Question about Lexmark Office Equipment & Supplies
Z645 won't print
I checked the queue but the signal doesn't seem to be getting to the printer. I've uninstalled and reinstalled it but it didn't help
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
Lexmark x1190 with windows 7 print queue wont clear after printing
Once you load the driver successively then don't try to fiddle with driver. Remove the printer from the system and switch on whether the printer
initialize proper, try to print one self test page.
Jul 24, 2012 | Lexmark X1190 All-In-One InkJet Printer
Shows printjobs on printer but not in queue
Hi
Try disconnecting the printer from power and from the PC completely.
Reboot the PC.
Connect the printer again and then try printing.
Solved?
Uninstall and re-install the printer again.Don't have installation discs?
Download the drivers from the link below,Just select your Operating System,
h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=295932&lang=en&cc=us&prodTypeId=18972&prodSeriesId=295930&taskId=135
Hope it helps.
Feb 23, 2012 | HP DeskJet 9300 InkJet Printer
My printer is showing as online and ready, but print jobs are stacking up in the queue. i have to have this fixed asap for i use my printer for shipping labels on ebay and have to have my items shipped out...
Please follow the steps below to fix the problem:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Aug 29, 2011 | Lexmark Z645 InkJet Photo Printer
Keeps printing copies of what i copied last week and won't copy what i want this week
((make sure you have the printer turned off)) otherwise you it might print another page if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a display print queue tab you can see all prints right click on the ones you don't need select cancel
it will be in the print queue where you can stop it printing right click to delete what you are printing you might have to uninstall the printer then reinstall to adjust your print settings
or just go into your printers settings to alter/change the settings
hope this helps
Jun 12, 2011 | Computers & Internet
I have an epson stylus TX110 and it was printing fine today, but then as is sent a job from adobe it prepared to print (made usual noises) but then didnt take any paper and just went quiet. I've tried...
Try purging your temp files. If it's a usb connection try a different usb port. Since it can print from scan and do a test nozzle print then it's not getting data from the pc to the printer. If a different port doesn't work either, and if purging your temp files doesn't work try it on a different computer if possible. You may need to reinstall the driver for it.
oh and make sure you don't end up with one of those 'oh duh' moments :) ... check both ends of the cable to make sure it didn't become loose or unplugged :)
Jun 05, 2011 | Epson Stylus Photo R1900 InkJet Printer
I have a Z645 that won''t print. I've uninstalled and reinstalled it. I tell it to print and it goes to the print queue but then doesn't seem to send the signal to the printer.
in the printque check out whether the printer is off line or online.if there is tick mark sign beside the off line option that means it is off line .also check out whether it is on pause printing .reset all the settings and check out.also replace the usb wire and check out.
Jan 27, 2009 | Office Equipment & Supplies
HP 2015 Printer not printing as a shared printer
Hi Ronmur,
Few checks...
1. Is there sufficient diskspace for to queue print jobs?
2. There a corrupted print job that is holding the queue. Find the which application on which computer sent the print job. Send it again to see if it holds up the print queue.
Dec 15, 2008 | Office Equipment & Supplies
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark z845 ink refill problem
i need adisk to install z645 printer towindows vista couputer
May 08, 2008 | Lexmark Z645 InkJet Photo Printer
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
