Question about Panasonic PT-47WX49 47" Rear Projection Television
I replaced the bad capacitor and now!?
Whats the deal, can anybody help? it used to turn off after a couple of seconds and thats it no picture no sound, now when it turn it on it continues to click over and over in the fly back! i pulled the flyback out. am i on the right path? all the tv repair men i've called want me to bring it in or throw it away. can anyone help?
  • Gene'O Turney Jul 23, 2007
    yes it was close to the flyback. i replaced it and now it keeps clicking.how do i know which one is a regulator
  • 41 Answers
Are you sure the flyback was clicking? Usually it arc's inside or externally to metal chassis. There is a relay that clicks on & off , which could be what you are hearing. Your bad cap, is it in the power supply or near the flyback? A regulator is more of a possibility than the flyback.
Posted on Jul 22, 2007
SOURCE:
My vi 42 in led lcd vizio works great for like 30 mins to an hour then the picture disapears but the audio is still intact and playing whats the issue has anybody else had this issue the tv is less than a...
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
or you have faulty t-con board..
Jun 19, 2012 | Vizio Televison & Video
Not turnin on but got sound
Good day!!!!
Jun 06, 2012 | Zenith R57W46 57" Rear Projection...
RCA R52WH74 that will shut itself off
Replace 3 capacitors on Deflection board its the bottom left hand side cp150 200uf 16v use 25v capacitor and cp114 cp120 in same circuit 220uf 35v. You will see cap cp150 if it is puffed up on top they are Bad. Call Mats Electronis 1-800-628-1118 Radio shack might have capacitors.
Dec 29, 2009 | RCA R52WH73 Projection Television
Sharp lc-26d40u No picture
I have a Sharp Aquos LC-40E77UN with the same issue, and have tracked down a single burned capacitor at C7816 on the power supply board, and am looking for info on the capacitor in order to replace it. (Power supply: RDENCA354WJQZ / Delta DPS 208BPA). - Any help with a schematic would be appreciated!)
Since you say the picture went out, it is possible that you might have the same problem, Bad/failed/leaking capacitors are, unfortunately, quite common in electronics. There are volumes of info available on the subject.
Replacement power boards can also be purchased. One for my TV runs about $60 to $120 depending on used or new. Since I was able to see a good picture on mine for a few seconds, despite the burnt out capacitor, I'm opting to try and find/replace the cap myself (using the proper safety procedures), or at worst, have a repair done to the power supply.
Backlights should typically last around 60,000 hours.
Aug 29, 2009 | Sharp LC-26D40U 26 in. LCD HDTV
When i turn on my tv, after 5 seconds it will turn off..
If it is an LCD (not DLP), there is likely a problem in the power supply /and or inverter circuit that drives the ccfl backlights. It is sensing a problem and shutting down to prevent further damage. Bad electrolytic capacitors are a common fault. They usually bulge at the top and chemical leaks out. These degraded capacitors wil cause unstable operation, and shutdown. www.badcaps.net/forum is a great resource for information.
May 29, 2009 | Samsung Televison & Video
Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Apr 07, 2009 | Sharp LC20SH7U Television
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Won't power on....
I think I have the same problem, If I don't use it for a couple of days, then try to turn it on, nothing. I turn it off, and on one more time, it works. WEIRD
Jan 10, 2007 | Polaroid FLM-2601 Television
Display goes blank when brightness is above 70 percent
This is a generic symptom that could happen to any LCD monitor.
The following is a generic answer applicable to most.
Two possible causes are bad capacitors or a bad light inside the LCD panel.
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad. Check the area for any cracked or overheated ceramic or mylar capacitors.
Also, you may have a bad light inside the panel. This is tough to test without a spare light to use for troubleshooting.
You can take the panel apart and inspect the lamps but it is very tedious. It's tough enough to get them apart and back together again never mind keeping the layers clean. You have to try not to get any dust between the layers or you will see it in the picture.
There are usually two light fixtures each of which holds two lamps. One fixture is at the top and one at the bottom. Remove them one at a time and inspect the lamps to see if any are broken or very dark on the ends. If one looks out of place, it could be bad.
You'll have to find replacement lights on the net. It's not easy to replace them, but if you've gone this far, good luck. You should be able to get generic instructions off of the site that sells the lamps.
Aug 10, 2006 | Mag Innovision LT776s 17" LCD Monitor
Panasonic PT-47WX49 47" Rear Projection Television Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
