Question about Canon LBP3460/33ppm Laser Printer
My lg 3460 is displaying message" load lg plain paper"
Pc " load lg plain paper" this message is blinking in my printer and does not work. what i do now?
3 Suggested Answers
  • 30 Answers
SOURCE: I have problems printing from my computer to my printer - Printer Error Message
It sounds like the default tray it's expecting to pull paper from is out of paper.  Make sure the trays have paper, and that it isn't jammed.
Posted on Nov 06, 2008
  • 2692 Answers
SOURCE: Printer loads paper but does not print just ejects the paper
Dwnload and install new VISTA 64 driver dated 3-20-08.
Link below:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403#DownloadDetailAct
Posted on Feb 05, 2009
Told that this is a PCL5 type printer and can be used as a plug n'play, and no need to install a driver. It does work, but will not hold the programming. I only want to use Tray1.
the thing is that with plug and play equipment, when you plug it into the pc and turn it on Usb connections) , there is a small message just above the task bar which says installing driver for printer
it is the way that the pc recognizes the printer in a port
it may be best it you go to the control panel ,printers and devices , add a printer and install it properly
Oct 13, 2016 | Lexmark Office Equipment & Supplies
I cant get the printer to align what should i do
IssueA Printer alignment failed error message displays on the product.SolutionFollow these steps to resolve the issue.
  1. Load letter or A4 unused plain white paper into the input tray.
  2. Touch the Setup icon.
  3. Touch the down arrow button (c01093709.jpg) and select Tools.
  4. Touch the down arrow button (c01093709.jpg) and select Align Printer. The product calibrates, aligns the printhead, and prints an alignment page.
  5. Touch OK to close the message.
  6. Recycle or discard the alignment page.
CauseAn incorrect type of paper is loaded in the input tray. If colored paper or photo paper is loaded in the input tray when aligning the product, the alignment might fail.
Jul 21, 2011 | HP Photosmart D7460 Printer
Lexmark e352dn-load manual plain letter message
In most cases if the printer is asking for an unexpected manual feed it is because the paper tray is not set to the right paper size or type. To set the paper size to the most common size and type (letter size plain paper) use the following instructions.
1. Press the Menu button.
2. Press the right arrow key until Paper Menu then press Check Mark.
3. Press the right arrow key until Size/Type then press Check Mark.
4. Press the right arrow key until Tray 1 then press Check Mark.
5. Press the right or left arrow key until Letter then press Check Mark.
6. Press the right or left arrow key until Plain then press Check Mark.
7. Press the back button until Ready is displayed.
This will set up your printer tray for plain letter paper and should relieve the manual feed error unless yourcomputer is sending other paper size/type settings.
Aug 20, 2010 | Lexmark E352dn Laser Printer
On button steady e on display paper type plain
Remove the Cartridges,
Clean the contacts on Cartridges and inside Cartridge slot ( electrical contacts )
Install the Cartridges back into Cartridge slot
If that does not stop giving the "E" -
Disconnect the Power cord from bak of printer
Press and hold the Cancel and Plain paper type button and connect the cord holding the buttons.
Release the buttons after 3 seconds
If should go thru alignment process
Jun 22, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Message on printer printer calibration load plain
Well this is simple but iratating
There are paper feed from begining to end Im gonna say this is a manuel to static printer this is simple in the sense that you do not need to really do anything accept keep it clean. When you drop the paper in the printer you need too let feed dont stick it in there let it sit in the carrier and the printer should grab it if not You may have gotten a lemmon Take it back and tell them HEY IM NO ******!!!!!!!! You know that
Oct 18, 2009 | HP PhotoSmart 7960 InkJet Printer
Paper missmatch
Cause The HP all-in-one has a media sensor that checks the type of paper loaded before printing a fax. If the sensor detects that the paper is not plain paper, this message will display. The message may also display when the correct paper is loaded in the all-in-one, but the media sensor cover is displaced, distorted, or covered by debris. For more information and how to resolve this issue click here.
Apr 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My LaserJet4250n Printer keeps printing a page recurrently. Except the former job is cancelled Manually, it prints the previous instead of the currently sent job. Moreover,it displays the following...
I think what is happening is when you get the error, the printer automaticaly reprints the page it was on when it got an error condition that makes it think it didn't print the page correctly. The clearing paper path message comes up after it thinks it had a jam. Displaying load plain paper could be because either the printer is not configed for the correct type of paper you have in the tray you are trying to prin form(push the green check button, arrow downt to paper handling and see what your trays are set for.) Also there is a blue switch on the tay(looking for front of tray it will be on the right hand side of tray rail) the switch says standard or custom. The switch should be in the standard position.
Are you getting any errors or jams, if so, tell me what they are.
Feb 25, 2009 | HP LaserJet 4250n Printer
'Load plain paper' message
Make sure that you have set the same paper type on both the printer driver and on the printer itself, using the on-printer menu. When I get this message, I usually had forgotten to change the paper type on the printer.
Jul 30, 2008 | Dell 3000cn Laser Printer
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
Canon LBP3460/33ppm Laser Printer Logo
54 people viewed this question
old marine
old marine
