Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Dishwasher leaks at top of sink
There is a tube coming from the dishwasher that connects at a "Y" continues up to top of sink, the other goes to the garbage disposal. during the final rinse, water comes out of the top of sink. Not sure why the valve at the top of sink. looks like it should have been a soap dispenser...
  • 31 Answers
Hi some old dishwasherhas that y ,,,,,,the y is there so when washer drains it does not go bact to the machine,,,,,,,,some times the pipe that goes from y to disposer gets clugged and you can turn the hole tourd the sink the drain into sink
Posted on Oct 02, 2009
Top sprayer is not cleaning dishes. No water is coming out on the dishes.
There may be one of two problems here and you're going to have to stick your head inside the dishwasher to solve either of them by yourself. First, in the back of the washer is a tube that goes up to the top shelf. The sprayer tube fits OVER the mouth of the other tube and then carries the water to the arm. Sometimes the support brackets for this tube become dislodged and the sprayer tube just droops but doesn't connect with the water tube. Check this first and reattach the brackets.
If this is not the problem, you might have to remove the sprayer arm (should be a screw or bolt under the arm) and flush it at the sink. There may also be pieces of paper or fragments of bone or fruit and vegetable peels stuck in the spray openings. If these won't slush out, you'll need to remove them with tweezers.
I hope this helps. It always works for me. If I have helpee, please come back and rate my suggestion!
Jun 07, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
My badger 5 plus 5/8 HP HD insinkerator is leaking from the bottom of the unit. It is dripping from the reset button and one other metal tab location. It is at least 10 years old. Can it be repared?
Sorry to read about your problem, I hope this helps you out.
sorry no it is rusted out, even if you could take apart, after 10 years 1/2 the parts will be rusted..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.
Thanks and good luck. you are looking around $90.00 for a new unit
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My in-sink-erator model 5-81 is just over 2 years old and is leaking from the sides whether it's running or not. Is there anything I can do or do I need to contact a professional>
Find out exactly where leak is coming from.
You say water is coming from the side... is that where the pipe connects? Then take apart pipe and reassemble pipe using instructions below, and use rectorseal on joints as described below..
Is water coming from where dishwasher connects to disposal? Then tighten the clamp.
Is water coming from top where disposal connects to sink? Run paper towel around top to check for moisture, and then use steps below to dissemble disposal and re-install same disposal.
Is water coming from a rusted hole in disposal. Then replace disposal using steps below:
Here are the disposal steps:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or change pipes.
How to: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Before installing new disposal.
Attach electric wire to new disposal.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Apply good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment
Dec 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leaking from the bottom of the disposal in the connection area.
Disposals rust out and need replacement.
Check a couple things first.
Run paper towel around top of disposal to see if moisture is leaking from around sink basket or dishwasher hose connection. Then check where tailpiece connects on side of disposal.
If these places are dry, the disposal has probably rusted out.
I wrote instructions for disposal replacement:
How to change disposal: Disconnect p-trap and tailpiece going into disposal.
On image below loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Apply rectorseal where lower p-trap comes together.
Add a comment
Dec 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My dishwasher air flow leak why
I will guess you are talking about the air gap that is mounted on the sink top. A simple fix is to attach an extra piece of hose/pipe/tube between the sink mount and the 'upside-down y' shaped connection. This will give you an additional buffer between your sink and the splashing water flowing from 1 side of the 'y' to the other. Any number of tubes will do the trick. Just make sure that your connections are secure. Good luck
Dec 04, 2009 | LG LDS4821ST Stainless Steel 24 in....
My dishwasher is apart (bottom and all tubes, pump looking things) but I'm having trouble remembering where all the tubes connect to. There are three wide diameter tubes (short, medium and long) and two...
you have one tube from pump to agitator, one to the sink and one coming into the washer for fresh water. If you are wondering about the supply tubes into the tank from the pump, the pressure is the same for all hoses.
Aug 16, 2009 | Dishwashers
Foul odor coming from kitchen sink/dishwasher area????
Hi Jenny - I had a terrible smell coming from under my sink, and I too thought it was a dishwasher/garbage disposal drainage issue. I used vinegar, baking soda, bleach and hot water on a daily basis. When I cut out the wallboard from under the sink and the smell got even worse, however, there was no sign of any water leaks or evidence of a dead animals. Come to find out, when I had a "friend" cut out a pass through from my kitchen (above the sink) into the den, he cut the pvc exhaust pipe and didn't re-route it nor cap allowing the fumes to escape outside via the attic. Thus, the fumes had no place to go other than down. The smell confused me because I thought it was rotten food or most likely a dead mouse trapped between the wall. The smell was actually causing me to get headaches. It's been almost 24 hours that this was repaired and I already can "smell" the difference. I hope this helps! Good luck.
Mar 30, 2009 | Tappan MDB531RF Dishwasher
Kohler 5988 Sink leaks from soap dispenser spout (?) when dishwasher is running
Hi.. Its a breather or "vent "and its clogged. Remove the drain tube under the sink that runs from the vent to the connection on the drain( under sink). Clean vent and replace. Please send me some Positive feedback if I've help. Thankyou!
Jan 21, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Should the drain tube be looped or can it be pulled down for extra length
If the drain line goes into an air-gap on the top of your sink than it can be pulled down. If it goes directly into your garbage disposal then it really should be looped a bit higher than the bottom of your sink incase your sink gets stopped up the water will not flood back into the dishwasher. Some models come with a "check valve" on the end of the drain line (it's plastic and is about 2" long) these prevent water from draining back into machine and potentially flooding your nice floors.
Jul 21, 2008 | Maytag Dishwashers
Dishwasher drains into sink
As background, the dirty water typically goes from the dishwasher to a small tube within a tube, and that goes to the disposal. This ensures that your dishwasher does not back up in the event of a clog.
The problem is likely that the tube that links the thing you see next to your faucet to the disposal is either totally or, more likely, partially blocked.
I recommend taking the entire flex pipe off and inspecting. In my case it was about 80% blocked, so a simple test whereby water was pored down failed to show the issue.
Once I took it apart and gave the tube a plumbing version of an angioplasty all was well.
Dec 31, 2007 | Tappan 18 in. MDR251RE Built-in Dishwasher
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
196 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Ned Halaweh
Ned Halaweh
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
