Question about Acer Aspire 3690-2196 Notebook
Hello I've got this problem. when my computer running, sometimes my screen go white screen and i can't see at all to the windows, just white screen. but all function is ok so i press power button to force shutdown and start again with normal screen condition what happen to my laptop..??? what is connection between white screen and hardware condition..???
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 53 Answers
Got this from a friend: Apparently some series of Acer notebook came with BAD_EDID laptop display. The only thing wrong is the checksum which is 9D and should be 1D. Powerstrip 3.76 (registered version) managed automatically to correct EDID.
There is no problem with drivers from 101.x series, but with any newer driver max. resolution is 1024x768 and the picture is in left upper corner of the screen with black bar on the right and smudged taskbar to the bottom of the screen. After installing and restarting resolution is set to 800x600 what results in white screen whit thick black bar slowly appearing on the screen.
Posted on Feb 05, 2009
3 Suggested Answers
  • 237 Answers
SOURCE: white blank on acer 4315
First things first, are there any cracks or visible damage on your lcd screen? do you think you've had the same button before the screen goes completely white? Check your screensaver and display settings to make sure it is not set on a white screen. Second, have you tried to reset your monitor using your screen controls such as brightness settings, contrast, colors, etc. Also, try to reset it to factory mode.
Lastly, is there a particular program you are using that occurs when the screen blanks out?
If all this checks out and is not the problem...use our chat live now, so we can further diagnose the problem with you to distinguish whether it is a hardware or software issue.
Posted on Nov 17, 2008
  • 10 Answers
It sounds like a Bios issue.
Go to http://support.acer-euro.com/drivers/notebook/as_4315.html
Download the latest Bios for the windows you are currently running and follow the Readme.txt and update the bios.
Hopefully this will fix the issue that is connect with the monitor and power setting in the bios.
Please Rate, Thanks.
Posted on Jan 06, 2009
Ax1200 u1711a
HAVE YOU TRY SAFE MODE AND RUN SFC / SCANNOW
OR CHECKDISK .CHKDSK /F/R AS A ADMINISTRATOR.
Jul 08, 2013 | Computers & Internet
My Acer laptop will not boot up.
You may have a corrupted video driver due to an update. For some Acers, press and hold F10 when starting the computer. Two beeps will mean that the bios settings have been restored and the machine may boot correctly. If you can enter the BIOS via F2, F1, F10, ESC or DEL, then find the area for display and change it to low resolution then save and restart your computer. Once running, you will need to uninstall the current video driver and have the computer install a new one.
Mar 18, 2017 | Acer Aspire 5736z 4460 Laptop
My 531S hangs at the dell splash screen with one short beep before loading windows vista
I would start the computer in safe mode. To do this, keep tapping on the F8 key as you start the computer. Do this as soon as you see anything on the screen. If you get the windows splash screen, you've waited too long. Once you get the white menu on a black screen, choose safe mode and let it start. The next time you do a restart, it should work. If it doesn't, then in safe mode do a system restore back to the time it worked.
Apr 06, 2012 | Dell I531S-2809 PC Desktop
Electric window goes up crooked
Hello there patsey! I've seen this many times before. It sounds like a window track problem. The window glass rides up and down inside the trackwork channels. Those channels sometimes bend or break and cause the window to run crooked. You wont really know for sure what the exact problem is until the inner door panel is removed so you can inspect it. Best case scenario is the track bolts have come loose and just need tightening ($50-$60 repair). Worse case scenario is that the entire window track or window regulator assembly needs replacing. This can sometimes run upwards of $200 or more. BTW, removal of the door panel just to inspect it should run no more than around $30- $40. Hope this helps.
Oct 06, 2011 | 2000 Pontiac Montana
Hi, i have a samsung notebook, recently it has started to go into a blank, white screen, sometimes it stays like that sometimes it goes on and off. i've tried to install a new anti virus software but...
I would reboot into safe mode, then run your anti-virus/anti-spyware software again, then try rebooting in regular mode and see if that fixes the issue. It sounds like it could be a hardware issue, though... possibly a loose connection or faulty screen, if the virus/spyware search doesn't pan out.
May 18, 2011 | Computers & Internet
White blank on acer 4315
Jan 06, 2009 | Acer Aspire 4315 Notebook
Windows wont load
is your computer set to boot from cd?
Jun 01, 2008 | Computers & Internet
Acer Aspire 3690-2196 Notebook Logo
547 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
