Question about Brother HL-2040 Laser Printer
Problem with drum?
Just replaced Toner. Full set of paper in tray. No paper jam. Yet...red 'paper' light continues to blink. The printer seems to be spurting out black ink on the pages (that is, when it worked, the printer has ceased to work at all). My suspicion, based on research on this site, is that the drum needs to be cleaned or replaced. Is this correct? I cannot, however, find any information on HOW to remove the drum (truth be told, I am not sure where exactly the drum is). Is this the crux of the problem? Or could it be something else? Can I clean the drum without buying a new one? Please help. Thank you.
  • duncan_ridde Jan 30, 2009
    what do you suggest I do to repair this problem???
    Genius:
  • 2,035 Answers
1. If the paper source setting of the program you are printing from or
the Brother printer driver is set to Manual feed, the Paper LED will
flash prompting you to load a sheet of paper, an envelope, or a label in
the manual feed slot of the printer. It can also be caused if the document you are trying to print was created as a letter,
mailing, or label.
2. Using both hands, slide the manual feed slot paper guides on the
front of the printer to the width of the paper that you are going to
use.
3. Using both hands, put one piece of paper in the manual feed slot
until the front edge of the paper touches the paper feed roller. When
you feel the printer pull in the paper, let go and the printer will
print the document. If the Paper LED continues to flash and the printer
does not pull in the paper, this issue was not caused by a manual feed
command, continue with trouble shooting.
4. Open the front cover by pulling the tabs on the left and right side
of the printer towards you.
5. Remove the drum/toner assembly by lifting it up slightly at the
center and pulling it out to the front. Place the drum/toner assembly on
a piece of disposable paper or cloth to avoid spilling and scattering the toner.
6. Clean the primary corona wire inside the drum unit by gently sliding
the blue tab on the top from right to left and left to right several
times. Return the blue tab and snap it into the home position. If you
don#t, printed pages may have a vertical stripe.
7. Remove the toner cartridge from the drum unit holding down the lock
lever (purple tab) on the left side of the drum unit and lift the toner
cartridge out.
*Handle the toner cartridge carefully. If toner scatters on your and or
clothes, immediately wipe it off wash it with cold water.
8. If there is paper in the drum unit, gently remove it.
9. Examine the inside of the printer where the drum was installed. If
there is paper inside the printer carefully remove it.
10. Reset the toner cartridge into the drum unit (be sure it clicks
into place).
11. Reinstall the drum/toner assembly into the printer.
Posted on Jan 27, 2009
  • Anand Kumar
    Anand Kumar Jan 27, 2009
    then try to print test page:
    1. Turn the printer power switch OFF. Check that the front cover is
    closed.
    2. Turn the printer power switch ON while holding down the GO button.
    3. Continue holding the GO button until only the Toner, Drum and Paper
    LEDs will are lit.
    4. Release the GO button and all LEDs will be off.
    5. Press the GO button 1 time. The Ready LED will flash and then the
    internal test page will be printed.
  • 86 Answers
Instructions to clean the printer drum:
http://www.instructables.com/id/How_to_clean_the_printer_drum_cartridge/
however, by the description the problem could be bigger.
    Sergeant:
  • 221 Answers
No its not the drum problem.the drum is in the toner cartridge itself.it is not the problem.the problem is either rthe rollers which pulls the paper.or the sensor which detects the paper in the tray.that sensor is turned faulty.or broken or moved from its position.
Orange blinking light hp laserjet 1600
this signal issue mean any paper jam or toner cartridge end remaining or end of drum, transfer belt life
Jul 12, 2014 | HP LaserJet 1600 Printer
Brothers HL-5370DW. Yesterday, I printed about 20 sheets with no problem. Then I set up to print more pages and the yellow paper light started blinking and the red status light came on. I checked for a...
I had the misfortune of between two sheets of paper, out of the packet, there was a piece of tape that jammed the drum.
Nothing else for it with your, take the drum and toner out and check for bits of paper.
Mar 11, 2017 | Brother HL-5370DWT Laser Printer
Paper red light blinking. paper is full. What could be wrong? Will not print
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Jun 12, 2010 | Brother HL-2070N Laser Printer
Paper light keeps blinking, paper full, won't print
Paper light blinking could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Apr 12, 2010 | Brother HL-2040 Laser Printer
Red "Paper" light stays on; printer will not print.
Apr 11, 2010 | Brother HL-2040 Laser Printer
My Brother HL-2140 Went out in a storm. All three lights just keep blinking no matter what I do. Held down on the blue light button a number of time, restarted computer, turned off printer, reloaded ink...
You can find the usre's manual here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hl2140_all&dlid=&flang=English&type2=-1
1) If the LARGE BLUE BUTTON is blinking:
Data remaining in memory
There is remaining print data in the printer memory. If the Ready LED is blinking for
a long time and nothing has printed, press the Go button to print the remaining data
in the memory.
2) If the TONER LED is blinking:
Toner low
Indicates that the toner cartridge is nearly empty. Buy a new toner cartridge and have
it ready for when Toner life end is indicated.
The Toner LED will turn on for 2 seconds and off for 3 seconds.
3) If the DRUM LED is blinking:
Drum life end soon
The drum unit is near the end of its life. We recommend that you get a new drum unit
to replace the current one. See Replacing the drum unit on page 69.
The Drum LED will turn on for 2 seconds and off for 3 seconds.
4) If the RED ERROR LED is blinking:
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Mar 26, 2010 | Brother HL 2140 Laser Printer
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Red paper light blinking
To replace the drum, just pull out the toner cartridge from the front, the drum is the part DR-2025 that is connected to the cartridge. Push down the little purple lever and remove the cartridge from the drum.
Jan 26, 2009 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
