Question about Archos USB transfer / charging cable for 80 G9
Usb diagram Archos 80g9 - Archos USB transfer / charging cable for 80 G9
How do I connect my Android Tablet to my Laptop ?
1. Connect the supplied USB cable to the ARCHOS.
2. Plug the USB end of the cable into your computer.
3. The ARCHOS will turn on and ask you if you want to connect it (Mount) or not. Choose to Mount it.
4. If you choose to just let it charge, you can always drag the top notification bar downwards to reveal the USB notification message and choose to connect.
5. The ARCHOS will appear in your computer's file browser as an external hard drive, ARCHOS (E:) for example.
More Information & Instructions about your Archos 28 here:
http://www.archos.com/manuals/A32_EN_v1.1.htm#zzee_link_1_1294043188
Sep 02, 2014 | Archos 28 Internet Tablet
How to change the battery in an archos 80 g9
very small scew under kick stand two more under feed opposet of kickstand screw driver catch latch left and right sides of achos logo pop open plug and play hope that helps :)
ooooh one more thing beware the only thing holding the usb port in is the screen it may slide out of place when you open the tablet its not supposed to be opened and is a little tricky to line up when your closing it again.
finaly only do this if the warntee is up archos will replace the internal batter for free if it is still under warantee
finaly the archos 101 battery also fits the 80g9 but very snugg it will however give you just shy of 48 hours constant use over the 15 hours that the 80g9 original battery will i had mine playing a 80 hours youtube play list for two days before it lost power and did not plug it in just to see how long it lasted roughly 53 hours i think
Mar 09, 2013 | Archos 605 WiFi Digital Media Player
How do I transfer my sermons from my laptop to my Archos 101?
2 ways:
1. Copy sermon files from laptop to USB drive, then mount USB drive to Archos, go to files, external drive, copy files to ARCHOS from USB drive.
2. Connect laptop to Archos with USB cable & copy or drag files from laptop to Archos
Note: You will then need a reader / Office Suite/ or other app to view the sermon files. I assume the files are .doc files. Excellent app for this is Docs to Go.
Dec 26, 2010 | Archos 101 Internet Tablet 16GB 10.1"...
Archos won't connect by USB to computers
You should keep your eye on the device after its been plugged to the PC it will give you 2 options "charge" or "usb" you ca not establish a connection without picking usb connection option on the Archos screen when it pops up. If you are doing so and problem still existed then i would recommend you to download the latest windows media player. Because it comes with new devices sync driver update.
Aug 10, 2009 | Archos 605 Wifi Portable Multimedia Player
Archos AV500 / USB harddive
from what i gathered with my archos 5 it is due to a power issue so the archos does not provide enough power to make the external hd work
Mar 08, 2009 | Archos 605 WiFi Digital Media Player
Transfer file to Archos 5 using usb port on DVR Station Dock
On your Archos 5 go into tools -> Files and you should have two Archos 5 tabs. Change one to your USB stick and the other to the Archos 5 and copy and paste. I have not tested this, but this should work.  Good Luck.
www.blogger.usarchos.com
Jan 31, 2009 | Archos DVR Station for Select Portable...
Archos 404
Did you click menu button and enable usb on the Archos?
May 26, 2008 | Archos 404 Digital Media Player
Archos not recognised by both my computers
You must update the firmware on the archos.
Dec 07, 2007 | Archos 605 Digital Media Player
Archos USB transfer / charging cable for 80 G9 Logo
18 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
