Question about RCA F38310 38" TV
Tv antenna the tv that i have RCA F38310 does not receive signal from both antennas A or B.
  • Anonymous Mar 13, 2014
    my rca model f38310 hd direct tv has no sound
  • 87 Answers
Press menu on the remote. Press the cursor up or down button untill the word CC is highlighted. Press the cursor right button to select Closed Caption 1. You will likely have to do this with the original remote. A universal remote may not allow you to do this.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Jul 23, 2007
  • Dewayne Turner Jul 23, 2007
    Sorry, the above solution was not for this set.
RCA HDTV antenna is it Ok on a non HDTV
Yes, this antenna will receive VHF and UHF signals. If you install it properly outside and point it towards your local transmitters, it will work nicely (use tvfool.com for the directions to your transmitters). The "HD" label is something of a marketing gimmick; the tuner on the TV will pull in the signal and interpret ito display on your TV.
However, make sure that you have an ATSC tuner for your TV. Only a few low power NTSC stations are still broadcasting.
I hope this helps.
Apr 15, 2013 | RCA Televison & Video
"How do I get this to receive free HD antenna TV?
You will need a antenna and a digital converter box to convert digital to an analog signal the TV can understand.
Oct 20, 2012 | RCA F27440 27" TV
I have a RCA D52W20 rear projection HDTV. This TV was purchased in2005. I cancelled my cable and I just hooked up a digital antenna but the TV isn't finding any channels. What do I need to do? I was...
HDTV indicates the number of lines that are shown by the TV. (HD means that at least 720 lines can be displayed in a given picture.) To receive OTA signals, you need an ATSC tuner (digital) of sufficient power (with a clear path to the transmitter) these days. The RCA D52W20 was released in 2002 and only has an NTSC (analog tuner). You will need a digital-to-analog converter to receive OTA TV (unless any low power analog stations remain in your area).
Please note that the basic digital-to-analog converters that were available with the government coupon back in 2009 were SD (480i lines of pixels used) units. HD d-t-a converters exist but are more expensive.
I hope this helps.
(the phrase "digital antenna" is meaningless; check with tvfool.com or antennaweb.org for the direction of local transmitters. TVfool.com will give more information on the type of antenna (indoor, outdoor, amplifier) that you will need to receive channels in your area. Antennaweb assumes an external antenna but is very conservative in the stations that it will indicate that you can receive. Antennas are given a color rating based on how far away the transmitter can be to get a watchable signal. Since digital signals are either enough for the tuner to interpret or you get a "no signal" message, you often need a stronger signal than was needed to receive a watchable analog channel.)
Sep 27, 2011 | RCA Televison & Video
What antenna do you recommend wit the RCA 20F510TD
This tv has an analog tuner so you will need a digital-to-analog tuner set-top box (assuming you live in an area where most stations have been converted to digital TV broadcast). Whichever tuner you use, the recommended antenna will depend on where you live and how many tall objects are between you and the transmitters. Go to antennaweb.org or tvfool.com and type in your address. Antennaweb assumes an external antenna but is still very conservative in the channels it will identify as watchable in your area. Tvfool.com lists the channels by direction and the antenna type (by color) you will need to receive them. The color rating is based on how far the stations signal travels to reach your location. An amplifier can help you receive stations that are marginal to your location. (Digital signals are sufficient for the TV to tune them in or you get "no signal" messages.)
I hope this helps.
(I'm in a rural area with an external antenna with a signal splitter/amplifier. Antennaweb suggests I will only get the stations ~10 miles away. In fact I get the stations from there as well as the ones ~30 miles away.)
Sep 11, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
SETUP RCA F38310 TO DISH NETWORK
using your Dish Network box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. Or you can connect your Sattelite to the antenna A or B input jack on the back of the set and set the tv input to antenna
Apr 14, 2009 | RCA F38310 38" TV
Rca television (f38310)
using your cable box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. If you do not have a cable box you can connect your cable to the antenna A or B input jack on the back of the set and set the tv input to antenna
Mar 23, 2009 | RCA F38310 38" TV
Is the f38310 digital ready or do I need a converter?
No you do not need a converter box your television is digital ready. I use mine with a regular antenna and recieve many channels mostly High Definition and some analog you should notice that when your hooked to a quality HD antenna and assuming you are within broadcast distance you will be very surprised at the quality you will no longer have blury or faded pictures they will be crystal clear. This is because digital broadcast is either there or it's not. no inbetween although you can get what is called speckling thats where little dots pop up randomly the best olution to this problem is buy an additional antenna and run both antennas in through a splitter and this should clear that problem up redundancy is the answer
Hope this helps
Nov 10, 2008 | RCA F38310 38" TV
Indoor antenna problems
I don't know the menu system on your model, but you have to check that the tuner is in the proper mode. Also, some of the new TV set models cannot receive a standard analog TV signal from its tuner.
As for the distance from the transmitter sight, this depends mostly on the antenna quality, antenna location, the power output of the transmitter sight, compatiblity of the TV to the received signal, and also the capability of the TV's tuner.
Modern TV sets are really designed to be used with a satellite or cable TV box with their respective service.
Terrestrial TV is dying out, and in a matter of a number of years, it will be gone.
Jerry G.
May 24, 2008 | RCA F25645 25" TV
RCA F38310 38" TV Logo
87 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
