Question about Tascam 2488 Portastudio Multitrack Recorder System
External FX Hi I tried to connect a space echo, but the sound is very bad, and noisy... Is there any way to fix this problem? Thanks
  • soutisg Jan 27, 2009
    Well from the effect's output I connect to Tascam's Input (I also tried to connect to H) and from effect's input, to Effect Send 1. I think the connections are ok.
    Thank you very much!!
  • Dave Hart May 11, 2010
    Please explain how you were connecting and/or recording the effect and I'll see if I can help.
  • 6,784 Answers
Try raising your sound module dept to 24 bits. also, check your connection wires for breakage. sometimes, cheap wires can cause this as well.
Posted on Jan 28, 2009
Need echo dot app with setup instructions
hi Gary.
  1. Turn on Echo Dot. Place your Echo Dot in a central location (at least eight inches from any walls and windows). ...
  2. Connect Echo Dot to a Wi-Fi network. In the Alexa app, follow the instructions to connect Echo Dot to a Wi-Fi network. ...
  3. Talk to Alexa. ...
  4. Optional: Connect Echo Dot to an External Speaker.
Amazon.com Help: Set Up Your Echo Dot
https://www.amazon.com/gp/help/customer/display.html?nodeId=201994280
if this does not help you out go to this link and read up some more.
echo dot app with setup instructions Google Search
Nov 20, 2017 | Echo Computers & Internet
Poor audio with Logitech Quickcam Pro 9000
What type of internet connection do you have and also at what speed? How is the video quality?
Feb 21, 2008 | Logitech Quickcam Chat Webcam
Setting up echo dot
hi roger.
see if this helps you out.
or if you need more help go to this link.
Setting up echo dot Google Search
Nov 16, 2017 | Echo Computers & Internet
Hi, I have a EURORACK ub1204fx and this is my problem: the effect does not work when I open fx return, there is much noise. Dpm5 broken?. How to get it? Thanks
This is confusing... the "FX return" is for an INPUT from an EXTERNAL effects unit... if you try to take output from there it will be nothing but noise as you are tying two inputs together with nothing driving them. Possibly you are misunderstanding the terms and use of these connections.
Jan 03, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Feed back thru external speaker, very bad
Have your antenna checked at a place that knows what they're doing. If your antenna system is bad, ground problem,coax bad mount or maybe just a wrong or bad antenna. Then the sounds not getting out the antenna and its feeding back thur the radio.If your echo board was bad then your radio wouldn't transmitt at all.
If you unplug your external speaker will it squeal? If not do the antenna and if that reads fine just try a better speaker like a uniden 20watt speaker.I own a CB shop and this is easy to fix.
Jul 10, 2010 | Connex 3300 240-Channels Base CB Radio
I have a Behringer 2642a mixer and a Roland 201 Space echo. How do I connect the echo into the mixer? There are so many input and outputs on the back of the mixer! Pete
This is relatively easy. All you need are two stereo RCA cables and RCA to 1/4" adapters. Plug the 1/4" adapters in to the FX1 send jacks on your mixer ( 1 only if you want mono echo, 1 & 2 if you want stereo ), and the other 1/4" adapters into your echo units in and output jacks - of course if you have 1/4" cables, you won't need the adapters.
The output of your echo unit then plugs into the FX return jacks on your mixer. Set your FX1 and FX2 send controls on the channels you want echo up to the 12 o'clock position and turn up the FX send masters also. You should see some level indication on your echo unit. The turn up the FX return controls on your mixer to the extent you want echo.
You may have to do some adjusting of all controls on the mixer and echo unit to get just the right amount of "dry" and "wet" sound.
Jul 29, 2009 | Behringer Audio Players & Recorders
When I try to use both internal and external speakers at the same
Check your plugins to make sure the external speakers arren't plugged into the rear surround plugin. That usually makes an echo sound. Also try adjusting your equalizer. Right side of eq should be up higher, then middle should be a little lower, and left side of eq should be about the middle setting. If this works or not let me know
Jan 17, 2009 | Samsung LN52A650A LCD TV
Echo
It's your external speakers. Try headsets. Honestly, it'll sound 1000% better for both of you.
Jan 03, 2009 | Microsoft LifeCam VX-3000 Web Camera
Clutch is noisy
Sounds like the clutch throwout bearing is going bad. Not an expensive part but the transmission has to be removed to fit the part.
Jun 23, 2008 | 2001 Toyota Echo
Can't hear voice of singer on speakers, more of an echo sound
Hello Shemon
Well, there is 2 option here, 1) your sound speakers are not connected corretly or in the right slots on the sound card.
2) your sound card, (internal or external) you have to use the mixer on software to put the right channels for the music you heard. try configuring in control panel, in multimedia devices, the speakers. for 5.1 system, or 2 way speakers or 3
try again
Dec 25, 2007 | Bose Companion 3 Computer Speakers
Tascam 2488 Portastudio Multitrack Recorder System Logo
69 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
John
John
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
