Question about E-Machines eMachines Desktop PC
Emachines W2888 not turning on
I have an emachines W2888, about 4 ½ years old. One day it shut off on it’s own, and I haven’t been able to get it back on since. I checked the power connection, the cord, replaced the power supply and the cpu fan, but it still will not go on. Neither of the fans go on and it doesn’t sound like there is power to the hard drive. When the power cord is plugged in, I do, however, see a very tiny green-colored LED light lit on the top of the motherboard, so there is obviously some sort of power getting through. What should I try next?
  • rbramhall Jan 28, 2009
    How do I know if the power supply is bad? If I plug in the power supply to an outlet, with none of the power cords connected in the computer, should the power supply fan come on?
    Problem Solver:
  • 6 Answers
Easy fix! Sounds like you bought a bad Power supply. Purchase an identical p.supply and it will run like a car!
Posted on Jan 27, 2009
  • cmptr86
    cmptr86 Jan 28, 2009
    The power supplt will be bad if you hook it up to your motherboard with all the proper cables connected and once you press the power button the computer should kick on. If not it's the power supply there's a small posiblility it could be the power button/switch on your computer. If you plug the power supply in on it's own and the green led light goes on that is also an indication that the power supply is working. Easy Fix!
Help. my laptop is not working. i turned it on this morning but it suddenly turnoff then i turn it on again and its not working.
The main problem these days are that people are putting windows 7 on desktops and laptops that are 4 to 6 years old. They don't have the video card that is capable nor fast enough to care that OS. So go back to the system it came with and the problem will go away, or buy a newer computer.
Oct 06, 2012 | eMachines D520 D720 Laptop Motherboard...
I have an emachine that is 1.5 years old. The problem is that it locked up/froze and was not able to turn off so I turned off the power strip. Now I cannot get the computer to start, it sounds like the...
Try to disconnect the cables connected to the mother board from your power supply then put it back in, then remove the CMOS battery and put it back in then try to turn the computer on..If it's still the same this means you need to purchase a new power supply.
Sep 10, 2010 | E-Machines eMachines Desktop PC
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
W2888 emachine just shut down as if it were unpluged
THE LITTLE LIGHT ON THE MOTHERBOARD SHOULD ALWAY BE ON. THE FAN ON THE POWER SUPPLY RUNNING NORMAL OR FAST.
DID YOU ADD ANY NEW DEVICES TO YOUR COMPUTER LIKE UPGRADING THE RAM, VIDEO CARD, NEW INPUT DEVICE.
NEED MORE INFORMATION.
ROD
May 12, 2009 | Bestec (ATX-250-12E) 250-Watt Power Supply
I ran into a emachine desktop 3 days ago, and reinstalled operating system, everything was working fine, however when i shut down and booted the next day, computer continued to reboot itself after passing...
there is usually a jumper with three pins beside the cmoss battery just move the jumper to the last two pins for 5 seconds and put it back that will reset your bios that may help
Apr 18, 2009 | Computers & Internet
Emachines W2888 will Not Start up
Most likely the system board has failed. If the power supply had blown it is not unusual for the subsequent spike to blow the system board. On the other hand it may have been the system board that failed and the PSU is ok. Emachine system boards are rubbish
Either way you will need a new board and most likely a reinstall of the OS
Dec 09, 2008 | E-Machines eMachines Desktop PC
Emachine restore back to factory settings
I had to restore my Emachine. I have Windows Vista
(1) Go to start menu
(2) Click on all programs
(3) click on Emachine
(4) click on Emachine recovery management
(5) Click on restore on the bar across the top
(6) click on restore to system factory default
It takes about 20 mins.
Sep 07, 2008 | Computers & Internet
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
396 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
