Question about Pentax Optio Cameras
How do i change battery pentax optio e65
Have not got the manual how do i change the battery?
    Genius:
  • 1,019 Answers
Just do a web search, Type: pentax optio e65 user manual
You will be able to download a free copy of the manual.
Posted on Jan 25, 2013
SOURCE: Depleted Batteries
I had the same problem...
I tried several different types of batteries.
The only one that I found that works is rechargeable batteries.
I am using the ones that came with my Logitech mouse/keboard, so, I just use the mouse to recharge the batteries when needed.
Other rechargeables don't work...
these are :
Ni-MH AA 1400 mAh 1.2 volt
made by L&K
Posted on Nov 23, 2007
SOURCE: Pentax Optio M30 won't turn on!
MY CAMERA WONT TURN ON... I HAVE CHARGED THE BATTERY SO I KNOW IT IS CHARGED...ANYONE HAVE THIS PROBLEM.?
CHERI
Posted on Oct 30, 2008
  • 16 Answers
SOURCE: Pentax e10 shuts off The pentax optio e10
You probably set the auto power-off for energy saving
Posted on Jul 23, 2009
  • 15 Answers
SOURCE: Windows vista not compatible with pentax optio 33l
If you're using an sd card or most other standard memory cards you can buy a card reader very cheaply and plug it into the usb of your computer, your computer may even have a reader built in
Posted on Sep 03, 2009
lock123
  • 6831 Answers
SOURCE: How to unlock card in pentax optio Says Card
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 22, 2010
Change language to english on pentax optio VS 20
Follow the instructions in the "Changing the Display Language" section of the manual (begin on page 183 in my copy). If you need a manual, you may download a copy here.
Jan 12, 2013 | Pentax Optio VS-20 Digital Camera - White
I need an English Pentax Optio E65 Manual
I can't find the Exact Model, but I found the E60 and they may be very similar or exactly the same, so here is the link to go download the manual http://www.pentax.jp/english/support/man-pdf/optio-e60.pdf hope this helps you!
Jun 13, 2012 | Cell Phones
Looking for Pentax Optio E65 software
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what said first, you can use any photo cataloging program such as Picasa.
Sep 14, 2010 | Pentax Optio E40 Digital Camera
Where do i get a spare battery shutterfor optio 50L
ggentertainment.com/Pentax/Pentax-Optio-50L/
www.shopping.com/xPO-Pentax-Pentax-D-LI88-Rechargeable-Lithium-Ion-Battery-for-the-Optio-P70-39774
Apr 04, 2010 | Pentax Optio 50L Digital Camera
Need manual for Pentax Optio 330
1. to buy manual online u can visit the following link :
http://manuals2go.com/gmanuals/pentax_optio_330_owner.htm
2. to download the manual visit this link :
http://www.azmanual.com/manual/3759/pentax-optio-330-camera-manual/
Mar 04, 2009 | Pentax Optio 330 Digital Camera
Pentax optio l 50
1.first switch off the camera
2.then take out the battery
3.clean the inside with a dry and clean cloth
4.again switch on the battery
5.try to select the white balance option again
6.if not,do the process again
it will surely work
Sep 24, 2008 | Pentax Optio 50 Digital Camera
Pentax optio e10
change the batteries. mine does this when the batteries are almost dead.
Dec 05, 2007 | Pentax Optio E10 Digital Camera
Cameras Logo
64 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
