I have a Z645 that won''t print. I've uninstalled and reinstalled it. I tell it to print and it goes to the print queue but then doesn't seem to send the signal to the printer.
    Sergeant:
  • 250 Answers
In the printque check out whether the printer is off line or online.if there is tick mark sign beside the off line option that means it is off line .also check out whether it is on pause printing .reset all the settings and check out.also replace the usb wire and check out.
Posted on Jan 27, 2009
In Windows 7, items put in the print queue at home won't print when I get to the office.
I don't see how this can be done, because there are 2 different print queues in question. Not to mention the lag and buffer required by the printer. So when you disconnect communication the job hangs.
Besides the spooler at work my lie on a dedicated print server, especially if the printer is on a network and and not attached directly to you PC.
Feb 26, 2013 | Microsoft Windows 7 Professional for PC
Lexmark x1190 with windows 7 print queue wont clear after printing
Once you load the driver successively then don't try to fiddle with driver. Remove the printer from the system and switch on whether the printer
initialize proper, try to print one self test page.
Jul 24, 2012 | Lexmark X1190 All-In-One InkJet Printer
My printer is showing as online and ready, but print jobs are stacking up in the queue. i have to have this fixed asap for i use my printer for shipping labels on ebay and have to have my items shipped out...
Please follow the steps below to fix the problem:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Aug 29, 2011 | Lexmark Z645 InkJet Photo Printer
Keeps printing copies of what i copied last week and won't copy what i want this week
((make sure you have the printer turned off)) otherwise you it might print another page if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a display print queue tab you can see all prints right click on the ones you don't need select cancel
it will be in the print queue where you can stop it printing right click to delete what you are printing you might have to uninstall the printer then reinstall to adjust your print settings
or just go into your printers settings to alter/change the settings
hope this helps
Jun 12, 2011 | Computers & Internet
My printer is not printing it tells me they are in queue
try going to control panel - printing - Resume Printing
Mar 29, 2010 | Lexmark Z645 InkJet Photo Printer
Print jobs go through the queue but nothing prints
Maybe you should uninstall software for the printer the restart your system again then reinstall back the software for the printer, the problem maybe as a result of the configuration on your system. after reinstalling try to print out a tested page to see if the problem still persist. Thanks
Sep 25, 2009 | HP Hewlett Packard LaserJet P1005 Printer
Document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
May 27, 2009 | Office Equipment & Supplies
Z645 won't print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 27, 2009 | Lexmark Office Equipment & Supplies
HP 2015 Printer not printing as a shared printer
Hi Ronmur,
Few checks...
1. Is there sufficient diskspace for to queue print jobs?
2. There a corrupted print job that is holding the queue. Find the which application on which computer sent the print job. Send it again to see if it holds up the print queue.
Dec 15, 2008 | Office Equipment & Supplies
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
62 people viewed this question
jasbo
jasbo
