Question about Bradford White M240s6ds-1ncww 40 Gallon Electric Water Heater - Sh
Too much hot water, how to adjust water temperature
  • M. O.
    M. O. Jan 24, 2013
    Really helped, thanks.
  • Bradford White Master
  • 5,245 Answers
1) Copy following links:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
2) if you have electric water heater, and too much hot water, then thermostat may be bad, or element is shorted and needs replacement. Test elements first, and if they're ok then replace both thermostats.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jan 22, 2013
Water heater
Most instant-on tankless water heaters require at least 10 psi of water pressure to start the heating process. The flow of water determines how hot the water will be, within the heating range. An electric 110 volts heater will increase the water temperature about 25 degrees F. A gas water heater will increase the water temperature about 45 degrees F.
Too much flow will not allow the water time to heat. Too little flow will not allow the heating system to work. Each heater must have the outflow water flow adjusted for the best heating outcomes. The best way to find the ideal flow is to turn the hot water facet on and adjust it (open or close) until the water reaches the balance of producing hot water.
Apr 25, 2016 | Water Water Heaters
Water heats up then trips off red button
The lit red button may be an indicator that the water temperature inside the water heater flow channel has become too hot. If the outflow facet is adjusted to allow more water outflow (opened more) the water temperature should drop some and therefore with increased water flow, the temperature inside the water heater will also decrease. Or, if there is a manually adjustable outflow valve on the water heater, adjusting it to a more open position would also decrease the internal temperature.
Sep 17, 2015 | Water Water Heaters
Why do we need to have to continuously adjust the temperature of the water when we're taking a shower. We have a new Rheem gas .hot water tank
It *may* not be a problem with the water heater itself necessarily. When you say "keep adjusting the water temperature when you're taking a shower" I presume you're talking about turning the shower hot/cold knob(s) and not the temp thermostat on the water heater itself.
If so, when it starts to run colder, turn the knob all the way to full hot. Is the water then very hot? If so, the water heater is working fine & doing its job, and the problem is likely to be in the shower faucet mixing valve itself. Sometimes a faulty one will expand the inner seals/cartridge as hot water flows thru it, and starts to (wrongly) restrict the hot water flow, thus causing the constant need to "turn the dial up a notch".
Oct 29, 2014 | Rheem Water Heaters
How to adjust hot water Gets too hot
Check you data plate. The inlet temperature must match the machine requirements, which means that your incoming water is too hot and the water heater temperature needs to be turned down. Here is a link to a installation/service manual. http://www.webstaurantstore.com/documents/pdf/wareforce_cg_service_manual.pdf
Apr 17, 2014 | Wareforce CG Underbar Glass Washer...
Rheem 21vp40 1
Copy following links to identify type of thermostat, and see how to adjust temperature on that specific thermostat, and see other ways to increase amount of hot water
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
http://waterheatertimer.org/Increase-amount-of-hot-water.html
Add a comment and describe if water heater is gas or electric, and add what other problems you are experiencing.
Jul 14, 2013 | Water Heaters
Not enough hot water ge smartwater water heater gas
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/Crossover.html
2) Low temperature setting, extremely cold incoming water, Water leak or broken pipe running hot out of tank, crossover caused by bad faucet cartridge or bad recircirculation check valve,, bad gas control valve thermostat.
Feb 19, 2013 | General Electric GE SmartWater Household...
I have an Atwood GGA-8E about 6 months old was getting hot water but now the water is only luke warm, any adjustments?
There should be a temperature setting on the gas valve. It should be on top or front and have several settings normally vacation, warm and hot. Rotate dial towards hot setting to increase water temperature. Hope this helps. Thanks
Nov 17, 2010 | RTO Atwood Water Heater - 6 Gal LP
I need to adjust water temperature, and dont have a manual. i have a 81v40d C model , 40 gal electric.
Here is a tip that I wrote to help people understand how to adjust the temperature on their electric hot water heater.
Electric Hot Water Heater Temperature Adjustment
heatman101
Oct 16, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water not hot enough
Check out this tip about adjusting the water temperature on electric hot water heaters...
heatman101
Oct 11, 2010 | RELIANCE ELECTRIC WATER HEATER
Bradford White M240s6ds-1ncww 40 Gallon Electric Water Heater - Sh Logo
226 people viewed this question
Top Bradford White Water Heaters Experts
Gene Haynes
Mack Baxter
David Spradling
David Spradling
Are you a Bradford White Water Heater Expert? Answer questions, earn points and help others
