Question about Drills
Need anew chuck for a black & decker BD155RT Quattro 550w drill and advice on how to change it
How to change the chuck
    Champion:
  • 304 Answers
Remove the left hand screw from inside the chuck and then insert the chuck key onto the chuck, place the machine on a suitable work surface and give it a wack so that the chuck will unscrew off the drill anti clockwise.
Posted on Jan 29, 2013
  • 1214 Answers
SOURCE: how to change drill bit
Grab the end of the chuck in one hand, and the outer ring of the chuck nearer the motor, and twist the chuck end. try both directions until it loosens.
Posted on Jan 28, 2009
  • 3 Answers
SOURCE: How do I change the chuck on a 5 amp skil drill. It is keyless.
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Turn it clockwise until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Posted on Jun 24, 2009
  • 583 Answers
SOURCE: Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Posted on Aug 18, 2009
woobie dog
  • 1273 Answers
SOURCE: Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
bhiveranch
  • 5 Answers
SOURCE: black decker drill keyless chuck won.t open !
hold the back of the chuck with channel locks or a vice and use the same channel locks on the front and open the chuck manually it should work and you can get to the screw to replace it or the hand chuck. this can be a little frustrating but hang in there and you'll be a pro shortly.
Posted on Sep 02, 2009
Black & Decker Q200 not variable speed now??
if you took it apart to change the chuck you might have disconnected some wire id check that first
May 29, 2012 | Office Equipment & Supplies
Black & Decker cordless drill 9.6V chuck will not come off shaft
If it won't close the only other option you have is to break the outer collar and use a chisel to hit on the exposed jaws inside the chuck. I have detailed instructions in the tip section on how to remove a chuck from these drills. Let me know if you need more assistance.
Jan 31, 2012 | Black & Decker Drills
I bought a Black & Decker 7.2v cordless drill with
Just charge battery put bit in and your ready to go.
Jul 04, 2011 | Black & Decker Drills
The chuck is frozen on my 14,4 Black and Decker cordless drill. This is the second time that has happened with a Black and Decker drill so I assume it is a product defect. In use it was not that...
Yes, they are an inferior product. However you can replace the B & D chuck with a Jacobs chuck that will hold up and last for a long time!
Jacobs Chuck
heatman101
May 23, 2011 | Black & Decker Drills
How do I exchange bits in the keyless * BLACK & DECKER 12-Volt 3/8" Cordless Drill
In Black and Decker drills when the drill stops turning the chuck spindle locks automatically. All you have to do is grip the outer sleeve of the chuck and turn it anti clockwise to open it. Turn it clockwise to close it. When you press the trigger to start drilling the spindle unlocks automatically again.
Jan 10, 2011 | Black & Decker Garden
How to remove the chuck of Black & Decker Drill BD154R?
You need to open the chuck and remove the bolt from the bottom of it[usually a #2 phillips].The next step is to insert a 5/16 allen wrench into the chuck and tighten the chuck.Hold the drill with the chuck facing away from you then strike the allen wrench with a hammer on the right side[so it goes down] and now you will be able to remove it by hand,good luck.
Mar 21, 2010 | Rotary Ryobi 1/2" Hammer Drill ZRD551HK
My chuck wont open on my KD574CRE Black &
Try putting a vise grip on the bit,, and a big vise grip or chanel lock wrench on the key lock..
That should break it free..
Good luck..
Sep 10, 2009 | Black & Decker Drills
Keyless Chuck how do you change the bit? Model
hold outside collar on chuck firmly with your hand and reverse drill
Jul 10, 2009 | Black & Decker 3/8" Variable Speed...
Black & Decker Quattro, drill, won't tighten to grip drill bit.
give a good coating of oil then clamp chuck in a bench vice or alike and using short bursts with it set in the forward direction to free the chuck
Jul 07, 2009 | Hand Tools
How to change drill bit on black & decker plus pivot cordless drill How to change the bit on a Skil cordless screwdriver 2362 with a keyless check?
Jan 28, 2009 | Drills
Drills Logo
541 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
