Question about Sharp LC60C6400U 60 in. HDTV
Screw hole size on back of 60 inch tv - Sharp LC60C6400U 60 in. HDTV
Screw size to mount 32 inch Emerson flat screen?
I don't know, but you can figure it out. It's a sure bet that it's a metric thread. 6mm would probably be a good guess. Could be 8mm also. They're likely fine pitch threads. Take a close look at the back you your TV with a flashlight and take a close picture of the screw hole with a ruler close by that shows up in the picture. Take another picture with a pencil or some other object lightly pushed into the hole. Take the photos and the pencil (or whatever you use) to Lowes or Home Depot and try to match your picture with what you see there. In the hardware department where the screws are, they have rectangular plates on the rack with every size screw and nut for you to see and fit your sample into. Stick your pencil into the holes until you find one that it goes into the same amount that it went into the hole on the back of your TV. You'll figure it out.
If its any consolation, Lowes has calculated that the average project their customers work on requires three trips to their store.
Mar 16, 2015 | Emerson Televison & Video
What is screw hole size in a 50 inch zenith tv to mount to tv stand
It will be a 4 to 6mm screw. Exact model is going to be needed to know exact size.
Feb 08, 2015 | Zenith Televison & Video
Computer case fan for Gateway Performance, mid-tower case
Case fan size is typically measured in mm. Common sizes include 40, 60, 80, 92, 120 and 140 mm. OEM cases can have proprietary fan sizes as well.
Jun 12, 2012 | Gateway Computers & Internet
Screw size for wall bracket
Hello. The best thing for you to do is take your bracket to a hardware store and get the largest diameter screw you can that will fit easily into the holes. Regarding length, you should try to screw into the wooden studs behind the sheetrock or plaster wall so you will want 2 and 1/2 or 3 inch screws. Be sure to drill a pilot hole for each screw but only go in half as deep as the screw is long and use a bit that is only half as big around as the screw is.
Jan 14, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Has no mounting screws what type do they take or are they standard
Most of these tv's use the 1/4-20 machine screw, for example, has 20 threads per inch and a 1/4 inch diameter. I would recommend that you stick a piece of wire into the screw hole to determine the length that you need and start with this size screw. If it fits nicele and snugs down you will know you have the correct size.
May 07, 2009 | Televison & Video
No screws for wall mounting 42 inch tv
any hardware store will have them bring your tv manual with you it will tell you the spec on the screw to connect to the 4 pre existing nuts on the back of the tv as far as from the mount to wall it will be a standard lag bolt small enough to fit threw the hole and long enough to go threw the drywall and about an inch and a half of the studd 2" to 2 1/2" inch lag bolt will work
Apr 14, 2009 | Televison & Video
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Sharp LC60C6400U 60 in. HDTV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
