Question about Freezers
Philco/ford freezer door seal
Doorseal
2 Suggested Answers
SOURCE: Philco Freezer - replace/repair seal & plastic around top
Well, you can find a universal gasket kit. Instead of being one solid piece specifically made for you model, It is made up of pieces that you cut to fit. I should warn you that these kits are very difficult to work with. If you dont create an air tight seal, the constant warm air leak will make it run longer, decreasing its useful life.
You said however that the gasket is only dried and rock hard, not that it was torn or falling away from the door. If that is indeed the case, and you still have good tight seal on all four sides, you might be ok for a while.
factory replacements are nearly impossible without a model number for reference.
Posted on Mar 29, 2010
I have a kenmore upright freezer model 970-254326 bought in 2011 from sears. The door opens left to right but in my tiny apartment I NEED it to open from right to left just to put things in and get th
You should see some plastic plugs or holes for mounting bolts on the opposite side of the freezer case. The latch mechanism should adapt from one side to another.
You would remove the top hinge and then lift the door off of the bottom hinge. Then you would remove the bottom hinge and switch it to the other side. Place the door onto the bottom hinge and then install the top hinge on the other corner of the case to match.
You should be able to move the handle from one side to the other. The magnets in the doorseal should work as before to keep the door closed. The interior light is usually centered on the bottom to aid in reversing the door opening.
Dec 30, 2011 | Kenmore Freezers
MAGIC CHEF FREEZER THE DOOR IS NOT OPENING FOR 8.8 CU FT UPRIGHT FREEZER MCUF88W -- BRAND NEW JUST BOUGHT?? HELP
If You run Your finger in between the rubber seal that is resting on the freezer and the frame of the door , the rubber seal will break lose. When you open the door the seal is attache to the door.
Just had the same problem after unboxing.
Simple, just be sure to do the entire door.
Sep 27, 2010 | Magic Chef 11.8 cu. ft. / 334 liter...
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
Sep 24, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Good day,
Unlikely you would be able to repair if the inner liner is coming apart.
A local appliance parts house may be able to supply universal gasket to fit to the machine but again, if the inner liner is bad it could prove to be fruitless.
Oddly enough, if you visit supermarkets you will see chest type freezers with no top at all.
Seems like a terrible loss, but it's not.
Cold air falls, hot air rises. When the freezer generates cold air it doesn't spill out the top. It settles into the bottom of the freezer, and stays there. Likewise, warm air rises and has no interest in going into the freezer cavity.
Bottom line. Very little loss.
If appearance doesn't matter, and you can get it close, you should be able to continue to use it.
Your choice, but I thought you would like to know the physics involved here and how it does or doesn't affect you.
Mar 28, 2010 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezer door has a gap in the middle. Seal doesn't
Put a long straight edge on the door to verify a warp. A 4 foot level is good for this test.
If the door is in fact warped. You should pull back on the seal,loosen the screws behind the seal holding the door liner in place,adjust the door to the straight edge and re-tighten the screws.
If the straight edge does not show a warped door,take a hair dryer and heat the seal where it is off the frame. Do this with the door closed and you will see the seal relax and touch the frame. Let it cool in this position before opening the door again.
If neither of these is the cause,loosen the door hinge and re-adjust the door position,then re-tighten the hinge screws.
Feb 13, 2010 | Frigidaire 19.53 cu. ft. Commercial...
REPLACEMTN MAGNETIC DOOR SEAL FOR FREEZER NOT
freezer needs to be down to temp with door shut for about 1hour to build up vaccum
Sep 14, 2009 | Bosch Freezers
Frost free freezer with ice in the bottom and water dipping off bottom door hinge
Frost Free Freezer have an automatic defrost, which is essentially a heating element which melts any ice. If your door seals are in poor condition or something is preventing the door from sealing the ambient air may be melting the ice more than the drain can accommodate. Check the drain in the bottom of the freezer. Humidity can also cause more water to accumulate, especially if the door seals are not sealing.
Jul 10, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer door of electrlux freezer keeps coming
Try cleaning along seal and seal itself. If it does not work get new seal. The seal do go bad after a while.. If under warranty call dealer you purchased from for them to replace.
Jul 06, 2009 | Freezers
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
New freezer has bad door seal
it often works to warm the seal with a hairdryer and reshape it
Nov 29, 2008 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Freezers Logo
65 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
