Question about Dual Electronics CECT P168 Cellular Phone
Phone is showing Connecting.
I have followed the directions in the manual to correct this problem and after many times it still is showing Connecting. I have unplugged everthing a couple of times but that doesn't help either.
    President:
  • Dual Master
  • 1,734 Answers
Ask http://chinamanuals.com - they know everything about that phones.
Posted on Feb 08, 2009
Model FA101 outdoor mechanical timer, I have two brand new timers, neither will keep the time of day, I spin the dial to the correct time, in the correct direction, I believe it sticks when it comes up to...
1) I cannot identify FA101 timer.
Internet search shows no result for FA101 timer.
My files show no FA101.
There is Intermatic T-101, but with trippers and not tabs.
T-101 will not work if it is wired wrong.
2) I test timers -and- answer questions for fixya, so I can identify with your frustration, and believe you should get your money back from the seller or manufacturer.
3) Open box cover and see if manufacturer and full model number appear on door.
Or check following links to see if your timer appears.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
http://waterheatertimer.org/Tork-timers-and-manuals.html
http://waterheatertimer.org/Boxtype.html
4) Add a comment with exact information so a free solution can be offered.
5) Take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 18, 2011 | Hardware & Accessories
Hi, How do you change the time on a Panasonic KX-T7633 CORDED PHONE
There are several way that may adjust the Panasonic phone clock, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
Oct 19, 2009 | Panasonic KX-T7633 Corded Phone
Program Extension Name and change time on phone.
Please refer to the manual page 5-6 for how to storing caller's information names and numbers.
To set the time of the phone, there are several way that may help, please try the following suggestion method:
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Sep 23, 2009 | Panasonic KX-T7633 Corded Phone
Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Jul 17, 2009 | LG enV VX9900 Cellular Phone
When i am connecting my n72 with my pc a massege comes out that"USB device not recognized".my phone is showing the arrow like sign but my computer is not connecting with the phone...what should i do????
Remove Totally and Re-Install your Nokia PC Suite and Drivers first, then follow the On-Screen instructions to connect your Phone to your PC, at the same time, also try to use a different USB prot this time around.
Hope it helps.
Jul 10, 2009 | Nokia N72 Cellular Phone
Change the time on the KX-T7633 pnone
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Jul 10, 2009 | Panasonic KX-T7633 Corded Phone
Clock on Phone
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Jun 24, 2009 | Panasonic KX-T7633 Corded Phone
How do I use the fax without going thru my computer just as a fax
Issue: How do I connect a telephone, answering machine or computer modem to my machine?
Solution: Connecting the telephone line and external devices to the MX310
Preparing the Machine for Faxing title-bar.gif Typical examples of connecting the machine are described below. The machine cannot send/receive faxes if the connection is incorrect. Connect the machine correctly.
i_important.gif Important
If the Power Disconnects Unexpectedly
If there is a power failure or if you accidentally disconnect the power cord, the date/time settings as well as all documents stored in memory will be lost. User data and speed dialing settings are retained. If the power disconnects, the following will apply:
bullet_s.gif You will not be able to send or receive faxes or make copies.
bullet_s.gif If a telephone is connected to the machine, you can receive voice calls.
bullet_s.gif Whether you are able to make voice calls depends on the type of your telephone.
sikaku.gif Methods of Connecting External Devices bullet.gif Connecting to an Analog Line t_01522.jpg
(A) Telephone line (analog)
(A) Telephone or Answering machine
Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A) . The machine may not operate properly.
bullet.gif Connecting a Telephone or Answering Machine via a Computer t_01724.jpg
(A) Computer
(B) Telephone or Answering machine
sikaku.gif Methods of Connecting the Various Lines The following are some basic connection schemes that apply when you are connecting to a non-analog telephone line. These are examples and are not guaranteed to suit every connecting conditions. For details, refer to the instruction manual supplied with the network device (control devices such as an xDSL modem, terminal adapter, or dial-up router) you are connecting to this machine.
(A) Digital Subscriber Line
(B) Splitter
(C) xDSL modem (splitter may be built-in to the modem)
(D) Computer
bullet.gif Connecting to an ISDN Line For details on ISDN connection and settings, see the manuals supplied with your terminal adapter or dial-up router.
Please be informed that you can access Canon's online support site for your printer by clicking here. You can find many solutions to your problems by searching their database once you have navigated to the support page for your model.
I hope this information allows you to resolve this issue. If not, reply back with a comment to this thread.
If so, please take just a moment to rate this post. Thanks!
Apr 03, 2009 | Canon PIXMA MX310 All-In-One Printer
Internet
procedure for connecting to internet in pc:
<*install the sony ericsson pc suite using the cd that you got with the phone during the purchase.
click on the ->sony ericsson pc suite
->a window appears
click on ->the mobile networking wizard
you can see the status of the internet connection,speed .
call the customer care of your mobile network service provider they will tell the necessary procedure follow it.
*settings are required to connect to internet,some service providers send the settings directly to your phone,while some service providers tell the settings which you have to enter it directly or manually in the concerned profile
*make sure that you have selected the correct internet profile.
*if you are connecting the phone to computer,make sure you are able to browse in your phone first else internet cannot be accessed in your computer
.all the best do contact me if the problem persists
Jan 28, 2009 | Sony Ericsson K530i Cellular Phone
How to change time
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Nov 06, 2008 | Panasonic KX-T7633 Corded Phone
Dual Electronics CECT P168 Cellular Phone Logo
22 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
