Question about Buffalo Technology Terastation Live HS-DH2.0TGL/R5 (747464113319) 500 GB Network Storage Server
Replacement fuses for controller board - Buffalo Technology Terastation Live HS-DH2.0TGL/R5 (747464113319) 500 GB Network Storage Server
How do I test a control (circuit) board?
You really can’t test a control board, but if you have a separate oven board there is a fuse between the two.
Sep 25, 2017 | Kitchen Ranges
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
Jet arms will not turn
check if its dead then the power coming into the unit is bad or the fuse inside on the control board has blown.
check the power at the dishwasher and if all is well then open the door, remove all the screws from around the edge, raise the inside panel, swap the fuse thats on the control board
If the control panel is not lit at all and the dishwasher doesn't function either then you will have to check the fuse. The fuse is on the control board. It is a white flat plastic fuse that is on the front of the control board.Remove the screws from the inner door. There should be about eight or so screws that need to be removed from the door we it is opened.
After those screws a removed you can pull off the inner and outer door to expose the control board in the top portion of the door. It is usually in a black plastic cover that protects the board. You will need to depress the clips on the black plastic cover on either side to release the cover. Once the cover is off you will see the control board and fuse attached to the control board.
If you have a meter you can check the fuse with continuity. First unplug or turn the circuit to the machine off. Then take the wires off the fuse and put the leads from the meter onto the terminals of the fuse. And then set your meter to ohms or continuity. You should read 0 ohms or a tone with continuity. If the fuse is good and has continuity then you need to replace the main control board.If the fuse is bad you will have to change it.
Jun 26, 2014 | Whirlpool DU930 Built-in Dishwasher
How do you replace the fuse on the control board
The fuse on the CCU control board cannot be replaced.
Unless you would have a fuse that blew from age, replacing would not solve the reason why the fuse blew. A new one could equally blow when you start the machine.
May 17, 2014 | Fisher and Paykel Washing Machines
15A fuse going out. Replaced 3 with no success, spark on low end of board after about 5 seconds, thenn fuse went.. Unplugged power wires to the lower board, powered up treadmill and the fuse survived. ...
You are going to need a motor controller, or find someone who can repair the one you've got there.
If it blows the fuse immediately on power up, it may require a full wave bridge rectifier replaced on the controller. If it blows when the start button is pushed, it might be a MOSFET or SCR found on the motor controller..
Sportsart fitness can be reached by phoning 1-866-709-1750. The website is found at
http://www.sportsartamerica.com There you can find a dealer/service depot in your area.
Dec 19, 2010 | Sportsart 6300 Treadmill
We replaced the heating element and control board
Hi Paul,
First off check to make sure you have incoming power, that the circuit breaker is not tripped or fuse blown, the outlet it is connected to has power, no switch that controls that is off.
If power is going to the dishwasher the most common reason for the unit to be dead like this would be the thermal fuse. The thermal fuse is a device that clips on to the control board you just replaced. It senses the temperature of the board and trips if it gets too hot. My guess is that it either is not clipped on to the new board in the right spot or one of the wire connections to the board or this fuse is not tight and creating enough heat to trip it.
You will need to replace this fuse if it is bad, it will come with new wires for it. Be sure to install the new wires, the kit will have instructions.
Apr 25, 2010 | Kenmore 24 in. 16472 / 16474 / 16479...
Whirlpool Oven Control Panel Thermal Fuse
If the display is totally out it is likely the thermal fuse this is located where the wire connectors plug into the board it looks like a small resistor in a platic shrinkwrap type sleeve. test it with a continuity meter.
Oct 25, 2008 | Ovens
I'm getting a SC 558 error
SC558 Abnormal zero
cross signal
- Timing & Condition -
Zero cross signals
generated within certain
period do not reach a
predetermined target
value.
• Poor connections
• Blown fuse
• Defective AC drive board
• Defective main control
board
• Defective I/O control
board
1. Make sure the following are connected
properly:
• CN212 and CN229 on the I/O control
board
• CN303 on the main control board
• CN7 on the AC drive board
2. Check the current through the signal lines
in the above harnesses.
3. Replace the fuse (FU101) if it is blown.
4. Test the AC drive board, I/O control
board, or main control board by checking
the signal line at each pin.
[Signal Check]
• Zero cross: CN7-5 on the AC drive board/
CN229-6, TP216, or CN212-B8 on the I/O
control board/CN303-B4 or TP120 on the
main control board
Any problems get back to me
Than You
Mar 11, 2008 | Ricoh 6513 Copier
MAH5500BWW model fuse blown
You probably need the motor conversion kit 12002039. This Neptune motor / motor control board has a high failure rate. To determine this you need to remove the front cover and inspect the motor control board near the floor on right side for burnt components or a blown 10 amp fuse. If you have burnt components or a blown fuse then your motor control board has failed and needs to be replaced. See www.neptunewaxmotor.com for Neptune disassembly pictures and other neptune information.
Dec 31, 2007 | Maytag Neptune MAH5500B Front Load Washer
Buffalo Technology Terastation Live HS-DH2.0TGL/R5 (747464113319) 500 GB Network Storage Server Logo
20 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
