Question about Square D 9037HG31 Closed Tank Float Switch
Have a closed tank float switch for a water well it works but cant make it turn on automatic
Have to positive wires were do they go.or how could i make it turn automatic.i have a square d no. 9037-891
Can I connect a mechanical tank float to the filtered water line of my HydroSense-0500? Will doing so damage the pumps?
You can connect the permeate line to a 3/8" tank float without any issues.
When the tank float valve blocks the water flow, the pressure will increase in the line until the high pressure switch shuts down the pumps. As the valve opens, the pumps will turn on automatically.
WECO HydroSense 0500 Light Commercial Reverse Osmosis Water Filter System
Mar 28, 2018 | Water Dispensing & Filtration
Dishwasher won't start
Try resetting the unit by shutting off the circuit breaker first for 1 minute then try the reset button. If nothing happens, then i would recommend having someone take a look at it.
Feb 09, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
WATER LEVEL FLOAT DEVICE PREVENTS UNIT FROM TURNING ON,EVEN THOUGH WATER TANK IS FULL. REMOVED SOME FILTER MATERIAL WITH NO EFFECT. FLOAT IS FREE WITH NO RESTRICTION.
These hints are from the air o swiss webpage.
Q: No mist / unit is not working / empty indicator keeps flashing
A: Fill up the water tank. Check if water is flowing through the demineralization cartridge (attached to the water tank cap). If the water tank is full but there is only little water in the base it indicates that the water is now flowing through the demineralization cartridge.
  • Wait for 15 minutes to allow the mist to come out of the unit.
  • If the unit is not working and the empty light is not flashing you might have set the desired humidity too low and the current humidity level in the room is higher. That is why the unit switches off automatically.
  • If the empty indicator continues flashing and the tank is full, water is not flowing through the cartridge. Exchange the cartridge or the granules in the cartridge after 2-3 months, in areas with hard water exchange the cartridge after 1 -2 months. However, the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit does not reach its full performance.
If the granules are new, see the following instructions:
  • Make sure the cartridge and/or granules were soaked for 24 hours, water takes longer to filter through dry granules in cartridge and into the base. Next, remove 2 tablespoons of granules from the cartridge, and throw them away. Too many granules in the cartridge it does not allow water to flow from the tank to the base.
If your issue is with the float and not the mister, then you have to make sure the float is tripping the micro switch that turns the machine on. Some units the filter will not allow the float to hit the switch if the filter is not installed correctly. If everything is in correctly and the float is tripping the switch, then the micro switch must be faulty.
Apr 04, 2011 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
LOW FUEL INDICATOR COMES ON 2004 GRAND PRIX EVEN WHEN TANK FULL
The low fuel sensor works on an open circuit. When you have a full tank, the float floats up, closing a micro-switch. With this switch closed, the circuit is complete and the light is off. When you get to a low fuel level, the float floats down, opening the micro-switch. This in turn sends a power signal to your dash, bringing the light on. Now if their is a broken wire in the system, it will act the same as the fuel level being low. As these wire are usually in a vulnerable spot underneath the vehicle, it is common for them to get damaged. Inspect the wiring first, and if nothing is found, suspect the micro switch could possibly be stuck closed and/or faulty itself. Goodluck, please let me know how you go with the problem.
Jan 23, 2011 | Pontiac Grand Prix Cars & Trucks
The machine will say Fill water tank. So, we will take the container out of the machine fill it to or just a little above the recommended line and then put it back into the machine. It will be full and it...
After filling the water tank, can you see if a grey plastic piece, in the back of the water tank, is floating?. If no, then that part needs to be replaced. If it does float, then the integrity of the water sensor, (located in the back of where the water tank is housed into), will need to be tested. Testing this sensor requires, tricking the coffee maker... that the door is closed. With Coffee Maker in the "ON" position, you will need to hold door switch in (located top right corner of unit, with door opened). As switched is held in, you will need to use a magnet and place it around the rear of where the water tank is housed into (Rear-left middle height area)... just around where the water tank float would be, if it were filled with water and inserted into the coffee maker. This sensor isn't visible, but is activated when a magnet is placed around it. If "FILL WATERTANK" message goes away, then replace plastic float or water tank itself.
Nov 16, 2010 | Miele CVA615 Espresso Machine
Water gtank full telling me to fill water tank
Hi
Check an see if you have the magnet in your water tank. That is your signal to the computer that it is full if it is at the top of its chamber. If you don't have a magnet ( gray cylinder) in the water tank that is your problem. If it is on the bottom the magnet needs to be replaced.
Jun 12, 2009 | Saeco Magic Comfort Plus Espresso Machine
How is float switch testing and troubleshooting ?
I use a float switch to automatically top off the water in my fishtank.  the best method I can suggest for testing the unit is to get an extension cord that you are comfortable with cutting.  Cut one of the 2 wires of the extension cord, and put the float switch in-line on this one cut wire.  Be sure to use wire nuts or something that can cover up the exposed connections where the float switch connects to the extension cord.  Once everything is buttoned up, plug the extension cord into an outlet and plug a small device which does not require much power into the other end of the extension cord, a small nightlight or something would work great.  Now move the float up and down on it's shaft to see if the connection is established to power the device.  This is essentially the same configuration that I use for my fish tank topoff and the deivce at the end of the extension cord is a pump which sits in a rubbermaid full of water.  Works great!!  Hope this helps.
Regards,
Joe
May 07, 2009 | Zoeller 10-0034 Switch-Mate Pump Float...
I cant get it to ****
This is from the owners manual that I have provided a link to, so that you can have a copy for your records. I hope this helps.
http://www.bissell.com/images/UserGuides/9500_908.pdf
Possible Causes Remedies 1. ReadyTools dial may be at wrong setting. 1. Set ReadyTools dial to either FLOOR CLEANING or TOOLS setting. 2. Tank may not be seated properly. 2. Pick up both the 2-in-1 water tank and formula tank and reseat them so they fit snugly on the unit. 3. Tank may not be assembled properly. 3. Check to make sure the "lip" of the nozzle is securely hooked into the groove on bottom of Tank (see page 9). 4. Solution or 2-in-1 water tank is empty. 4. Check fluid levels in heavy duty bladder and formula tank. 5. 2-in-1 water tank has picked up 5. Empty 2-in-1 water tank. Refill maximum dirty water and red float heavy duty bladder with clean door has closed. hot tap water and replace. 6. Red float "door" in the tank may have closed 6. Turn the machine OFF ( O ), as a result of bumping an object or moving allowing red float door to release into machine back and forth too quickly. the open position. Turn unit back ON ( I ) to continue cleaning. Be sure your forward and backward strokes are done at a slower pace.
Jan 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water tank level indicator sinks to the bottom when water tank is full.
I think the float is up and down, try to take it out and turn it.
Look at the float in the other tank to see if it is same position, the rounded side should be down.
Let me know if you get it to work.
Best regards
/Mirran
Sep 04, 2008 | Saeco Royal Cappuccino Espresso Machine
Red light is flashing continuesly
Ok I found a temporary solution. I opened up the unit (yes there are a lot of screws) I checked the float switches and they worked and even unplugging the water level wire connection to the main board did not get rid of the red flashing light. But if you unplugged the connection from the front panel to the main board but leave the infrared remote still plugged in the main lights and control are not on but you can still work the unit by remote. When in this configuration the compressor will come on and the unit will cool. So I think that part of the problem is on the front panel circuit board or maybe somewhere on the main board. But physically the compressor/relay/ switches work. A short term solution until I can get a new board.
Cheers!
Jun 10, 2008 | Danby Portable Air Conditioner
Square D 9037HG31 Closed Tank Float Switch Logo
26 people viewed this question
Top Square D Plumbing Experts
Paul Carew
Tom Chichester
Are you a Square D Plumbing Expert? Answer questions, earn points and help others
