Question about Ingersoll Rand 2340/2475 Electric Air Compressor Start Up Kit 32305880
Correct rotation of copressor
Installed new motor which can be wired for either direction. there is no indicator arrow on unit anywhere to indicate correct rotation. Viewing from pulley side , clockwise or counterclockwise rotation ? Ingersol rand model 2475-7.5 hp.
    President:
  • Ingersoll Master
  • 1,388 Answers
Checked all the IR compressors in stock and all turn counter-clockwise facing pulley, however you could check the pump for fan angle on pulley. The fan on the compressor pulley blows air towards the pump. Generally, pumps turn CC because that would allow for the use of gasoline engines which all turn CC. Please email you questions, and Good Luck.
Posted on Jan 27, 2009
What is code 67 on a LG PTAC
Hi Jason, The link below is a web page, Click the 4th down for an LG Ductless HVAC & PTAC Error Codes manual.....
https://www.google.com.au/search?q=LG+PTAC&oq=LG+PTAC&aqs=chrome..69i57j69i61&sourceid=chrome&ie=UTF-8#q=LG+PTAC+error+codes
Code 67 ODU fan motor not rotating or proving rotation. Verify fan motor plugged in correctly & fan rotates freely. This can be a failed motor, failed board or motor could have failed and caused board failure as well. Verify 310V DC on motor wires separated by empty terminals on plug with motor plugged in, 0V DC = failed PCB, 310V DC = likely failed motor. Next step: Unplug motor and manually spin the fan (keep it spinning): on same wires you just tested, 0V DC indicates motor failed and caused board failure. 14-30V DC indicates a good motor
Mar 31, 2016 | LG Heating & Cooling
Firing oder on 1998 5.7 vortec and also on cap
The distributor cap will have a "1" stamped on the top to indicate CYLINDER 1, and will have an arrow indicating direction of rotor rotation.
There will be a sticker affixed to the inside of your engine compartment, listing your correct FIRING ORDER.
May 14, 2015 | Cars & Trucks
Ck rotation motor
Controller sensing wrong rotation of compressor. The 220 volt 1 Phase motor rotation can be changed. If this is a new compressor check to make sure all vacuum lines are tight and not cracked. The rotation error is caused by the lack of vacuum to the avpt transducer. The transducer may also be bad or not connected properly. check the connections to the transducer. Wiring and plastic vacuum line. If this is a unit that has had the motor replaced visually verify rotation of the motor. Rotation arrows should be on the unit. I believe rotation should be clock wise. If it is indeed motor rotation incorrect the motor tag should show the correct internal motor connections to make the motor rotation change> If not comfortable take it to a trusted motor shop.
Apr 28, 2014 | Ingersoll Rand Compressor, 5Hp 80 Vert...
I have a new A O Smith B861 motor I want to
Thank you for posting your question here on Fixya.com.
I am not sure what you mean by "center wire". For 230V single phase you should have 2 hot line leads (115V each) and a ground wire. Set the motor leads as the nameplate shows for the high voltage connection and attach your line leads where the two lines are indicated. If you have a 3+Grd wire drop DO NOT connect the neutral, insulate it and leave it unconnected. It will not matter which line lead connects to which motor line wire as far as rotation direction. To change rotation, if the motor allows it, you reverse the start winding leads as directed on your nameplate.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Sep 17, 2010 | AO Smith A O Smith Motors A O Smith 2hp...
On my standard motorguide trolling motor the direction indicator points one way my motor goes the opposite direction. How do I fix this?
put the motor in the water and ensure that the propeller is at the rear. On the head of the unit (where the direction indicator is) push down and turn the round plastic plate (this plate has the direction indicator on it) clockwise until the direction indicator mark (mine is blue and is about one inch long) is in line with the alignment bar on the non-moveable part on the head. You will hear several "clicks" and this means that the indicator plate is clicking around to the proper directional alignment with the motor in the water.
Jun 13, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Roaring is heard from front end when going speed
I have a 98 Ponitac Grand Prix GT. Soon as you start going it starts roaring. Gets loader the faster you go till 70 mph. When I am turning to the right a little while going 60 mph the sounds quiets down. Only to the right. I have replaced both wheel bearings, got brand new tires, new brakes. Didnt stop the roaring. Would it be cv axles, rack & pinion, transmission, etc?
May 19, 2010 | Cars & Trucks
IMAGERUNNER 2000 SYSTEM E100
This can be caused by the following....
*When the laser scanner motor is started up, the BD input signal does not arrive within a specific period of time.
*When the scanner motor is started up, the motor rotation is too fast, and fails to reach a specific revolution within 20 sec at time of deceleration.
*While the scanner motor is rotating at a specific speed, the BD input signal cycle is not within a specific range (±2%) for an equivalent of 10 mm (print distance).
*While the scanner motor is rotating at a specific speed, the BD input signal cycle is not as indicated (±2%).
*During the WMUPR period after the power switch has been turned on or the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause:
  • The wiring is faulty (short circuit, open circuit).
  • The laser scanner unit is faulty.
  • The DC controller PCB is faulty.
  • The drum unit is not installed.
Remedy
1) Drum unit
Is the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB.
Apr 15, 2010 | Canon imageRUNNER 2000 Copier
Ir 1600 . e100
When the scanner motor is started up, the BD input signal does not arrive
distance).
During the period after the power switch has been turned on or
Possible cause The wiring is faulty (short circuit, open circuit). The laser scanner unit is
faulty. The DC controller PCB is faulty. The drum unit is not installed
Mar 30, 2010 | Canon ImageRunner 1600 Copier
I have a motorguide trolling motor and the front
With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Mar 09, 2010 | MotorGuide Standard Motor Replacement...
I got canon ir1600 i am receiving an error msg as error 100
as sm -
E100
distance).
Possible cause
faulty. The DC controller PCB is faulty. The drum unit is not installed.
Remedy
1) Drum unit
2) Connection
YES : End.
Jun 04, 2009 | Canon ImageRunner 1600 Copier
Ingersoll Rand 2340/2475 Electric Air Compressor Start Up Kit 32305880 Logo
1,086 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
