing jobs then you can double click on the printer logo showing in the right side of the bottom tool bar and then right click on the printing jobs pending for printings then click on restart printing. Issue will be resolved and it will not show ‘paused status’.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 04, 2009 | HP PSC 1210 All-In-One InkJet Printer
Desktjet 920c stuck on paused
System restore got my printer working again.
Feb 27, 2009 | HP DeskJet 920c InkJet Printer
Printer paused
Hi
Go to control panel on your computer, then go to printers and other hardware or printers and faxes, right click on epson icon and left click on resume printing, or you can cancel the document then when it says 0 and ready as status, try printing again.
Hope this helps
Aug 25, 2008 | Epson Stylus CX6600 All-In-One InkJet...
HP Deskjet F2180 All-In-One InkJet Printer Logo
75 people viewed this question
Ben Johnson
